Question about Teac Audio Players & Recorders
On/off button fails on teac model no.le3291hd but some 30 minutes plus the screen comes on!
Screen flickers on and off
If all your other HDMI inputs are out, then I recommend replacing the MAIN PCB
try the following web site: https://www.encompassparts.com/model/ZEN55UB9500UA/_/_/LG/55UB9500UA/55_INCH_UHD_4K_SMART_3D_LED_TV_W_WEBOS
page 4 lists a part number for the MAIN PCB,
HOWEVER, PLEASE MAKE SURE YOU USE YOUR COMPLETE MODEL NUMBER TO ASSURE THE CORRECT PART.
Apr 06, 2015 | LG 55UB9500 55" 4K Ultra HD TV with 2160p,...
Teac model LT-1 how to set clock
To set time on TEAC CD Receiver LT1
Press Memory/Clock Adjust button until numbers flash.
First display is 24/12 for choice. Change with >>> button.
Press Memory/Clock Adjust button again and Hours digit
flashes. Set with >>> or <<<.
Press Memory/Clock Adjust button again and Minute digit
In 12 hour mode "PM" will be displayed
Sep 23, 2012 | Teac LT-1 Clock Radio
Samsung rear projection tv does not come on
The power supply circuit board has probably gone bad. Repair cost for an in home service call by the major players would be about 450$ plus tax usually with a 90 day guarantee.
Mar 14, 2010 | Samsung HCN4226W 42" Rear Projection...
How to unlock the child lock
Most of the dishwasher in this series have an energy saver dry button. Hold this button in for four seconds and it should unlock the child safety lock. Does not work, try again for 30 seconds. Does not work. We have problem. If your model does not have an energy safer button, then type in the model number and you should be able to find the manual online and open the same to find out how to unlock the child safety lock. If all fails then you need an Electronic control board assembly, about $86 for your model, plus shipping from repair clinic.com. If you are at all handy, this is easy repair. Make sure you turn off the breaker or remove the fuse before you attempt any repairs.
Feb 08, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
I have a teac AG D8900 Digital Home Theater. My subwoofer seems to be dead. No lights come on the front of Sub Woofer even though it's plugged in. I tried changing outlets. The wire from speaker to...
I have the same-just talked to TEAC last week, if fuses(two 5 amp glass ones inside housing-just remove screws on back after un-plugging 120v power) on the LSR-1008 subwoofer are blown, it may be failed relays. I replaced my fuses, both blew w/in 5 seconds. Called TEAC today, relays are NOT available alone and are solder connected; however, complete new circuit board is plug in, part #APE000515-0001 at $47.69 plus shipping. Verify #s and price with TEAC, but now I must decide if it's important to keep this sub, or if another at around 60$ on Ebay is a better bet. Good luck!
Dec 26, 2008 | Teac AG-D8900 Receiver
Water filter initiation failed
Did you this steps?
Fill the tank with fresh water.
Let the filter soak for 30 minutes.
After 30 minutes discard the water in the tank and refill with fresh water.
Place a container under the spout.
Press the cup button in the middle.(Filter on, yes)
Press the cup button again.(press ok, initialisation)
The machine initialises the filter.
Press the cup button again.(done initialisation)
Then press MENU repeatly. When the "exit" message is displayed, press the cup button. In this way, the machine ends the start-up phase.
Best regards
/Mirran
Sep 24, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Changing the clock time
small button just right of LCD screen push watch push once for hour, puch tunener bar up or down for hour. push button to change to minutes, push tunerbar up or bown to change minutes
Aug 30, 2008 | Teac DC-D2831 CD Shelf System
Songsaver screen will not come up to allow to pick song?
My ExpressRC problem was operator error. I thought I was "Saving Songs" when I was really "Tune Selecting" therefore there was no songs in the Song Saver list to show. Problem solved.
Thanks!
Aug 05, 2008 | Delphi XpressRC XM Satellite Radio...
Teac AG V7700 Receiver problem powering up
I have a Teac ag-7700 and when I would try to power it on it would shut off. I did get it to turn on for about 10 minutes and then it shut off. Now when I try to power it on the light on volume dial stays lit but the LED does not light up and no sound through speakers.
Jul 30, 2008 | Teac AG-D8900 Receiver
Teac dvd recorder
In the control panel, go into "power options", there make sure the settings make sense(that there's no setting that shuts off the hard drive or hybernates the PC after a while its apparently not used). Failing electrolytic capacitors on the motherboard or a failing power supply sound like a potential avenue of investigation to me. You may be able to detect bad caps with no more than a visual inspection for bulges and/or leaking electrolyte. Try borrowing a power supply and see if it solves it. Does this happen with more then one DVD playing software? Hope you sort it out
May 13, 2006 | Teac 4X +/- DVD Recorder Kit DV W50D...
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
