Question about New Home Security
Installed a new wired doorbell and it just keeps chiming. the button is not stuck. what should I do?
  • 3,987 Answers
Check wiring . Did you use a staple gun on wiring as I know a friend who did this and put staple through the wire shorting it out .
Rind doorbell doesn't stop ringing
it is possible that the doorbell button is sticking down and keeping contact - so the doorbell keeps chiming.
Mar 24, 2018 | New Home Security
I am trying to install a Ring 2 Doorbell using the existing E851 Friedland Stockport 5K5 6BP chime. When I connect my wires the chimes ring continuously. What might I need to do?
Connect the new wire to the wire going to the original door bell button. one core of the new wire to one core of the existing wire and connect the other new wire core to the other existing wire core. insulate the joints from each other and any metal surfaces.
Aug 08, 2017 | The Home Security
I had to replace the doorbell button, now the doorbell only buzzes instead of chimeing. I have tried three different buttons and they all give the same result. Whats wrong?
This has to be a setting of dip switches that got changed somehow on the chiming unit. Open that up and check the settings.
Feb 22, 2015 | Home Security
Id like to change song on my doorbell Dimango model 4330 r cd chime reciever
The webpage http://www.dimango.com/dc-cd-quality-doorbells.htm
shows:
Wireless Doorbell CD Quality Door Chime
Model RC4300
No longer do you need a wired door chime or traditional doorbell with brass tubing to get amazing, rich sound. Our Battery Operated Door Chime from Dimango has CD quality sound while remaining completely wireless...
  • Plays three selectable sounds
    1. Ding Dong
    2. Dong
    3. Westminster Chime Click To Hear Sound!
  • Set sound conveniently at button
It seems that there is a button on the receiver/speaker. Try press once and see if the sound changes.
Nov 27, 2013 | Desa International White Wireless Plug In...
I have a IQ America doorbell with 5 chimes and 5 tunes and the bell only plays a sorta gong which cannot even be heard How do I fix this problem so that it plays a chime/tune?
We had a similar problem with a wired doorbell. There is a diode in the doorbell itself that causes the chime to ring fully. If the diode is backwards, you get just a small tone and can only hear the full chime if you hold the button down. If this sounds like your problem, open up the doorbell at the button end (or have an electrician do it) and reverse the diode.
Nov 07, 2011 | Desa International White Wireless Plug In...
Have had major snow storms in the past few weeks. Installed, prior to storms, new door chimes that worked. Since the storms, neither the front nor side bells function. The bell button has a light on...
Most times, doorbell problems are button, especially since indicator light shows you have power.
Take off front doorbell button and see two wires.
These wires are low voltage and safe to touch.
Use screwdriver and touch both screws together, or remove wires from button and then touch two wires together.
If doorbell rings, then replace button.
If bell still doesn't work then scratch two wires together and look for static-type spark that says wires have power.
If wires have power, and you crossed both wires and bell didn't work, then new door chime is suspect.
If wires do not have power, then transformer is suspect.
Open following link to see example transformer:
http://waterheatertimer.org/images/attic-transformer10.jpg
Transformers are located in basement or attic.
Scratch a wire across both screws on transformer and look for static-like spark.
If no power, then check circuit breaker.
Home centers sell transformers in the doorbell section. They are 12 and 24 volt. Check markings on old transformer.
If transformer has power, then new door chime is suspect.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 12, 2011 | Garden
How do i fix my doorbell
99% of the time, you need a new doorbell button
Also check if any circuit breakers are tripped
Check GFI breakers in baths and kitchen
Real-estate lady answer: buy a new doorbell button and connect 2 wires on back of new button.
Doorbells are low voltage and not dangerous.
If screws are loose in the holes, break off toothpicks in hole so screws have something to bite.
You need small screwdriver:
Repairman answer
Doorbell problems have 3 parts
1) The button
2) The chime or bell located in house
3) The 12V or 24V transformer located in attic or basement
4) rarely the wiring because it's low voltage and does not get hot
1) start at the button.
Remove button from wall
There are two LOW-voltage wires on back of button
Remove 1 wire and touch other wire, copper to copper
Does doorbell ring? Do you see a spark?
If bell rings, then button is bad
2) Chime or bell doesn't ring when button wires are crossed
Take cover off chime
The button works, so have helper push button while you're looking at chime
Can you hear any noise? Have helper push button on-and-off
Chimes have 2 or 3 wires >>> 2 wires if only front door has button, 3 wires if back door also has button
Take one wire loose and scratch it across each of the other wires
Remember front button is held down (or front button wires are twisted together)
Can you see a spark when wires are scratched together?
Try this with more than one wire ... but don't mix up location of each wire
If you are getting a spark, then chime is getting power, but it's not working
Replace chime
3) Transformer in attic or basement looks similar to this:
Use a wire and scratch across both screws to see if you get a spark
If you get a spark ... and the crossed wires dont ring the chime... and there is no spark at chime, then there is a bad wire
If no spark at transformer, then check circuit breaker
At last resort, but new transformer at Home depot in the doorbell section near light department
Oct 05, 2010 | Garden
Hello I have now got 2 (two) of these units over the past 8 months and neither work----changed batteries--interchanged push button---changed main unit--nothing works----but when my neigbour across road has...
The doorbell buttons and your receiver must be on the same channel. If you will get out the directions that came with your unit, they will describe the process to go through to reset the specific "codes" for your buttons and receiver.
Jan 04, 2010 | Desa International White Wireless Plug In...
Wired doorbell. Trying to connect to pre-existing one.
Unfortunately, we live in a time of need security alert and services, such as wireless door bell system. Theft and robbery, at an all-time high, it is very important to protect their family and their property. There are some equipment can provide high levels of protection and some can low cost.
Jan 01, 2010 | Kitchen Appliances - Others
New wired Heath/Zenith doorbell buzzes until disconnected
it sounds like you have a bad push button . if the wires where crossed you would most likely have this problem as soon as you turned on power .
Mar 15, 2009 | Honeywell Electrical Supplies
Home Security Logo
Top New Home Security Experts
pawnpower
NOEL
NOEL
Are you a New Home Security Expert? Answer questions, earn points and help others
