Question about Carrier 52PQ-515---3 Premier Series Heat Pump, 15000BTUH, 5.0KW, 230V PTAC Air Conditioner
Which would be the filter size for Carrier Heat Pump FB4CNF024?
Is it worth to clean the existing green mesh plastic filter, or just go with disposable ones?
3 Suggested Answers
yalmer
  • 549 Answers
SOURCE: Carrier Thru-Wall Heater and Air Conditioner won't heat
http://www.residential.carrier.com/support/troubleshooting.shtml
Here is some troubleshooting tips.
Also service available.
Posted on Feb 25, 2008
SOURCE: Need the motor size on a carrier 38SQ940311
Carriers usually have a 1/4 HP condenser fan motor.
Posted on Jul 19, 2012
What SEER is carrier model number FB4CNF024
The FB4CNF024 normally connects to a 13 SEER Heat Pump.
Feb 16, 2015 | Carrier Heating & Cooling
Trying to install honeywell 7 day program thermostat but I don't know if I have a heat pump. My initial thermostat W white O orange G green R red C blue Y yellow. When I install the Honeywell the O is not...
Look real good at the terminal block. Look at both the left side and the right side of the terminal block. O should be there! You probably do not own a heat pump. Also have patients when programing the thermostat!
Dec 30, 2014 | Heating & Cooling
Filter for Payne (Carrier?) Heater FB4CNF024??
Yes what you say is right try home depot ,canadain tire, lowes, they all do filters with differant sizes you can get them in 12 , 10 what ever you need
Feb 17, 2012 | Heating & Cooling
The picture is slitly green tinted on the screen ?
It sounds like the polarizer filters are starting to ware due to heat build up, if you remove the lid and the main booard, there is a white plastic mesh cover over the lcd panels, you can remove this and adjust the polarizers for the red, green and blue lcds to adjust the black level, there are 3 hex bolts holding a plastic frames which in turn hold the pre polarizer filters, buy slightly loosening the bolt you can slide the plastic frames left or right to adjust the levels, buy you should mark the position before you start. this may not solve the problem but may help to improve it, unfortunately these projectors require special software to make electrical adjustments which is hard to get hold of.
Apr 29, 2011 | NEC MultiSync MT1065 Multimedia Projector
The paper filter was wet i was cleaning it and it seems that no use at all...does it has a spare,where can i buy it? thanks!
It's not necessary to replace it with a paper filter like the one that got wet. You can replace it with a foam type mesh filter, that is washable. All you need is the size (length & width) and you pickup one up at any home center or hardware store.
Hope this helped.
Mar 29, 2011 | Carrier XHC101D Air Conditioner
Dishes not getting clean, left with gritty residue. Could the filter be backed; if so how do I fix it?
Had the same problem with a GE Nautilus 3400 series.
Solution:
- In their manual, GE recommends not stacking tall dishes on the bottom right tray - this prevents the dishwashing powder from fully dissolving. Are you using the right detergent and rinse-agent ?
If your upper arm is not turning during wash (DW leaves residue on top-shelf items), do the following:
1) Empty the DW.
2) Pull down the rotating arm on the DW ceiling. Thoroughly clean the passageways (I had to tap it on the counter to break-down the sediments).
3) Inspect the mesh-screen filter located on the floor in the back - if it's backed up (ours was backed-up from the inside), you'll need to clean it by removing 4, 1/4" screws holding it to the DW floor and throughly cleaning it (I also unscrewed the plastic valve located on the bottom of the filter compartment). While you're at it, remove the plastic mesh on the DW floor (2 screws) and fish for any objects and sediments blocking the pump.
4) Replace filter and bottom mesh and operate the DW in "Rinse" mode.
5) Press the rotating arm back in and operate the DW in "Rinse" mode. Check rotation.
- Good Luck !
Feb 21, 2009 | GE Nautilus 24" Built-in Dishwasher
Genral oil change
1.Get your supplies ready and expose your engine 2.Unscrew the Oil Filler Cap 3.Remove the Oil Drain Plug 4.Remove and Replace the Crush Washer 5.Clean the Oil Drain Plug 6.Remove the Oil Filter 7.Remove and Clean Plastic Mesh Filter 8.Lubricate the O-ring of the New Filter and Attach it to the Engine 9.Motorcycle Oil Change - Replace Oil Drain Plug & Plastic Mesh Filter Pour Oil 10.Check the Oil Level,,
Nov 10, 2008 | 2001 Mondial Piega
Genral oil change
Nov 10, 2008 | 2008 Bimota DB5S
Genral oil change
Nov 10, 2008 | 2005 Benelli TnT
Bosch axxis WTL lint indicator problem.
I have been struggling with this lint filter problem big-time. After reading the previous user's comment that his mesh holes had become clogged, I took a closer look at my filter and noticed that the tiny holes in the mesh were, indeed, clogged up. In fact, when I initially ran water on the filter it pooled up on the mesh like a solid plate...pretty good sign that air wasn't able to pass through the filter properly.
I used a soft toothbrush and soap to clean the filter, and when I ran water to rinse it off it the water passed right through the mesh. I popped it back in and, voila...That fixed it!!
Mar 08, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Heating & Cooling Logo
21 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
