Question about XM Radio Audio Players & Recorders
How do I use an aux source in connection with the alarm function of my Bose Clock Radio?
I want to use my XM radio as the music source for the click radio
  • 281 Answers
SOURCE: Timex Indiglo Clock/Radio/CD alarm clock
whats the brand and the informations about it ?
Posted on Mar 03, 2008
SOURCE: bose radio won't turn on
My Bose wave radio (w/cd ) was purchased in 1999, it was working fine untill it quit. Power is gone. What could be the cause and how could i fix it or can it still be fixed?
Posted on Nov 08, 2008
  • 16 Answers
SOURCE: Instructions; TIMEX Alarm Clock Radio w/CD Player & Nature Sounds
Go to timexaudio.com, select SUPPORT, then select PRODUCT MANUALS.
Posted on Feb 22, 2009
SOURCE: operating instructions for timex t311t radio/alarm clock
You can acces a PDF file of the manual at the following site: http://timexaudio.com/media/uploads/product/files/T311IB57574_35.pdf
Posted on Mar 04, 2009
SOURCE: Instructions to 'science museum' radio controlled alarm clock
press the alarm button (so the alarm time is on the screen) then the + button. do the same to deactivate the alarm.
it took me forever to work this out after losing my instructions, feel a bit of an idiot now it seems so simple
Posted on Mar 10, 2010
I have a ten year old bose wave/radio/cd player. Sound is great but want to play music from my ipod through the bose. my ipod plays in car using aux cable but this does not have same result when...
Anything that has a headphone output can be adapted to feed an RCA cable pair for standard stereo to any audio device with a standard RCA input (except PHONO). Get a cable like the one described here: http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
and connect it into any available analog input EXCEPT "Phono".
Jun 17, 2011 | Bose Wave Radio
Is there a way that I can play music from my computer windows media center through my bose wave system?
You can obtain a cable that has a 3.5mm stereo plug on one end and two(red, white) RCA plugs on the other end and hook them into an AUX input on the wave radio
Dec 27, 2010 | Bose Wave Radio
Can you connect two Bose Wave radios together for more sound volume?
There are several types of Bose Wave Radios - the one pictured (the others likely do, too) have "Line Out" and "Aux In" jacks. Each consists of a Left and Right pair of RCA type jacks. Simply connect the "Line Out" jacks of one of the radios to the "Aux In" jacks of the other. Select the "Aux" source of the radio that has the cable connected to the Aux In jacks. Whatever is playing on the main radio (CD, Tuner, or other input) will be heard on the second radio - if the Aux source is selected.
Please rate this reply if it was found to be helpful - good luck!
Jul 03, 2010 | Bose Wave Radio
My 10+ year old Bose wave radio/alarm on fritz
Replace the 3 AA batteries that maintain memory & backup alarm function. That just may do the trick.
Apr 10, 2010 | Bose Wave Radio
The radio and alarm stopped working. It is about 10 years old
A Bose Wave Radio with a problem? I say blame Paul Harvey! :P
No seriously.. Does the radio work in manual mode, or does it not work at all? On most devices such as this, this, the clock and alarm function is usually found on it's own "clock board", and there is no real practical way to fix the board. The board that controls the **** will probably have to be replaced. It may very well be that a failure of the clock circuit may be causing the radio to not work either because the radio circuitry may only be getting power when the clock enabled it to - either manually, or when the alarm is activated.
To repair it, I recommend calling SOT Electronics in Concord California. Here is a link that should give you all the info you need.
http://www.sotelectronics.com/Bose/index.htm
I hope this helps!
Oct 25, 2009 | Bose Wave Radio
My alarm doesn't go off
You must try to reset the microprocessor in the Clock/Radio. To do this you must unplug the Clock/Radio from the A/C power source.Then remove the Internal battery(CR2430). Let the Clock/Radio set without a power source for about 3 hours. This will discharge the microprocessor and reset it. After you have discharged the microprocessor,you can reinstall the internal battery. Connect the Clock/Radio to the A/C power source. The Clock/Radio's Functions should have returned to normal function. If the Clock/Radio did not return to normal function, you must replace the internal battery and again let the microprocessor discharge. After the microprocessor has discharged,put in the new internal battery and reconnect the Clock/Radio to the A/C power source. The Clock/Radio should have returned to normal function. If you are still having problem with the functions of the Clock/Radio, You will have to call Emerson Customer Support. The telephone number for the Emerson customer support is 1-800-909-1240. you can call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance. I hope this information help you with your problems with the Clock/Radio. Thank you for using FixYa and have a nice day!
Jun 09, 2009 | Emerson Smartset Clock Radio
Bose radio
I want to know if the alarm can come on through aux?
Dec 24, 2007 | Bose Wave Radio
How do I make my alarm on my Bose Wave Radio play the FM Radio instead of the usual beeping noise?
When you choose the alarm button on the back row of buttons in the middle you get 4 options, no alarm, beeping, music, beeping & music. These are represented by icons on your front panel the note and the ))) sign.
Regards
Derek
Dec 20, 2007 | Bose Wave Radio
Alarm not working
Sorry it took so long to reply to your problem.You must try to reset the Clock/Radio's microprocessor. To do this you must disconnect the Clock/Radio from the A/C power source and remove the internal battery. Let the Clock/Radio set without any power source for about 3 hours. This should completely drain all the power from the microprocessor. After this is done, reinsert the internal battery and plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal. If they do not return to normal. Unplug the Clock/Radio from the A/C power source and remove the internal battery. Replace the internal Battery (CR2430). Let the Clock/Radio again drain all the power from the microprocessor. Insert the new battery and Plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal.If you should still be having problem with the functions of the Clock/Radio, you will need to call Emerson Customer Support. The telephone number for Emerson Customer Support is 1-800-909-1240. Call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance with your problem. I hope this information help you with your problem. Thank you for using FixYa and have a nice day!
Oct 26, 2007 | Emerson Smartset Clock Radio
24 people viewed this question
Top XM Radio Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a XM Radio Audio Player and Recorder Expert? Answer questions, earn points and help others
