Finding my queue - Office Equipment & Supplies
  • Brett Duxbury
    Brett Duxbury Jan 02, 2017
    Hi charles thorne, we want to help you with your question, but weneed more information from you. Can you please add details in the comment box?
    operating system ?
    should just click on printer icon if windows in box at bottom right hand side of desktop screen.
    If stuff stuck in queue that won't print
    control panel - services (may be able to search for services in control panel / settings)
    stop spooler service
    then restart spooler service
Brother HL2130 press print and i want to stop the printing how to i pause or cancel printing do i just open the lid or can't be cancelled i tried to search via settings but unable to locate thankyou
most likely it has gone into the printer's memory.
Turn off printer at power point.
CHECK COMPUTER FOR PRINTER QUEUE
Also check computer for printers icon on right bottom of screen and click on it to open the printer queue.
Then cancel print job if in Windows operating system's printer pool.
Turn printer back on at power point
If you can't find the printer queue go to printer settings in the control panel of the p.c and find the printer queue.
If this is not possible for you to find.
Go to services (in control panel) if windows operating system and find the print spooler service and restart the service .
May 25, 2017 | Brother Office Equipment & Supplies
Canon pixma mp610 cant delete the printing queue or print
This is not the fault of the printer but windows. Open the Control Panel, select Devices & Printers, find your printer, click on it, select Delete Print Queue. Problem is fixed.
Jan 07, 2013 | Canon PIXMA MP610 InkJet Printer
I'm trying to add movies to my queue. i can't find the add button!!!! can you helo?!! ...
The reason you are having trouble adding movies to your instant queue is because a limited amount of movies can be viewed through instant queue. The new really popular titles generally aren't on there. In fact the majority of movies you want to watch are most likely not on there. You can look at this list to see the most popular movies that are available to be watch on instant queue.
http://www.alwayswatching.net/features/125-great-movies-tv-shows-netflix-watch-instantly
I hope this helped!
May 16, 2011 | Computers & Internet
How to access print queue
You can find the print queue going to Start-Settings-Printer and Faxes, Open printer and faxes by clicking and You will find the printers installed. Select your printer probably the one which has tick mark on it ( default printer) double click to open and see the files in queue. You can delete the queue if printing stucked.
Other way to delete the printing queue if not getting deleted from the above method is to go to start-.>run type "services.msc"
search for print spooler service in the rights side pane, right click the service and stop it. Now again go to Start->run type
"spool" and hit enter. It will open up folder for you, double click on PRINTER folder and delete all the files in that folder. This will clear up the queue from printer. After deleting all files, go to again follow the same process to start the print spooler service. Go to start->run-> type "Services.msc" hit enter, on the right side pane search for printer spooler service, right click and start the service.
Hope this helps
May 19, 2010 | Microsoft Office Home and Student 2007...
Cannot find "printer queue" page
install a new software and check your cable
Oct 21, 2009 | Epson STYLUS CX3900 All-In-One InkJet...
Print job disappears withouth printing in Quickbooks
Go to the printers folder, right click the printer and chose properties. Under properties go to the advanced tab and check off print directly to this printer. I work with HP and find this solves the problem of printer 95% of the time
Jun 19, 2009 | Office Equipment & Supplies
Printer queue is blocked
Easy, but it will reset all print jobs.
Goto Control Panels.
Open Administration Tools
Open Services
Find Printer Spooler
-Right click and choose restart
Nov 13, 2007 | HP DeskJet 9800 InkJet Printer
27 people viewed this question
k24674
jasbo
jasbo
