How do you put the charging cord back into the box?
Battery won't charge
So put the old power cord back on since you say it charged the battery normally. Why did you change it if it was charging the battery? It's quite possible that the new power cord is faulty. Just because it is new does not mean it works.
Remove the battery and plug the new power cord in. Does it boot the laptop up? Are you able to function with the new power cord plugged in. If so, then your battery is more than likely dead and needs to be replaced. The battery only has a useful life and once it is completely bad it will not charge.
May 01, 2012 | Dell Inspiron 1545 Notebook
THE SWITCH ON IS NOT WORKING CAN YOU HELP ME TO FIX IT
The Switch ON? Are you talking about the Power Button? If so it could be that your Power Cord is bad. Some models of the Power Cord has a light on it and some laptops light up somewhere when the power cord is plugged in and working.
You might have been working off your battery and if the power cord is bad it was not charging the battery and now nothing will work because the battery is completely drained.
If the power cord is good, you might have a Static Charge Buildup. Remove the power cord and the battery, then press and hold the power button for 30 seconds. After 30 seconds put the power cord back in (not the battery, leave it out) and press the power button. If it starts booting you had a Static Charge Buildup and can put the battery back in now.
If all fails, take an ink pen and stick it inside where the power cord goes. If it is not tight then the DC Power Jack is bad and need to be repaired. This will require a complete disassembly of your laptop.
Mar 23, 2012 | Samsung N150 Netbook
My samsung N150 power switch is not working
Mar 23, 2012 | Samsung N150 (36725723009) Netbook
I can not find our little black box that you plug into the wall to charge by using the usb cord.... can you charge the camera through a usb cord with the nikon coolpix s4000
if you can't put batteries in it then u can charge it that way, but if you have a spot for batteries then no because all the usb is for is to take items from the device to put on computer.
Oct 15, 2011 | Nikon Coolpix S4000 Digital Camera
Hi, I just bought your product SYMA s107. I took it out of it's box and I started flying it. At first it was flying great but after a couple of minutes it started to not even lift of the ground. I charged...
you should have charged your heli BEFORE 1st flight.......anyway,,plug computer end of usb charge
cord into computer......turn heli OFF....before you plug cord into heli look at computer end of cord,,
should be bright red light inside......now plug other end of cord into heli.....bright red light goes out!
when heli is fully charged bright light on computer end of cord comes back on......disconnect
heli right away.....if left on charge your battery could wear out....it takes about 50-60 minutes
Feb 25, 2011 | SYMA Toys industrial New Syma S107 Radio...
How do i charge my acer laptop?
You plug the charger into the wall then if there is a light on the cord or the box it is working. Then you plug the other end of the cord into the back or side of the laptop where it fits. Next time say what laptop, please! Also, If you don't have a charger search the name of your laptop model then put charger at the end of the query and buy one, because it won't last that long without a charger.
Sep 27, 2009 | Acer Computers & Internet
How do I charge my camera?
go to ebay.com search Polariod t831 , it should be a cord with a little silver box at the end you slip the battery into the little box,but be careful make sure it is an A/C cord or you might be getting a car charger, the light will be red at first and when it turns green it will be charged. The usb cable is to put the pictures on your computer. Hope this helps you..
Sep 18, 2009 | Polaroid T831 Digital Camera
Today my cord for my toshiba was behind my pillow and i was lying on it. and I didnt notice, but then it showed that my laptop wasnt charging did my cord just get too hot? will it work later?
The power adapter does not have a temperature sensitive device, therefore it won't stop for overheating if not in consequence of a fault.
Try leaving the power adapter unplugged for about ten minutes.
In the meanwhile also remove laptop battery and put it back.
Connect it back to AC and laptop.
Ensure that connection to laptop and power cord connection to AC adapter box are both well plugged.
Before turning on laptop leave it connected for few minutes.
If laptop still does not turn on and battery does not charge, then the AC adapter is faulty.
A further test can be done using a multimeter to read voltage on AC adapter plug.
A replacement AC adapter is not expensive and can be purchased online. Try entering in Google your Toshiba model followed by the words "power adapter".
Aug 15, 2009 | Dell Inspiron 5100 Notebook
Say it is charging but it's not
You may acually have a bad battery. I'de suggest a new battery first, if it says it's charging. The other problem could be a open connection from the battery to the power supply on the board but I'de take a close look at the battery first. Good Luck
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Samsung YP-K3 MP3 Player
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
