It wont light. Changed bulb, still wont light. Can i replace the main board? Price?
  • 5,651 Answers
Try changing fuse!
Posted on Jan 01, 2017
I changed the main board, the red light was on before,now with new board, nothing. i changed main board because it wont come on.
Hi you should be more specific. From what is that board? Make, modell? From what you described i can't figure out whatis
Aug 03, 2016 | Emerson Televison & Video
What's a fair price to repair a light bulb on 440QE?
Linda, The light bulb can fail for a number of reasons. If the power board has had the output transistor for the lighting circuit fail the 600.00 is reasonable. I would get a second opinion. Impossible to diagnose by email.
Oct 09, 2014 | Sewing Machines
Bought LED 8w(50W) bulb for range hood, bulbs work fine when turned on to regular mode but don't work on the second setting that supposed to make them a little dimmer. Do I need dimmable bulb or is this...
not a bulb problem, the computer board is what makes the light dim. for the price of replacing the main board i would just let it work the way it is. if the light fails completely, then think about a new board, but its not really a thing that is needed.
Dec 30, 2013 | Maytag MZD2766GES Side by Side...
How do i change the bulb on ag821azh microwave x2
follow this steps and use the VOM for fix it. God bless you
Light Bulb
If the microwave light bulb is not working it is usually located behind the upper grille and behind an access panel, and above the lower panel. On counter top units you will need to remove the outer cover to get to the bulb. If that doesn't solve the problem check the on-off switch, and control board
Main Control Board
If the microwave light bulb is not working check the light bulbs, sockets and wiring. If they are good the main control board might be defective.
Light Bulb Socket
If the microwave light bulb is not working and a new light bulb doesn't solve the problem, the light bulb socket might be burned out and need to be replaced.
Jun 19, 2013 | Microwave Ovens
The lamp of won't work
follow the steps and fix it. God bless you
ight Bulb
Main Control Board
Light Bulb Socket
Jun 11, 2013 | Neff H5642 Convection / Microwave Oven
Akai dlp tv does not have any power going to it, I just changed the bulb. What else could it be?
If you plug it in and no lights come on at all then it is your power supply board. If it has lights on it could be your main board that needs to be replaced. Just search online repair shops and give one a call they should be able to get you a new board for cheap and replacement is super easy.
May 18, 2013 | Televison & Video
My Sanyo PLC XE31 wouldn't switch on, bulb replacemetn lamp was lit. Changed bulb and now it switches on, green light shows, fans run, and then after approx 30 seconds the red light flashes and it switches...
1, the lamp is ok
2,the lamp ballast is ok
3,seems that the power supply or mother board is defective
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Jan 24, 2011 | Sanyo FOR PLC-XE31
Dash light
It sounds like the headlight switch is bad.
Apr 22, 2010 | 2000 Mitsubishi Eclipse
SP42w5 problem
sounds like a logic main board, but first check all the cables inside to make sure they all are seated good, price for the board and labor will probably run around $350.00
Mar 04, 2007 | Samsung SP42P2S Television
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
