Can i buy a new board for floor lamp? File no e230863 model gx9906f lamp type fml 27w price?
  • 5,610 Answers
Yes from manufacturer but check fuse first!
Posted on Jan 01, 2017
Do I need a bulb with this same wattage,?
18 watt should work fine, but give less light.
Dec 14, 2011 | Tensor Home
TV turns on but lamp never comes on. Seems to try 3 times then all 3 led's on front start flashing. I tried to replace the lamp but problem remains.
If the Lamp has been replaced then problem will be either Lamp Fan or Ballast board .
Ballast board connects to Lamp and it is what powers Lamp on.
Check out Encompass Parts Distribution type in your Model number for a List of Parts/Prices and Part Numbers.
Samsung Parts 1-800-627-4368
Jun 23, 2011 | Samsung DLP HL-P5663W 56" TV
My son turned on my 1080pi tv last night and heard a loud pop and then smelt a burning smell. Do I need to take this to a repair shop or can I fix it myself? What would the cost be?
Hello
Something bursted out inside your tV. Probably it will be a mains filter capacitor. If this type of capacitor bursts out, it will spill the electrolyte liquid all over the surroundings, which is an electrically conductive material. So never turn ON this TV until it has been throughly cleaned and repaired. Power supply board inside your Tv is faulty. OK.
May 19, 2011 | Mitsubishi WD-52631 52" Projection HDTV
Samsung -hlm507w:lamp(green) temp(red) just pluging it in. Replaced the lamp with the correct type of connection. Nothing, I get the same blinking even without the lamp installed. Does this mean I have a...
No ,you need to check the Lamp Cooling Fan and the Ballast board it is what powers Lamp on.
Go to this website and type in your Model# for a List of Parts /Prices- Encompass Parts Didtribution 1-800-638-3328
Make sure all Fans are running .Let me know if you should need anymore help.
Oct 16, 2010 | Samsung Televison & Video
The on/off switch doesn't work on my floor lamp electric trait # PL/F 27W 6500K UL. E224694 Is there a replcement for it or is there a repair place here? Cary, N.C.
Suggestion: Someone just might want to peek inside the Electronic Ballast Enclosure mounted within the unit's base when they have the time and inspect for signs of failure similar to what I found in mine before insisting on buying a New Switch and risking disappointment first-cut. Burnt components are a dead giveaway, as (usually) is a blown fuse, although there's nothing wrong with jumpering that fuse to see what lights-up again or smokes, atcmb.
Those little snap-in SPDT switches are really rather rugged - your unit just MIGHT have a defective switch and nothing more - but I for one do tend to doubt that notion. Best double-check first before ordering.
Sep 13, 2010 | Vacuums
My Panasonic 44 inch T.V. hours on the lamp is running out, can I replace it myself?
Yes you can replace it yourself do you still have your owners manual,if so it tells you how to replace Lamp Go to website Encompass Electronics and type in your model number it will list parts and prices. You cn buy from them or Call Mats Ck prices their 1-800-628-1118
Oct 02, 2009 | Panasonic PT-52LCX66 Projection Television
I have bought a floor lamp model HBP319FL62. Shortly after the switch burned out. Can I buy from you a new switch?
No. But, you can buy a replacement switch from any hardware or home improvement store (ACE, True Value, Lowe's Home Depot etc)
Jul 16, 2009 | Select Products Blue Rhino Floor lamp...
Convertion of *.fml file into .swf file
i want convert fml to swf but i cant file a proram for this solution :/
Mar 31, 2009 | Macromedia FlashPaper 2
Toshiba 62HM195 needs a new light engine
This is a DLP type TV and if you mean the lamp, that is not a bad price however:
Projection TV makers charge an arm and a leg for their replacement lamps. They make it easy to do but as a result the custom lamp assy is expensive. The trick is to just buy the bulb for your model TV from any number of us aftermarket sources at a fraction of the lamp price and install it in the old lamp yourself. really easy. Some models are real bulb hogs though. Look them up on the net (include the word complaint or repair) before you buy, or you might be sorry. Many class action lawsuits out there - even against some of the name brand makers.
Hope ya fix it!
Feb 13, 2008 | Toshiba 57H81 57" Rear Projection...
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
