Question about Brother Sewing Machines
I have a Brother xr-46. My needle clamp broke off. Ordered a new one but how do I reassemble it? Step by simple an explanation as possible for me. Thx!
Need to reassemble entire needle clamp. It broke off of the machine. I ordered a whole new one. Now I can't figure out what goes where. I have the thread guide, the needle clamp, the tiny screw, the tiny pin and the large screw. I know nothing. Pls be as basic as possible so I can follow the instruction. What goes where and in what order?
  • 473 Answers
If you google Brother XR 46 needle clamp you will find numerous pictures that might help.
Record 930 Electronic, breaks needles in reverse on buttonholes
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time
Dec 14, 2012 | Bernina Sewing Machines
My needle broke and a piece of metal fell out of machine
just adjust to needle in fix to strait in needle clamp hole it operate to needle strait to hole so needle do nt break but needle is best buy qualtity
Aug 31, 2008 | Brother XR-65t Mechanical Sewing Machine
Zigzag stitch problems on brothers pc-420 sewing machine
Sewing machine skips stitches
1.needle inserted incorrectly
flat side of the needle faces the shaft
round needle
groove of needle faces away from the shaft
Correct needle insertion is mandatory for proper use
Raise the needle bar to the highest point, then loosen the clamp screw to remove the needle.
Place the new needle in the clamp with the flat side of the needle facing the back of the machine.
If round needle--the groove in the needle faces away from the shaft
Push needle all the way up to the stop or as far as it will go.
3.possible bent needle--lay needle on flat surface & roll needle over, if the needle does not roll good -replace
4.blunt needle point--needle makes a popping sound when needle penetrates the fabric--replace needle
5.needle not all the way up in needle holder--loosen needle clamp screw & push the needle up until it stops then tighten screw
6.incorrect threading--one step missed in sequence of threading can cause machine to skip stitches
7.wrong needle in machine--check instruction manual--some machines can use a generic needle with no problem
8.size of needle & thread & the fabric are not compatable
Mar 30, 2012 | Brother PC-420
I have a Brother XR-65. The needle bar fell out as I was sewing. I need a repair manual or some instruction on how to secure the needle bar in the machine. I have the bar itself and a pin sized piece of...
This was happening to me also - you have to tighten a different screw than the one that holds the needle in.
My husband thought the screw was missing - it is actually a plastic screw with a hole in it for a tiny allen wrench.
You can see it in this picture also
If you look at the photo of the screw I attached, you can zoom in and see it has a hexagonal hole.
It is above the flat head needle clamp screw (the one that holds the needle in)
It is REALLY annoying that this screw is mentioned nowhere in the manual, and the hex allen wrench is not included with the machine.
Kind of an important little detail, considering it holds the needle assembly together... you'd think that they would have told you about it.
Sep 09, 2011 | Brother Sewing Machines
The thing you put the needle in and their is a wire thing that goes in there...that piece fell out and needle won't stay's a brother XR-35
What fell out was the needle clamp gib - a small wedge-like part that presses on the needle to hold in place.
You may be able to get it repaired or replaced.
Search online for parts, or ask a sewing machine service tech for an estimate for having the machine repaired.
Mar 19, 2010 | Sewing Machines
this sounds like the needle guard it is usually held on by the same screw that holds the needle clamp it should fit so that it comes across the needle at the front to stop your fingers being sown but not interfere with the needle try turning by hand before turning back on.
Jun 05, 2009 | Brother XR-65t Mechanical Sewing Machine
Need manuel for XR-46. I am in Kuwait
No, the problem is still not solved because I do not own a XR-65T. I own a XR-46 and all I need is a manual???
Apr 12, 2009 | Brother XR-65t Mechanical Sewing Machine
My needle broke. How do I fix it?
hi! there, first you have to raise needle bar to its highest position by turning the handwheel toward you.hold the broken needle itmay drop after loosen broken needle.,loosen the needle clamp screw using by a srcewdriver pull out broken needle.take new needle holding the needle with the flat side away from you.slip the needle into the needle bar groove.make certain it is up as far as it can go tigthen the needle clamp screw with a screwdriver,aas shown1b71a34.jpgregards
Mar 28, 2009 | Euro-Pro Shark 60 - 384
Sewing Machines Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
