How do I find My List since My Queue no longer exists
How can I rid away of 5.5.0 undisclosed-recipients:; that appears to my Outlook all the time?
You will get a 5.5.0 error if the account you are emailing no longer exists. The undisclosed-recipients indicates to me that you are emailing a list of people. In order to stop getting this message you need to email everybody on your mailing list individually and see which ones are no longer valid and then remove them from your list. The only way to stop getting this error is to keep your mailing list completely up to date.
May 20, 2016 | Microsoft Office Outlook 2007: Windows
How do I get my list of movies on my Netflix queue?
Marrian, Trouble with Netflix,Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
See what next
10 Common Netflix Problems Fixes
How to Troubleshoot Commonly Encountered Issues in Netflix
https://www.google.ca/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=netflix+programs
Jan 30, 2015 | Netflix
HP DeskJet 6540 print job stuck in queue
If your computer has a Windows OS, you can clear the queue manually when the job will not delete it from the print queue list.
With Windows Vista or Windows 7, you will need to run the command prompt as Administrator. Click Start > All Programs > Accessories > Command Prompt (for Vista or Win7, right click here and choose Run as Administrator). At the prompt, type "net spooler stop" without the quotes followed by pressing Enter. Next type "net spooler start" (again without the quotes followed by Enter). Restart the computer then take a coffee break before trying to print again. If you don't type the start command, this reset takes even longer after the computer is restarted.
Note if you use a Fax machine with the computer, you may need to confirm that this will stop the Fax service as well.
If the problem persists, make sure that the USB cable is currently connected to both the printer and the computer. You may want to change ports and make sure that other devices work in the USB ports. (Some computers have an option to disable some USB ports.)
If you have a different OS, please add a comment with the OS on your computer. I hope this helps.
Apr 14, 2012 | HP DeskJet 6540 InkJet Printer
When I try to print from my PC the printer doesn't respond at all even though the cable is connected on both ends and the printer is turned on. Worked fine the day before.
I assume you are using a PC- All printers have a list of pending jobs refered to as the print "queue"- it should open if you double click on the default ptinter icon in the printer list- it sounds to me like your print Queue has been paused somehow and all the print jobs are being "held" until you tell the queue to restart printing
Jun 01, 2010 | Epson Stylus CX7800 All-In-One InkJet...
I have a document in the printer queue that will not delete. How can I get rid of this document
If you can not get it out of the queue and you have tried turning the printer off and back on, the only thing you can do is restart the computer. Once you restart, the printer should no longer show jobs in queue. Hope this helps!
Mar 16, 2010 | Epson Stylus Photo R200 InkJet Printer
My 5 in 1 printer is saying no cartridge when I just replaced it and when I do get it to print it's not printing that good at all kind of gray like it's out of ink, it has a new cartridge
  • Click open START then CONTROL PANEL then PRINTERS AND FAXES
  • If asked, click the link that says view or modify existing printers
  • You should get to a window that shows a list of printers that are installed on your computer
  • Look for the printer icon with a tiny little checkmark in a black circle to the upper right (see image below). This is your default printer, that is, it's the one that prints if you don't manually select a specific printer. defprint.jpg
    Note how the checkmark indicates that the Brother HL-2040 Series is my default printer
  • In most cases, this is the printer you are having trouble with, but the following procedure can be applied to any printer on your system.
  • Double click open your default printer to view the print queue printqueue.jpg
    Note that there are two documents waiting to print in my print queue
  • If the print queue is empty, skip the next step
  • Click and pull down the PRINTER menu from the top of the print queue and select CANCEL ALL DOCUMENTS. This will delete anything that's stuck in the queue cancelall.jpg
    After clicking CANCEL ALL DOCUMENTS, it may take a minute or two for the queue to completely clear
  • Click and pull down the PRINTER menu from the top of the print queue. If there is a line item that says USE PRINTER OFFLINE and there is a checkmark to the left of it, click it once, otherwise, click CLOSE.
  • Now go to the printer and power it off, wait a few seconds and power it back on.
If these steps haven't solved your printing problem, then you probably need help
Oct 01, 2009 | Brother Multi-Function Center MFC-240C...
Hanging print queue on Canon iR2200-3300
my ir2200-3300 canon printer m/c ip adders change automatically in 2-3 days pl. solution my problem?my email ID sudesh_trivedi@yahoo.co.in
Nov 20, 2008 | Office Equipment & Supplies
HP Deskjet F380 - NOT PRINTING - only scanning
Solution:-
Step one: - Restart the computer
Click Start and click Shut Down.
Click Restart or select Restart from the menu.
Click OK.
After the computer restarts, double-click the Printer icon in the system tray located at the bottom, right of the computer. The print queue opens. If no documents appear in the print queue, the issue is resolved.
If the issue continues, proceed to the next step.
Step two: - Check the product cable
Disconnect the USB cable from the product and from the computer.
Wait 5 to 6 seconds.
Reconnect the USB cable to the product and computer.
After the product is connected to the computer, the product should start printing the jobs in the print queue.
Step three: - Determine whether the product is paused or offline
Click Start and click Printers and Faxes. The Printers and Faxes window appears.
In the Printers and Faxes window, right-click the product icon and click Open . The Printers folder opens.
On the menu bar, click Printer.
Make sure that the Pause Printing and Use Printer Offline options are not selected. If a check mark appears next to either option, click to remove it.
If the menu includes Use Printer Online , click that option.
If neither Pause Printing nor Use Printer Offline is selected, press Esc to leave the menu without making changes.
Step four: - Stop the print queue
Double-click Macintosh HD.
Double-click the Application/Utilities folder.
Open the Print Setup Utility folder.
Double-click the appropriate product in the product list to open the print queue.
Click Start Jobs.
Step five: - Delete the print jobs
Click a print job and click the Delete icon. Repeat the steps for all the jobs in the print queue.
Click Start Jobs.
When the print queue is empty, click Start Jobs.
Try the print job again.
Step six: - Remove and re-add the product to the printer list
Select the appropriate product.
Click the red X to delete the product from the computer.
Disconnect the USB or Ethernet cable from the product.
Close all open windows and restart the computer.
After the computer is restarted, double-click Macintosh HD .
Reconnect the USB or Ethernet cable to the product.
If the product is not automatically added, click Add.
Select the product to add and click the Add button. After a few seconds, the product appears in the printer list. Try the print job again.
Jul 12, 2008 | HP DeskJet F380 All-In-One Printer
Can not clear the print que
Follow these steps to resolve the issue. Step one: Delete the print queue Open Print Setup Utility located in the Application/Utilities folder. Double-click your printer in the printer list to open the print queue. Click the Stop Jobs icon. Click to select the document, and then click the Delete icon. Repeat the steps for all the jobs in the print queue. When the print queue is empty, click the Start Jobs icon. A message appears: No Jobs Printing . This indicates that the queue is clear. When you have cleared the queue, retry your print job. If the procedure has not resolved the issue, repeat steps 3 and 4. If the issue still persists, continue to the next step. Step two: Remove the printer from the list Open Print Setup Utility , located in the Application/Utilities folder. Click to select the Photosmart icon. Click the red X to delete the printer from your system. Close all open windows, and restart your computer. Step three: Add the printer to the list Open Print Setup Utility located in the Application/Utilities folder. Click Add . Select the printer that you want to add, and click the Add button. After a few seconds, your printer appears in the printer list, and your printer is ready to print.
Sep 13, 2007 | HP PSC 1410v All-in-One Printer
jasbo
jasbo
