Question about Cameras
Why does my neewer 680 flash only works on aufomatic on my tii5
When I put it on A+settings and TTL it works. If I try m or av or any other settings it does not work.. What am I doing wrong
Quack
  • 542 Answers
SOURCE: flash won't fire on p-ttl mode
The AF360 can be in TTL mode until it is mounted on a P-TTL compatible camera and turned on, then it senses the camera and goes to P-TTL. However, sometimes in the past when I got TTL and it should have been PTTL it meant that either the batteries were not connected properly (I know, sounds strange, but check the battery compartment cover to make sure it is seated properly and make sure that the batteries are all in proper position), or that the AF360's contact pins were not all making proper contact with the shoe or extension. Beyond that it could be a faulty flash. You have swapped lenses and cameras with the same result, how about swapping flash? Unfortunately that may be your problem.
Posted on Sep 08, 2005
SOURCE: Cannot get to work right either TTL or as wireless remote
This one got me too. I assumed it wouldn't need the built-in flash if it was a wireless remote. I still want to know why this is is so. If it needs a pre-flash to set exposure, surely it can pre-flash with the remote SB600?
Posted on Dec 26, 2007
bearydude
  • 62 Answers
SOURCE: I Have a Nikon d80 with a sb800 speedlight
CAMERA ON P , FLASH ON TTL , AND LENSE ON F22
WAIT FOR THE RED LIGHT ON FLASH , GOOD MEMORY CARD AND IT SHOULD WORK .
BERRIE SMITH CAMERA REPAIR
BBMW@BELLSOUTH.NET
Posted on Nov 29, 2008
  • 9 Answers
SOURCE: Speedlight SB-600 TTL Flash: When I set my SB600 (mounted on D70) to TTL or TTL...
the sync speed for the sb-600 is onlt 1/200 on most cameras i think so if your shutter is faster then that then all you will see is black/ the curtans behind the shutter.
basicly just try again with a slower shutter speed
Posted on May 11, 2010
  • 3 Answers
SOURCE: I've mislaid my manual for my Metz 54. I haven't
Not sure what S6 pro is, but if the flash doesn't fire in TTL then the flash is not support the type of TTL in the camera. I had the same problem with Nikon flashes on Nikon bodies. Perhaps you need a newer SCA adapter? Please go on http://www.metz.de/en/photo-electronics/sca-adapter/archive.html to check which adapter you need
Posted on Jul 12, 2010
Not working in TTL mode
Yes did you set the camera also go to flash/bracketing on your camera and set they both have to work together
Feb 21, 2014 | Nikon Speedlight SB-800 TTL Flash
Neewer eza-c1 manual
EZA-C3 Manual, only difference is the plug that fits the camera...
http://www.scribd.com/doc/100733549/EZa-C3-Digital-Timer-Remote
Jan 30, 2012 | Cameras
May 07, 2010 | Nikon Speedlight SB-600 TTL Flash
I have a canon 40D and a speedlite 580 second sync not working
If you are not in P, AV, TV or M then the camera will not allow that feature. The picture modes disable many higher, more sophistocated features.
Jan 31, 2010 | Canon SPEEDLITE 580EX TTL Flash
Promaster 7500 D Digital Flash usage with Nikon D70
you need to go to your cameras menu and set your flash function to m ( no to ttl) set it in full M and then it works hope it works that works for me i had the same problem
Dec 05, 2008 | Promaster 7500DX for Nikon TTL Flash
BBMW@BELLSOUTH.NET
Nov 15, 2008 | Nikon Speedlight SB-800 TTL Flash
Automatic zoom
auto zoom will only work while the build-in wide-flash adapter is slided inside.
Apr 05, 2008 | Nikon Speedlight SB-600 TTL Flash
Sb 600 under exposure.
You probably haven't changed the camera and/or flash back to TTL mode from wireless mode.  Make sure they are both set to TTL, not commander mode and you should be fine.  Note that the LCD on the flash will indicate which mode it is with a little graphic.  On the D70 you had to switch between TTL and Commander mode to set it up to work using the built in flash as the commander, so you just have to switch back.
Jan 21, 2008 | Nikon Speedlight SB-600 TTL Flash
Nov 29, 2007 | Nikon Speedlight SB-600 TTL Flash
Canon SPEEDLITE 580EX TTL Flash Problem: Flash will not stay in ETTL mode
u can use the H sync button only with the camera set in semiautomatic or manual modes, it dosent work in AUTOmatic modes
Oct 23, 2007 | Canon SPEEDLITE 580EX TTL Flash
Cameras Logo
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
