Question about LG Tablets & eReaders
My home screen is not working so how do I reset my lg T-Mobil tablet?
How do you restart a LG tablet
An alternate reset method is available if the device can be powered on and is responsive.
Ensure the device is powered off.
Simultaneously press and hold Power + Volume down buttons until the System recovery screen appears then release.
From the System recovery screen, select Factory data reset. ...
Tap Yes to confirm
Nov 21, 2017 | LG Tablets & eReaders
When I turn on the tablet I get the welcome screen for about 40 seconds and then tablet turns off and repeats this over and over without ever getting to home screen
Did you attempt to root the tablet or install a different bootloader? If so, try again because it hasn't worked. If not, something has been corrupted, try to do a factory reset. Normally achieved by turning the power off, then turning the power back on while holding the home key and either the volume up or down button until you see an android.
If you factory reset you lose everything. So if the option is there, first try the to clear the cache and dalvik cache.
BTW, did you try the reset button on the edge of the case? Stick a pin in it. Try that first.
Mar 21, 2015 | Irulu 7" Google Android 4.0 Capacitive...
When I reset my lg vslate tablet now the touch screen doesnt work
Attach to power charger. Try hard shut down then try reboot all while connected. Then at that point you should see your keyboard again once o/s is back up.
Feb 11, 2015 | LG Electronics Unlocked Optimus G Slate...
Reset vigo android
This works with devices having physical home button:-
1. Press the power button and the home button together for a while, long enough until the screen appears with Android bot and a progress bar which shows that it's formatting the internal memory.
With NO physical HOME button:-
2. In case your device does not have a physical home button, press the power button and both the volume keys together for few seconds.
3. Press gently the "reset pin-hole" present generally on a side of Tablet. Use a clip-pin or similarly fine thing to gently push inside to reset your device to factory settings.
or you can Check my blog how to reset your tablet lol,
http://pcgadgetdeni.blogspot.com/2013/02/forgot-passwordpattern-unlock-of.html
Feb 18, 2013 | Android Flytouch 3 8gb 10.1 Inch Super Pad...
Forgot my passcode symbol on my tablet an need to reset it please
1.
Press the power button and the home button together for a while, long enough until the screen appears with Android bot and a progress bar which shows that it's formatting the internal memory. With NO physical HOME button:-
Note: I Use My Tablet SUNBERRY, and reset my Tablet
Turn Off your Tablet and then
Press Power + Volume Down (Press up Factory menu Show)
If you use Android 2.2 (Froyo)
Press Wipe data / Factory Reset -> Yes, Delete ALL user data -> if Finish press Reboot Now
If you want more other andoroid OS and other tablet visit my Blog
you can see how to Reset android with video
Feb 14, 2013 | Archos 101 Internet Tablet 16GB 10.1"...
Disgo is frozen on home screen and home icon keep flashing i cant do anything
Search google to do a hard reset, I had the problem and after doing a hard reset it helped me and my tablet is working fine now. I don't really remember which keys it was but there are three keys to keep pressed and after that it will reset your tablet and if everything is ok it should work perfectly after that.
It would be nice if the manufacturer would also put that in the manual, because when I received my tablet I had to calibrate the screen and that didn't really help me. Also the tablet was working really slow and took a lot of time for everything, plus the fact that the keyboard kept pressing all sorts of other keys then that I wanted to press.
I hope this will help you and that your tablet will work fine for you.
Let me know if you had any success.
Sep 08, 2012 | Disgo Tablets & eReaders
I have a craig touch screen tablet and i forgot my dot password how do i reset it?
Power the unit off (holding power buttom) and selecting Power off, then hold simultaneusly back button and on buttom 8 seconds,the android icon appear press back buttom, in the menu select wipe data/factory reset pressin home buttom and then press back buttom, in the next screen select "yes delete all user data" pressig back buttom, and in the nex screen select "reboot system now" with the back buttom and wait. IT WORK FOR MY TABLET
Aug 18, 2012 | Craig CMP741d Tablet
Tablets & eReaders Logo
24 people viewed this question
Top LG Tablets & eReaders Experts
Jax Planet
Jax Planet
Andrew Taylor
Andrew Taylor
micky dee
Are you a LG Tablet and eReader Expert? Answer questions, earn points and help others
