Question about PRINTER Office Equipment & Supplies
Why is my hp4620 printer printing blank pages? It has new ink, cleaned print heads, was plugged an unplugged, rebooted. Help please.
SOURCE: Canon PIXMA iP4000
If you look on the net this problem is very common. There is a good idea that seems to have helped heaps of people on using WD-40. Worth checking it out
Posted on Mar 27, 2008
SOURCE: Printer doesn't print even with new ink cartridges.
Take out the Cartridge & get a new one if the problem persists then get the printer software reinstalled & if still it is not printing then clean up the cartridge head with cotton swabs dipped in hot water!
This should clean the head & black will be on paper
If still its not working then there's some problem in the copper contact surface in the printer on the cradle so get a new Printer.
Posted on May 16, 2008
  • 1031 Answers
turn the printer i turned on and Press the cleaning button ,. Cleaning takes about two minutes, the printer makes some noise when it finishes you run a nozzle check for print quality and reset the cleaning cycle.
load paper . go to the printer menu as follows: click Control Panel, and then double-click Printers. Select the Epson printer if have more than one printer is installed. Click File, click Properties, click the Utility tab, then click the Nozzle Check icon.
The printer will print a Nozzle Check pattern in black, and in cyan, magenta, and yellow. Each staggered horizontal and straight vertical line should be complete, with no gaps in the dot pattern. If any dots are missing, clean the head again.
If your software is different, and does not have these options, you can do it this way:
1. Same as above.
2. Same as above.
Turn off printer and computer. Disconnect interface cable from printer. Load paper. Hold down the load/eject button and press the power button to turn on the printer. Release both buttons.
3 Same as above.
4 Turn off printer and reconnect the interface
Posted on May 17, 2008
  • 1447 Answers
SOURCE: printing blank pages
You might be having a clogged nozzles, if you want you can try to dismantle and check on the nozzles, heres the link on how to check it just click HERE
Pls rate as fixya if it helps. Thanks!!
Posted on Jun 17, 2008
SOURCE: canon bjc-85 printer doesn't print anymore
My 1st brand new cartridge and ink tanks did not work. I took them out and put in my other new ink cartridge and ink tanks, and now it works fine.
Posted on Aug 06, 2008
Hp4620 wont copy pages
Hi try removing the print head, run it under the tap, dry, then replace the head and retry
Aug 12, 2014 | HP Officejet 4620 e-All-in-One Printer,...
I just replaced my ink cartridge and now it's printing blank pages. I've unplugged & restarted the printer however the problem still exists. The printer says there is an "alignment...
Run a few "print-head-cleaning" cycles, to get the black ink flowing through the ink-jets inside the print-head.
Some printers REQUIRE an "alignment" step every time you change the ink-cartridges.
It only takes a few minutes, and it prints one or two pages of paper.
Jun 20, 2011 | Dell 924 All-in-One InkJet Printer
My 5500 printer is printing blank pages - can you help?
Does the ink cartridges are new or old? How long did you stop printing? Because if you stop printing for a very long time, the ink dries up and you need a little cleaning for the print head. Remove the ink cartridges and rub the print head into a plain paper with alcohol until ink flows and the run the cleaning maintenance like print alignment or print nozzle.
Please let me know if you need more help.
Mar 03, 2011 | Kodak EASYSHARE 5500 All-In-One InkJet...
After cleaning/maintenance, pages are still blank.
If you have just bought new carts (ink) and installed them into the printer and there is blank pages. and the printer is acting like its printing (moving from left to right) and sending paper out then i would say 99.9% it is defintally the head. On the printers that have the head built in and you insert your carts (ink) into the head and you don't print but very so often this is a common problem with ink printers the head gets clogged. If you are attached to your pinter you can take it to a print shop and have them clean the head (they have to remove it from the printer)
When buy a printer if you dont print alot i always suggust to get a printer where the head is built into the cart (ink) like hp they are more expensive to repalce the ink but you get a new head every time :)
Hope this helps
Apr 21, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Canon i850 printing but pages are blank
I had the same problem after changing the black ink cartridge. I went to Control Panel of my computer, chose Printers, then Canon Inkjet. Chose Properties, then Maintenance, the Deep Cleaning. NOW my printer is working!!
Jun 16, 2009 | Canon i850 InkJet Photo Printer
Please help me, my epson inkjet all in one printing just blank blank blank
Epson printers will not accept continuous ink cartridges. That is why you are getting blank pages. I recommend just buying the ink cartridge as you need them.
Good Luck
Jan 05, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Printer will not print ,paper comes out blank
Put new in cartridges in printer.
Page prints out blank.
Have cleaned the print heads 3 times.
Need help!
Nov 16, 2008 | Epson Stylus C66 Inkjet Printer
Cx6600 printer problem
if you left your printer for two weeks or more without using, the print heads may be stuffiness. In this case (aparently yours cases) you must take your printer to a authorized service, they will can clean (with a proper fluid) or replace the ink heads, if cleaning is not possible.
Mar 16, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Printing inkless printing
Gecko17 How old is your cartridge? is there is enought ink to print your document? If so then... Take out the cartridge carefully from your printer without touching any contact points, heads etc. Clean the head's of your printer cartridge carefully by using head cleaner fluid. After that, reinstall your cartrige and please try to print again. If this deosn't solve your problems, you may need to replace your cartridge with new one. thanks
Aug 30, 2007 | Lexmark Z600 InkJet Printer
29 people viewed this question
Top PRINTER Office Equipment & Supplies Experts
Roger Knight
Roger Knight
Level 1 Expert
R Daniel Wolfe
 Andrew Henderson
Andrew Henderson
Are you a PRINTER Office Equipment and Supply Expert? Answer questions, earn points and help others
