Question about Sony Televison & Video
Turn on and they blink red four times repeatedly. than shut off.
They were paired with a new transceiver model ZF-370 which is connected to my digital Sony TV, and worked fine except to much bass. Now when I turn them on they blink red 4 times repeatedly. and shut off.
  • 23 Answers
SOURCE: Sony SXRD Projection TV
This is a fan issue, most likely the large fan in the rear, lower left (from the back)...
Here's the fix, I promise, it's EASY........
Ok, I think I have the answer for the BIG FAN failure. I recently did a similar fix on the spindle of an xbox 360 and it is identical. Ok, this is an EXTREMELY EASY FIX...
Open the back of the tv, locate the large fan (on the lower left on the back of the set.) unscrew the screen and remove the fan.
Once the fan is removed, you will see the side with the model number and the other side is totally open.
On the open side, pull...
The fan will come off, into your hand, it is only held by magnets...
You will notice a spindle on the fan and the other side has the magnets and the hole where the spindle came from (this is the fan motor).
Clean both the spindle and the hole (motor) with a q-tip. The hole is smaller than the q-tip, but do the best you can to remove the old lubricant.
Get a bit of WD40 and lubricate the spindle and spray a touch in the hole.
Put them together, reconnect your fan, test it on startup and thank
Posted on Oct 01, 2008
  • 61 Answers
SOURCE: Sony Wega 40" TV will not turn on, standby light blinks 6 times repeatedly
Hello,For model KV-40XBR800,
Pls check following area.
Low HV Shutdown:
On the D Board.
Check IC8004/pin 7 should be 7.4v.
Check IC8006/pin 2 should be 2.5v if lower will trigger shutdown by causing pin 1 to turn on.
Check IC8006/pin 3 reference voltage 2.2v.
IC8006/pin 1 normally at 0v. If high
turns D5007 ON which turns the latch circuit Q6532,
Q6530, and Q6527 ON and turns the AC relay RY6501 OFF.
And NOTE: 6 blinks also can be Low B+ protection.
Unregulated 7.5 v from the power supply to 5v reg IC504 on the A Board. 5v to M Board Q2314
to CPU IC2300/pin 43. If 5v missing set will shutdown with 6 blinks.
Good Luck
Posted on Oct 15, 2008
  • 36 Answers
SOURCE: Sony 60" wega kdsr50xbr1 blinks red 4 times
Please check Fans are running in your DLP Sony TV as 4 times blinks shows that any one of four fans is stopped or not running.
Posted on Feb 10, 2009
  • 239 Answers
SOURCE: Sony KDS-60A2000 projection TV: power led blinks 4 times
the projector bulb has gone out you need to replace it.
hope this helped
please rate well
Posted on Mar 04, 2009
  • 563 Answers
SOURCE: Red Light Blinks 4 straight imes
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. The 4 red blinks is similar to an error code. It represents what's wrong with the TV to a service tech who knows how to repair it. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need a power supply module. If the problem is one of the video circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jun 18, 2009
The red light on my mouse keeps on blinking
Here's a guide;
What do the battery lights mean on my mouse? Some keyboard and mouse models feature a battery light that shows the current status of the batteries. The following table describes the different lights and states.
Device Model Status Single long green blink Rechargeable Batteries are good. This occurs when batteries are first installed or every time that the device is turned on. Slow green blink Rechargeable Device is docked in the charging station and is charging properly. Steady green Rechargeable Device is docked in the charging station and does not need additional charging. Steady green Presenter Mouse (Japanese version) Laser pointer is on. Red/green blink Wireless Device is discoverable (trying to connect to the transceiver). Slow red blink Non-rechargeable Batteries are low and need to be replaced. Slow red blink Rechargeable Batteries are low and need recharging. Fast red blink Rechargeable Device is docked in the charging station, but there is a charging error.
Reasons for errors: The wrong type of battery is installed; the battery or batteries are missing; or the battery connection is bad.
Solutions: Make sure that the correct battery or batteries are installed, and are installed correctly. If necessary, remove the batteries, wipe them with a clean cloth, and reinsert them. Steady red Presenter Mouse (Standard version) Laser pointer is on.
Oct 18, 2014 | Computers & Internet
It stays on at all times and can not be connected to my htc 4g
Try to put your headset in pairing mode, prior to trying to pair it with your phone. In order to do it, begin with it turned off. Then, if it is the first time it is being paired, just by turning it on (i.e. by pressing and holding the call button for some 2 seconds), it should enter the pairing mode. Otherwise, keep holding the call button past the turning on phase (a total of some 8 seconds), until its indicator light is flashing in red and blue, thus indicating it is in pairing mode. Either way, within the next 2 minutes, make your phone's bluetooth application search for new devices. After a little while, your headset should appear on-screen. Select it and make it connect. If a pairing code (or passkey, or PIN) is requested, enter '0000' (four zeros). If the pairing process is successful, your headset should enter the stand-by mode. Your phone should also indicate that the pairing process has been successful. Otherwise, please, turn your headset off and repeat the pairing process all over again.
By the way, if its user guide happens to be missing, feel free to download it from this location.
Anyway, please, let me know if I can help you any further.
Regards, Carlos
Mar 14, 2011 | Plantronics Explorer 220 Bluetooth Headset...
I have a 95 gmc 350 half ton and my check engine light comes on when I am on the highway and goes off when I drive at lower speeds. I am also getting poor gas mileage.
Most likely a bad egr valve. Take a paper clip. Jump pins A to B at the 12 pin diagnostic connector. (Top right pair wires in the connector - or - Lower left pair of wires depending on orientation) Turn key on. Count the "blinks" of the check engine light. All codes are 2-digit. Short blinks are the ones digit and long blinks are the tens digit. EACH CODE REPEATS 3 TIMES AND THE GOES TO THE NEXT CODE SET. You will get code "12" first..."b l i n k- blink-blink" It will repeat 3 times. I bet the next code will be "32" EGR system malfunction
Nov 22, 2009 | 1995 GMC Sierra
Sony KDF-50E2000 shuts down and blinks repeatedly twice.
The 2 blink error is a temperature error and the 6 blink error is a thermal fuse error. You may need to unplug the set and get you a can of canned air, take off the back lower cover and blow out all of the fans inside the set.
Oct 20, 2009 | Sony KDF-50E2000 50" HDTV
My SXRD 60" Sony LCD TV turns on. green light flashes about 6 times, then solid green. But just as screen starts to light up, turns off, solid green light turns red and blinks red four times, then stops. a...
Perhaps it needs the bulb, but there is also a good possibility that the lamp fan is getting clogged and shutting down the set. This is NOT the fan you see in the back, instead, it is above the lamp, and is a small blower-type fan, that tends to clog with dust. You CAN check this, when you open the lamp door,you can see the blower wheel, and if it is all dusty, it needs to be cleaned out--but do NOT just blow it out, or you might clog the engine!! It needs to be removed, and cleaned out of the set.
But first...if the blower is not too dirty...try another lamp.
Oct 10, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Battery light green, then flashes four times red, repeats
remove the battery
clean the connecting ends of ur laptop & battery,
plug it back in & then start it...
Aug 27, 2009 | Dell Latitude D600 Notebook
How can i reactivate my blueant blue tooth on my motorola ic902?
Try following the below instructions, if you haven't already tried them..
First Time Pairing to your Bluetooth Mobile Phone
When you turn ON your Supertooth Light for the first time, it will automatically go into Pairing mode ready to be found by devices in Bluetooth searches. This will be the case until you have successfully paired a phone. If you have already paired a
phone, please go to the next section.
1. Power ON your Supertooth Light. The Bluetooth Indicator (3) will turn a blinking
red/blue, The kit is now in pairing mode.
2. Go to Point 3 in the next section, “Pairing to your Bluetooth Mobile phone”
Pair the SUPERTOOTH LIGHT to your Bluetooth mobile phone to create a “Pairing”
link, or audio connection between the two. This has to be only done once when first connecting each new phone.
1. From OFF, Press and Hold the Accept Button (1).
2. While holding the Accept Button (1), switch the kit on (Press-and-release the
Microphone Shaft (5)).
3. The Bluetooth Indicator (3) will turn a blinking red/blue, when you see
this, release the Accept Button (1). The kit is now in pairing mode.
4. While the kit is in pairing mode, access the Bluetooth menu of your phone. Turn on the Bluetooth function then execute a Bluetooth search, or discover. (See your phone’s manual for specific instructions.)
5. When the phone displays the list of Bluetooth devices, select ST LIGHT.
6. When the phone asks for the password, enter 0000 and press Ok.
7. Set the ST LIGHT as a trusted/authorized device, if this is option in your phone.
Important Note: The kit is now paired. Most phones automatically connect to the
kit after pairing. With some phones you need to connect manually after pairing.
Go back to Bluetooth > Paired devices > highlight ST LIGHT > press
Options > then press Connect.
When connected you may see the Bluetooth Symbol on your phone change
slightly, either inverting in color or changing to a headset or car symbol. The kit
is now ready to use.
Repeat steps 1 -7 above for each new phone you want to use with the
Supertooth Light.
This was copied from the user manual, which you may or may not have already.. Here's a link to a .pdf file of the manual which you can also save to your computer:
Hope this helps :)
Season's Greetings!
Chris (ziraffa)
Dec 22, 2008 | Blueant Supertooth Light Bluetooth Speaker...
Free Pulse
The following procedure will re-establish the communication link between the Headphones and the Wireless adapter, this is called "pairing". Before you start please make sure both the headphones and the wireless adapter are fully charged and turned off.
Note: The headphones and the wireless adapter come pre-paired from the factory.
1. Press and hold the power button on the headphones. See Figure 1.
Figure 1
2. Continue to hold the button down until the LED starts flashing red/blue in an alternating pattern. Release the button when the LED starts flashing red/blue. See Figure 2.
Figure 2
3. Once the headphones LED is flashing red/blue, press and hold the power button on the wireless adapter. See Figure 3.
Figure 3
4. Hold down the button until the LED starts flashing red/blue in an alternating patter. The LED will blink blue, then turn off for a few seconds then blink red/blue. Release the button when the LED starts flashing red/blue. See Figure 4.
Figure 4
5. Once both the headphones LED and the adapter LED is blinking red/blue, press the volume up button once on the headphones. See Figure 5.
Figure 5
Once the headphones is paired with the adapter, the LED on the headphones will blink blue once every two seconds. See Figure 6.
Figure 6
When the adapter is paired the LED will be solid blue. See Figure 7.
Figure 7
The adapter may continue to blink red/blue for a few seconds even after the headphones LED starting blinking blue. This is normal; the adapter may take a few additional seconds before the LED turn solid blue.
Once the headphones and the adapter are paired, it is not necessary to pair them again even if the batteries on both units are completely drained.
Additional Note: Repeated pairing will not improve the sound quality or give the headphones and the adapter a cleaner connection.
Mar 11, 2008 | Logitech FreePulse Wireless Consumer...
Televison & Video Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
