Question about Acer Computers & Internet
Acer Windows 10 bad system configuration problem will not boot
How to enter Asus Q534UX BIOS
Windows 10 - How to enter BIOS configuration? - Asus
  1. Cached
  2. Similar
Hold and press [Shift] then turn off the system. Press and hold the F2 button then click the power button. DO NOT RELEASE the F2 button until the BIOS screen display. You can find the BIOS configuration. Category. Windows 10 - How to enter BIOS configuration? Windows 10 - How to boot the system from USB drive/CD-ROM?
How to enter Asus Q534UX BIOS Google Search
Jan 26, 2017 | ASUS Computers & Internet
How to reset motherboard for my acer aspire x5400 pc
Usually on motherboards if you :-
1. disconnect it from the power supply
2. hold the power on button in for 10 seconds
3. remove the battery on the motherboard for about 5 mins then replace
when you re boot your motherboard will be reset back to default settings.
You will have to press delete or F1 as you re boot so you can enter the bios to reset the time. then select default settings press F10, save and enter.
as it reboots this time press F8 to enter the windows boot menu select repair my PC from here you should be able to use system repair to roll windows back to a previous configuration.
Any problems feel free to get back to me & I'll help all I can
Apr 02, 2012 | Acer Aspire Computers & Internet
I have received a a problem in acer which is regarding boot up problem saying that windows can't start normally due to power failure
plz try by booting in safe mode, if the problem is not solved then try by booting in last good configuration, if still problem is not solved then you have to repair the operating system
Aug 17, 2010 | Acer Computers & Internet
Acer travelmate 2410 comes on does not load past the acer screen
if last known good configuration wont work (go to advance boot option before it boots to windows, then choose last known good configuration), you must reinstall your operating system using the OS cd that came with the computer. it will wipe out all your files but it will restore your computer to factory default. that is if the hard drive hasn't failed yet. if so, if OS reinstallation still doesn't work, then you have to replace the whole hard drive.
Mar 29, 2010 | Acer Aspire One PC Notebook
How do I get my Acer 5500 to boot from my uTorrent recovery disc?
Do you have your original recovery media for Vista? Sounds like you're going to have to repair the installation.
Dec 27, 2008 | Microsoft Windows Vista Home Premium with...
Acer launch at reboot
This sounds like an update trying to be configured. Try pressing F8 when the computer boots up this will take you into Safe Mode. Everything on the screen will look big but don't worry about that for now. Click on Start>accessories>system Tools>System Restore and choose a date when you know everything was working okay. When the computer has finished restoring the computer will reboot. If asked after booting choose Start Windows Normally.
I hope this helps. If not let me know
Dec 08, 2008 | Acer Aspire 5315 Notebook
What operating System has been installed to your laptop?can you clarify it?you can download support software at ACER,com but startup disk is in windows xp CD or any windows just configure your laptop in the CMOS setup or BIOS by accessing it on the boot up.just configure your laptop on CD/DVD boot media.
Jan 05, 2008 | Acer Aspire 3100-1405 Notebook
Acer 1690
They may be correct, although you can try pressing F8 on boot up and and enter safe mode. When in the menu choose 'Last Known Good configuration' and press enter, allow a reboot and hopefully you get into windows. It may also be the boot.ini which is damaged at tells the harddrive where windows is, but you will need your Windows disc to repair the system.
Apr 09, 2007 | Acer Notebook
Laptop cannot go into p.o.s.t. when it does.....
It could be the graphics, but it is a process of illimination as always. When you boot your pc keep pressing F8 and see if it will boot into safe mode. When in safe mode select 'Last known good configuration' as this may cure the problem. If that doesn't work boot into safe mode again, but this time select start windows in safe mode, if this works ok then it maybe a driver problem, probably either the wireless card or graphics, try uninstalling the graphics driver first in add/remove programmes. Restart the pc and windows should find it again and install the driver, if on the next restart the problem returns then it is the graphics driver so download a later version from the acer web site.
Mar 17, 2007 | Acer Aspire 5003WLMi Notebook
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
