Question about Home
How to over ride radio controlled La Crosse WWVB
SOURCE: La Crosse atomic clock model #WT-3143
don't push any buttons at all untill the clock has at least 15 minutes to communicate with the transmitter.
Posted on Feb 17, 2008
SOURCE: setting the altimeter on the la crosse xg-55
altitude changes depending on pressure; because you are along ocean, you experience it more than usual.
M problem is that temperature remains higher than normal one (30°C), can you solve it ?
Posted on Apr 04, 2009
SOURCE: LA CROSSE RADIO CONTROLLED WATCH
How do I reset watch after changing battery?
Posted on Oct 11, 2009
  • 2501 Answers
SOURCE: How to set a La Crosse radio controlled watch
Go to http://www.lacrossetechnology.com/support/setup.php and choose your watch from the drop down menu.
Unfortunately they do not have any instructions but there is a contact address there where you can get help.
Posted on May 09, 2010
cadillac02
  • 318 Answers
SOURCE: My WWVB radio controlled quartz
these really aren't atomic clocks and are set at the factory. It receives, it's LF signal out of Colorado and should correct itself. If not contact the manufacturer.
Posted on Jan 12, 2011
Cannot set time
WWVB Radio Controlled Clocks
www.nist.gov/.../radioclo...
National Institute of Standards and TechnologyFeb 11, 2010 - To find out more about WWVB radio controlled clocks, please ... Before it does so, it applies a time zone correction, based on the time zone setting that you ...your radio controlled clock, but we cannot provide technical support ...
[PDF]FM/AM Clock Radio - Sony
https://docs.sony.com/release/ICFC218_US.pdf Sony CorporationAutomatic time set - When you plug the clock in ... The radio or buzzer alarm does not sound at the ..... The alarm time setting cannot be changed if ALARM.
[PDF]Atomic Analog Wall Clock - La Crosse Technology
https://www.lacrossetechnology.com/.../Generic_Headway_Manual_050...
clock is synchronizing to the WWVB signal and once the radio signal is decoded, the hands will ... trouble free. If the clock receives a clear time signal, it will set itself perfectly. ... A: No, the clock cannot work with a booster antenna. Opening the ...
ICF-218 Sony Alarm Clock - YouTube
? 1:50
https://www.youtube.com/watch?v=XTQ8zEMMNq8
Aug 4, 2012 - Uploaded by sohvintage
Jan 10, 2016 | Audio Players & Recorders
Hands rotate endlessly onatomic clock wt 3143
If you have not talked to La Cross and if you continue to have the problem, most likely it may be a signal problem. I had a similar
problem with an earlier model and found that it only worked on
the west facing wall as the signal is coming from WWVB which is the NISTtime signal radio station near Fort Collins, Colorado. Get a fresh battery, reset the clock, put it in a west facing window and leave it overnight. If it doesn't work, contact La Cross as above post.
Dec 12, 2014 | La Crosse Radio Controlled Atomic Clock
Need instruction manual for 8N6V14(U) Radio Control La Crosse clock
You can get the info you need here, they should be able to help you identify your product which is not listed under that number.
Apr 12, 2014 | La Crosse Radio Controlled Atomic Clock
Www.lacrossetechnology.com/8248 need to reset time!
I'm not totally sure what you mean by "reset the time" because the unit normally sets the time automatically from the WWVB radio time signal. If you want to do it manually, this is what the Instruction Manual (PDF format) says:
MANUAL TIME SETTING
In case the atomic clock is not able to detect the WWVB-signal (disturbances, transmitting distance, etc.), the time can be manually set. The clock will then work as a normal Quartz clock.
  1. The hour digits will start flashing in the upper LCD.
  2. Select the desired hours by pressing and releasing the + key.
  3. Press and release the SET key to advance to the minutes setting.
  4. Now the minute digits will start flashing.
  5. Select the desired minutes by pressing and releasing the + key. If the + key is held, the units
    will increase by 5.
  6. Press and release the SET key to confirm the Time setting and continue to the Year setting.
Nov 08, 2012 | La Crosse Radio Controlled Atomic Clock
My La Crosse Radio controled atomic clock is spinning for the last two days, How can this be corrected? I have a secound Clock same modle it is working fine. Modle# wt-3102
Hello
To set up your clock simply install one fresh AA, LR6 ALKALINE battery. Due to the nature of long wave radio signals it is normally not possible to receive a signal during the day so it is best to install the battery late in the evening. Select your time zone by pressing one of the four time zone buttons PT-Pacific Time, MT-Mountain Time, CT-Central Time, ET-Eastern Time. The time zone buttons may be pressed any time after installing the batteries. If multiple buttons are pressed the clock will set to the time zone selected last. If no time zone is selected the clock will default to Pacific Time. Another time zone can be selected during or after the clock has set itself. Your clock can only set itself to one of the four time zones stated above. For time zones outside of PT, MT, CT or ET you must manually set the time using the Manual Time set button on the back of the movement.
When the battery is installed the second hand will advance eight seconds (two seconds per step x four steps). The clock is now searching for a signal. For the initial setting it is recommended to stand the clock in an upright position near a window. Within five minutes the clock will either receive the WWVB signal and set itself to the exact time, or it will determine that the signal is not receivable at its current location and time of day. If a signal is not receivable it will fast-forward the hands to the 4, 8, or 12 o'clock position and search for WWVB each
hour until a signal is received. If the time is manually set the clock will continue to periodically search for a signal and automatically reset the hands when the signal is received.
Select a location to place your radio controlled clock where it will be at least six feet away from a TV, computer, air conditioner or other household electrical appliances. The optimal location is near a window. Windows facing Colorado providing the best signal. The WWVB time signal will easily penetrate Masonry and wood framed buildings. WWVB will penetrate almost every residential building and most steel buildings if they have adequate windows. It is not possible, however, for WWVB to penetrate most indoor shopping malls and rooms in the center of large office buildings that do not have windows. In buildings that WWVB cannot penetrate you may set the time using the manual time set button. When the clock is exposed to the WWVB signal it will automatically set the hands to the exact time.
Ok.
Jul 31, 2011 | La Crosse Radio Controlled Atomic Clock
We now have two wall clocks that have stopped. Replacing batteries has not worked. Are they repairable? Can we get new or reconditioned movements?
Hello
Check its battery contacts for any rust or dust. Anyway clean it well and put the pattery, and check whether it is working or not.
Battery - The La Crosse Technology clock must have a fresh battery to receive and process the time signal.
Location - Try a different location, ideally near a window. It should be at least six feet from computers, TVs, air conditioners, other Radio-
Controlled clocks and other electrical appliances that cause interference.
Weather - Electrical storms between you and Colorado during the night will interfere with the WWVB signal.
Although we cannot control the weather we can help you predict it (see www.lacrossetechnology.com).
Daylight Savings Time
The National Institute of Standards and Technology and WWVB encode a special DST "bit" in the WWVB transmission for DST. Your La
Crosse Technology clock will read this information and automatically advance the hands one hour in the spring and eleven hours in the fall.
Arizona and Indiana
If you live in an area that does not recognize DST you must press the (unmarked) DST button for one second to deactivate your clock's DST
program. To reactivate the DST program simply press the DST button again for one second.
If you cant rectify the probelem, contact
La Crosse Technology, Ltd
2809 Losey Blvd. S.
La Crosse, WI 54601
Phone: 608.782.1610
Fax: 608.796.1020
or enter their website at
The device is a repairable one. OK.
Mar 14, 2011 | La Crosse Radio Controlled Atomic Clock
It looses time and the radio controlled feature does not bring it back to the correct time. I put in a new battery and it still happens. It is a La Crosse Technology Radio Controlled clock Model:WT-3101
When the battery is installed the second hand will advance eight seconds (2 seconds per step x 4 steps). The clock is now searching for a signal. For the initial setting it is recommended to stand the clock in an upright position near a window. Within five minutes the clock will either receive the WWVB signal and set itself to the exact time, or it will determine that the signal is not receivable at its current location and time of day. If a signal is not receivable it will fast-forward the hands to the 4, 8, or 12 o'clock position and search for WWVB each hour until a signal is received. If the time is manually set the clock will continue to periodically search for a signal and automatically reset the hands when the signal is received.
Jan 24, 2011 | La Crosse Radio Controlled Atomic Clock
My WWVB radio controlled quartz ch 899 clock is 21 minutes off the correct time. How do I set the clock by minute intervals?
Jan 12, 2011 | La Crosse Radio Controlled Atomic Clock
Manual for La cross technology radoi controlled digital watch #wt
Downloaded instructions and working on it.
Thank you.
Bernard W. Goering
Sep 12, 2009 | La Crosse Radio Controlled Watch
Resetting to daylight savings time.
The clock is searching for a strong enough radio signal from NIST station WWVB. When it can't lock on it, it gives up, moves the dial four hours, and goes to sleep to wait for better reception. Put the clock in a window facing towards Boulder, CO, overnight. (Radio propagation is better after dark.)
Mar 08, 2009 | La Crosse Radio Controlled Atomic Clock
Home Logo
81 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
