Question about Oster Coffee Makers & Espresso Machines
My oster coffe maker doesnt brew put it on you hear a clik but noting happens after couple secounds a beeper comes on
Coldcut
  • 1554 Answers
SOURCE: How to set the coffe maker to brew at a certain time.
After setting the clock to the correct time .
then Press the Set delay then the HR and Min you want the timer to come on.
Press the brew strength for your preference.
then press the Select Twice to change Led light to Daily Brew. and now it will come on at the selected time.
Posted on Jan 26, 2008
SOURCE: cuisinart dcc 1200 will not brew
I'lm not sure of the model, but it is a Cusinart Coffee Maker with a Glass Pot. It gets power on all lights except the ON/OFF switch, and it willl not brew. Any suggestions, or should I trash it and get a new Coffee Maker. This one is approx. 1 year old. Thanks for your advise.
Posted on Oct 19, 2008
SOURCE: melitta mill and brew 10 cup grinder/maker
  1. Press and hold the TIME button for 2 seconds. The green TIME light will come on and display will read 12:00. The unit is now in the timer programming mode.
  2. Press "HR" and "MIN" button to program start time. Small dot in upper left corrner signifies clock is programmed for A.M. No dot in upper left corner means clock is programmed for PM.
  3. The Timer Display and LED light will flash 5 times to indicate that timer is now set. Press and release the TIME button. The green TIME light will come on.
Posted on Mar 30, 2009
SOURCE: Not working at all put the coffe in and press brew
Perhaps you just need to lift the handle again? If it's not flashing, it won't brew. Good luck
Posted on Jun 11, 2010
SOURCE: A couple of days ago, coffee maker turned it self
spoke w/ Cuisinart. Unplug unit for 1 hr, then plug back in, reset clock & Auto Off setting. This resets the unit back to the factory settings.
Posted on Sep 14, 2010
Testimonial: "great it works!!! thank you so much!!!!!"
How do I turn the beeper off so there is not beep at all on my Oster 5834?
You need to look in your owner's manual to see if turning off the beeper is an option.
The beeper is very important to inform you when the bread is ready, when to add ingredients, or if there is a problem with the maker. I am not sure it can be turned off.
Jul 28, 2014 | Oster 5834 ExpressBake Bread Maker
My coffee maker wont brew
i cant clean it cause it doesnt pump
Nov 27, 2012 | Oster HDX23 12-Cup Coffee Maker
The coffe pot turns on but doesnt brew
is there water in it? are all the components secured closed? is there heat coming from the burner?
Check-check-1-2-kiggit.
May 06, 2011 | Gevalia 10-Cup Coffee Maker
Not working at all put the coffe in and press brew and nothing happens
May 30, 2010 | Keurig Special Edition B60 Coffee Maker
I put the water in, usually to make 7-8 cups of co...
I don't have a solution but the same thing happens to mine...anyone out there have a solution?
May 20, 2010 | Cuisinart DGB-600 Coffee Maker
Gaggia baby 18 momths old water coming through steam bit but no water coming through coffe bit any suggestions libby
HI
If you have a pre-grind button on your machine, push it but don't put any coffee in the brew unit. Push any of the coffee buttons, and see if water will come out then. If it does not, then you have a plugged brew unit and the brew head needs cleaning. I have directions for cleaning.
Jul 13, 2009 | Gaggia Syncrony Compact Coffee...
Coffee Makers & Espresso Machines Logo
Top Oster Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Think Crucial
Think Crucial
ray gallant
Are you an Oster Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
