Question about Rex Sewing Machines
Rex blind stitch model L118-2 instruction manual is there a site to download
  • 745 Answers
SOURCE: Blind stitch won't lock
This is hard to find in the internet so I hope this will solve your problem...
Frequently Asked Questions
Q) Help!
I am breaking a lot of needles and the tension is getting too tight on its own while stitching and causing the thread to break. I am learning the machine for two weeks. Is it so sensitive too wools, cottons, and fleece that this would make such a major difference in the stitching - breaking needles, breaking thread?
(A) It may not be tension that is causing the problem with your portable blindstitch. If you have broken needles it has probably left some needle burrs in the thread and needle path that need polishing off with fine emory cloth (crocus) before sewing again.
Start with a new LWx6T needle without thread or fabric. Watch the needle as you turn the hand wheel. If there is needle deflection, reduce the penetration dial until there is no needle movement. If there is needle deflection caused by burrs, they must be polished off. Check the looper tip and two arms for any needle burrs and polish off. If there is needle deflection caused by the needle track lifting the needle, lower the track very slightly with the screws on the side of the black metal bracket above the needle.
Finally, Back off on the tension dial and retighten while you are sewing with a light strong thread and light to medium weight fabric, until you get the correct tension without loops. If tension is too tight it will push the thread up so it is not all the way down between the tension discs where it belongs.
(Q) I can't understand how to finish off at the end. It
always unravels. I have read the manual and it seems simple but I
apparently just "don't get it." Any help would be appreciated.
(A) At the end of the blindhem seam, position the needle all the way to the left, then use the knee lift to remove the fabric and jerk on the fabric at the same time. That will tie off the tread and break the thread at the
needle without bending the needle. You can weave the thread tail back into the stitches or cut it off. Before the above procedure, you could also turn the handwheel counterclockwise for a few stitches, then come back to the end of the seam and repeat the first procedure above.
Posted on Nov 17, 2007
SOURCE: HOW TO THREAD
Go to www.reliablecorporation.com. Under products check out the MSK555 blindhem machine. It is the same as the Rex 518. To the right of the page is a category to download the manual. It is very helpful. I have the Rex518 with the original instructional manual, but the translation into English was very poor. The MSK555 is published so you can understand the manual, and figure out how to use your machine. I too am a first time user of a blind hemming machine.
Good Luck.
Posted on Jun 24, 2008
SOURCE: instruction manual
I have the manual and can email a copy to you...Hopefully you are still needing it.
Posted on Apr 01, 2009
  • 108 Answers
SOURCE: I have a Rex RX-518 Blind stitch sewing machine. I
i was able to find manual at www.ifixmachines.com
Posted on Feb 15, 2010
  • 139 Answers
SOURCE: SINGER 7422 28 STITCH 2 BUTTONHOLE INSTRUCTION MANUAL
http://www.singerco.com/accessories/manuals.html
Posted on Apr 07, 2010
Rex b/s 900-pb1 wondering how heavy of a fabric will this machine stitch, particularly cordura 1000d for hiking backpack
This will depend on using the proper needle and thread on this commercial machine.
Cheers,
Embroidery Services
San Diego, CA
Jun 14, 2016 | Rex Sewing Machines
I just moved and can't find my user manual i need help with the mode and code # foot letter for a blind hemming stitch Thank you do much for helping me :
go google and type in ---operators manual for (make ,model) sewing machine --- and there will be pdf downloadable pages
there may even be a page to help you set up fot the stitch that you want
Oct 05, 2015 | Sewing Machines
Need a downloadable instruction manual for Rex RX-518 blindstitch hemmer sewing machine please!!
No luck findong your but Go to www.reliablecorporation.com. Under products check out the MSK555 blindhem machine. It is the same as the Rex 518. To the right of the page is a category to download the manual. It is very helpful.
Good luck
Thanks
Apr 11, 2011 | Rex RX-518
How do you adjust timing on Rex commercial blind stitch?
I was just researching the same issue, only for my Lewis Blindstitch. I found a copy of the US Blindstitch maintenance manual on the mansew.com webstite. It looks like the setup is very similar to my machine, so maybe you can adapt the information to yours also. Good luck. Sorry, I was not able to post the hotlink, but this is it spelled out, exactly as it shows.
http://www.mansew.com/US BLIND/USBlindstitch_Maintenance.pdf
Apr 30, 2009 | Rex RX-518
Timing problem on Rex commercial blind stitch
retime your hook with relation to your needle the hook is slightly out of time causing it to "slip the loop" the hook should hold the loop until the needle retracts forming the chain
REX blind hem how to lock the stitch
When I purchased my blindstitch machine, I was also told to kind of snap the fabric as you pulled it our of the machine. Like you, I found that to be a little risky. Sometimes I'd just unravel what I'd sewn. I have found the most dependable thing to do is: Before removing the fabric from the machine, snip the thread between the fingers of the looper as it approaches the needle. If the loop is broken, the chain stitch will not pull out. If you cut the loop as it approaches the needle, you will get a bit longer tail so the needle doesn't come unthreaded on the next run. If you find you need a bit longer thread tail, you can pull a bit on that loop before cutting. As long as the needle has passed through the loop on the previous stitch, you'll be fine.
Dec 29, 2008 | Rex RX-518
HOW TO THREAD
Good Luck.
May 29, 2008 | Rex RX-518
Sewing Machines Logo
55 people viewed this question
Top Rex Sewing Machines Experts
Chance Miller
ray gallant
Are you a Rex Sewing Machine Expert? Answer questions, earn points and help others
