Question about Baby Gear
I have the Melaine crib 343-7134 NPTD and I need bolt information. I can see that I need 70mm long Allen head bolts and Phillips bolts but I need diameter to tell Home Depot guy to find replacements.
    Top Expert:
  • Baby Gear Master
  • 44,109 Answers
For safety reasons, OEM hardware should be used.
  • Hallie Miller
    Hallie Miller Jan 02, 2017
    I no longer have them and have been waiting to hear back from the manufacturer. I've called all the numbers suggested by others in this forum and am still waiting. I'm due soon and need this figured out
Need 4 allenhead bolts (2 3/8 inch) and 15 nylon washers for Chatham Lifestyle Crib. Customer Service states they no longer carry the hardware for it.
Do the bolts have to be allen head (hexhead) bolts, hardware store and match the threads and the length of bolt and switch to say, a phillips or flat head style bolt. Did the CSR at the hardware store NOT try to help you in this way?
Jan 02, 2013 | Baby Gear
I need the bolts to attach the side rails to the back. 4 - 2 inch and 8 - 3 1/2 inch allen heads
I got my crib as a family hand-me-down and needed the eight screws. I found them at Home Depot. they came in a pack of 4 for $5.21. My receipt has item# 030699813148. Hope that helps you!
Jun 19, 2011 | Delta Luv Delta - Baby Products 5-in-1...
I lost my manual, I need to know how to transform the crib into a toddler bed
Converting a Simplicity Crib into a Toddler Bed:
Please note, Simplicity has gone out of business and the Simplicity Cribs should NOT be used as cribs. They were sold at Walmart, Target and BabiesRUs. The word on the street is that Walmart is the easiest to deal with when it comes to returning them. Those who wish to return Simplicity cribs don't need a receipt, they can just take them to Walmart for store credit. BabiesRUs was apparently giving about $65 while Walmart was closer to $190. Again, this is just what I have heard from others.
You can find the specific information on the Simplicity recall here.
If you do want to use your Simplicity crib as a Toddler Bed, I have not read any warnings against this. Again, I might just take it to Walmart anyway and get a store credit and perhaps buy a new convertible crib. You can get some great ones on Amazon for around $150 with delivery included.
I would pack it up, take it in for store credit, and get a new crib!
You can get some great deals these days on cribs, there's a great one on Amazon for $150 with free shipping so it's kind of a no-brainer.
As I have heard, Walmart will take it back, no questions asked and no receipt necessary and you can get a brand new one with brand new parts, brand new instructions and no recalls or risks!
Good Luck.
Here's one of my favorites:
mkd123_2.jpgGraco Sarah Classic 4-in-1 convertible bed
If you still want to convert it, here is what you need to do:
1. Remove the front panel of the Simplicity crib. Use an Allen wrench and 45mm bolts (there should be extras underneath the crib, along with an Allen wrench, but if there aren't then you can pick some up at your local hardware store.)
2. Check the mattress support. It needs to be in the lowest position available, which will allow the toddler to get in and out of bed easily. It is also the only position that will make the rails line up properly with the pre-drilled bolt holes. To lower the mattress, unscrew the four bolts from the four corners of the mattress support and slide the support down. The holes for the lowest setting are just about the bottom wood panels. Use your Allen wrench to reattach the mattress support with the same bolts you pulled out when the mattress was in the higher position.
3. Attach the toddler bed rails to the crib frame. Use two 38mm Allen bolts on each rail. There are pre-drilled holes in both the rail and the crib frame. Line up the holes and then loosely screw the bolts into place. The bottom of each rail has a metal L-shaped hook. This will slide under the mattress support. Use a 19mm Allen bolt to attach this piece to the mattress support. When everything is lined up and screwed in loosely, go back and tighten each bolt. Repeat on the other side.
4. Check the entire crib frame for loose bolts. Use the Allen wrench to tighten all the screws. Toddlers can be rough on their beds, so it is important to make sure the bed is safe. You should recheck for loose bolts often. Jumping and climbing on the bed can easily loosen the bolts and screws.
5. Don't forget to hang onto the front panel and store it carefully, you will need it later to convert the bed into a full sized bed.
Jan 23, 2011 | Simplicity for Children 4-in-1 Convertible...
I lost my instrction manual!
Step 1: Detach the front panel from the 2 front post using an allen wrench
Step 2: If the mattress support is not in the lowest position unscrew the bolts and move it to the lowest position
Step 3: Using the allen wrench, attach the guard rail using 4 bolts between the lest and right front post (the guard rail would be that extra piece that you couldn't do anything with while the bed was converted to a crib. Looks kinda like a wooden board)
Step 4: Tighten all screws and put the crib mattress back in
Apr 30, 2009 | Baby Gear
Trying to turn our crib into a toddler bed
Part needed: Allen Wrench
Safety rail
Safety rail bolt
Make sure the mattress support in in lowest position. Remove the front top rail and front panel. Attach both safety rails ( small side pieces) to the crib end leg using the safety rail bolts.
Mar 25, 2009 | Delta Enterprise Baby Gear
Parts for a Modus Crib "Melanie" need part number
I just bought a crib like this one at a garage sale because it was in such good condition. The paper on the bottom of the crib was still intact and was complete including assembly instructions. Here is the information that came with this crib. Hope this helps you.
Melanie Product # 343-7134 NPTD
For Parts Call 1-800-827-2129
Dec 07, 2008 | Pt Domusindo Tori
Baby Gear Logo
404 people viewed this question
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Baby Gear Expert? Answer questions, earn points and help others
