Question about Cell Phones
How does the selector switch for the air flow change from floor to dash to defrostor
It has five selections and one all the way left and one all the way to the right will not stay there
  • 246 Answers
On a cell phone
Why is hvac air coming from all three locations (vent/floor/defrost) regardless of switch setting?
Check air box if it won't change air flow some thing is wrong there inside the car
Jul 14, 2014 | 2000 Buick Regal LS
1997 Ford Taurus front defrost not working
. Air won't blow out of the floor or center vents just defrost ? Do you have manual or automatic climate control ?
Air Flow Control
Air flow control is accomplished in the following manner:
  • Primary control is through the function selector knob mounted on the A/C-heater function selector switch, which is part of the integrated control panel.
  • The function selector knob has the following positions: OFF, MAX A/C, A/C, PANEL, PANEL/FLOOR, FLOOR, FLOOR/DEFROST and DEFROST. The A/C-heater function selector switch combines a vacuum selector valve with an internal electrical switch.
  • The vacuum selector valve directs source vacuum to various vacuum control motors (18A318). Refer to the Vacuum Control Diagram , System Airflow Schematics and Vacuum Control Chart .
  • Two internal, single-pole electrical switches are also controlled by the A/C-heater function selector switch. The combination of these electrical switches controls the electrical supply to the A/C clutch and heater blower motor switch (18578).
  • The position of the function selector knob determines the manner in which the system will operate.
  • Each position of the function selector knob is detented for positive engagement.
  • Vacuum Control Motors The vacuum control motors (18A318):
    • are located on the A/C evaporator housing, A/C recirculation air duct and heater air plenum chamber (18471).
    • direct system airflow to the vehicle interior as determined by the remote climate control module or manual override.
    • The five-passenger seating configuration has an additional vacuum control motor mounted on the heater air plenum chamber to control airflow to the rear seat A/C register (19893).
Jul 09, 2017 | Ford Cars & Trucks
Toyota tundra floor heat quit
sounds like vaccuum line problem or vaccuum assist
Jan 13, 2014 | 2002 Chevrolet Tahoe
Defrost selector turns but does not change where the air is flowing
Sounds like the switch nob itself is wore out. you may need to replace that assembly, not just the nob but that cluster that has the nobbs on it. good luck
Dec 07, 2013 | 1996 Geo Prizm
My AC air registers only have air coming out of the defrost ducts
In every car, there are fins or flaps inside the dash that rotate that distributes the air flow from the blower to the desired opening, ie defrost, floor etc... This flap is controlled by a linkage which is connected to the selector switch. It may be the linkage is no longer connected, or the fins inside the dash are stuck. If the selector switch moves freely with little or no resistence its possible the linkage is no longer connected, otherwise the flaps need to be physically looked at.
Aug 09, 2009 | 1989 Ford F 150
The selector switch for dash air ,floor air doesn't direct the flow of air stays on windshield air only is there a relay or a diaphram problem?
Hi, sounds like a vacuum problem. When you select from floor to vent to defrost, the system uses vacuum from the engine to change over. If you look under the hood, near the firewall, towards the center, there should be small rubber vacuum lines. Check these lines for leaks with the engine on by spraying soapy water on the lines. If you see bubbles forming on any of the vacuum lines, this is where the leak is. Also check the vacuum lines going to the climate control unit inside the vehicle.
Jul 26, 2009 | 2004 Ford Super Duty F 450
HVAC vent selector does not function. Air flow is
THe blend door seems to be stuck. When you change settings from defrost to floor air or, vent, the blend door opens and closes directing the air to the place you want it to go to. I have had some success spraying a lubricating oil such as WD40 under the dash on the blend door. You need to get under the dash with a flashlight to locate it. It looks like a flap. Spray it with a couple of shots of the WD40. Go easy on the spraying as you may be inhaling the fumes. Keep the doors and windows open to minimize the fumes. Wait about 1/2 hour and try the A/C functions. (defrost, floor, vent air)
Mar 09, 2009 | 2002 Buick Rendezvous
Cell Phones Logo
21 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
