Question about AEG Washing Machines
AEG lavamat 705500: program does not end. It is stuck on the last minute indefinitely and door does not open. Is there any other solution to that?
  • 24 Answers
SOURCE: operating instructions lavamat 538
type in ' AEG lavamat 538 ' into the top right hand address bar on your pc and you will find links that will give you all the instruction manuals you need... AEG is at the lower end of the list....
Good luck
sue
Posted on Aug 03, 2008
localwonder
  • 6784 Answers
SOURCE: AEG Lavamat 16820: Strange noise coming the machine
Ok, the motor windings are bad. the A.C. hum is a warning that the motor will sound when the windings are separated or shorting. its unable to hold a balanced current.the motor will actually stop soon if it isn't repaired.
Posted on Feb 16, 2009
beltronic205
  • 1474 Answers
SOURCE: AEG Lavamat 6250 - opening door?
Try spoon handle gently prise open
Posted on Nov 12, 2009
  • 174 Answers
SOURCE: aeg Lavamat 64840 programme stops at 1 minute.
The main PCB, before sending the door aperture signals, checks for the following conditions:
• The drum must be stationary (no signal from the tachymetric generator)
• The water level must not be higher than the lower edge of the door
• The temperature of the water must not be higher than 40º C.
Automatic release device
In the event of a power failure, or if the appliance is switched off using the ON/OFF switch, or if there is a
fault in the solenoid valve, the bi-metal PTC cools within a period of between 55 seconds and about 4
minutes (at a temperature of 65°C), thus releasing the door.
if after swiching off for longer than 5mins and the door lock does not unlock the lock must be faulty.
Posted on Jul 16, 2010
SOURCE: AEG Lavamat Turbo 12710 Update - Dryer program
Hi Brooks, did you solve this? I have same issue
Posted on Jan 03, 2011
AEG lavamat 705500 - Door wont open even after the program is totally finished. What to do? Is there an emergency opening?
unplug it take the top off the scews should be in the back then reach down inside the washer by the door lock and find a pull release hope this help every model in the usa has this but i am not familiar with your brand
Jan 01, 2017 | Washing Machines
The washing process stops after about 12 minutes at any program and the green door light is on but water in the drum.
it looks like your heating element are dead. But Im not sure.
Does drum is spinning?Does it pumps water then you set in on "drain" program?
Apr 03, 2013 | AEG Washing Machines
Aeg Lavamat 64840 programme stops at 1 minute to go. turning the machine off doesn't help and you can't open the door
Jul 10, 2010 | AEG Washing Machines
Nov 12, 2009 | Washing Machines
AEG OKO_LAVAMAT 74620 gave me a code error C7. What is it?
take off the bottom front panel, a booklet is taped to the right side of the panel for the sevice tech it has all the codes
Feb 28, 2009 | AEG Lavamat 72640 Front Load Washer
Feb 15, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Operating instructions lavamat 538
Good luck
sue
Aug 03, 2008 | Washing Machines
AEG lavamat
For user's manual: Click on your brand name (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, & your manual is on line. Wait for at least 3 minutes after the wash is complete, to open the door; do not force the door. The door will not open immediately on the wash being completed.
Dec 25, 2007 | AEG Lavamat W1050 Front Load Washer
Washing Machines Logo
43 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
