Question about Ariens Garden
Well my ariens platinum sno 24 inch which is 3 years old has a rotor jam this morning and some smoke came out of it so i turned it off. What can i do?
The smoke was probably from the drive belt. You have to clear the jam first, and you may also need to replace the drive belt.
Posted on Jan 01, 2017
Why sno thro continues to run after ice block is removed
Because that is how it's designed. It's designed to run again, after you remove ice block.
Apr 29, 2014 | Ariens Snow Blower. Sno-Thro Deluxe Drift...
Ariens 30 deluxe platinum series won't start
Is this your first attempt of the season to run it? Did you totally drain and run the machine out of gas last year?
10% Ethanol gas left in a carburetor for months is a killer
Jan 03, 2014 | Ariens Snow Blower 921013 ST30LE 305cc 30"...
Auger does not engage on Ariens Model 924121 sno- Thro
first check shear pins in the auger ( try to turn big auger by hand, engine off)
then if they are good then try to turn impeller by hand, engine off
youll need to turn it a few times before the larger ones turn, but thats what you want
if they dont turn then you have sheared the gear box gears
be sure belts are good tooo
Dec 15, 2013 | Ariens Snow Blower. Sno-Thro Deluxe Drift...
Ariens 1640 Zoom Riding Mower with Briggs & Stratton engine smoking
check to see if the oil smells like gas the needle valves go bad in the carb and gas over flows into the crank case also the head gaskets go bad and **** the oil from the crank case
May 08, 2012 | Ariens Garden
I have a ariens 24 "sno tech it will not throw
The most common cause of this is the drive belt is worn. If you remove the cover (usually plastic) in the middle of the snow thrower and look at the belt closest to the blower assembly. This is the blower drive belt. (Your operators manual will show you the location and how to remove the cover if you are unfamiliar with your snow blower)
With the engine not running, have someone depress the drive lever and check the belt. You should only be able to depress the long side 1/2 inch or less. More than that the belt has stretched and needs to be replaced. On some older blowers you can adjust the tension pulley, but most made in the last 15 years, you can't.
The belt may be frayed on the edges or glazed causing it to slip (it is shiny on the sides of the belt)
You can get parts (the new belt) through your local Ariens dealer or
Feel free to ask any other questions. I know Snow Blowers. Please remember to rate this answer!
Jan 13, 2011 | Ariens 34 In. Zoom Series Riding Mower
Where is the spark plug located on an Ariens Sno-Thro compact?
I am assuming this is a 22 or 24 inch model. The engine is an overhead valve design and the spark plug is buried on the left side of the motor (looking at it from the handles) You should be able to see a large black wire going into the engine. Depending on the engine make it may have a rubber cover or just plug wire covering the plug.
On this page are pictures showing the location of the spark plugs on Briggs & Stratton engines.
The OHV horizontal shaft engines are about half-way down the page.
Feel free to ask any other questions. I know Craftsman Snow Blowers. Please remember to rate this answer!
Jan 13, 2011 | Ariens Garden
Craftsman 247 88190 0 snow blower auger frozen
my auger and impeller froze too. fixed by clearing all snow, ice,stone build up behind impeller it works fine now.. hope that helps
Jan 19, 2009 | Ariens 34 In. Zoom Series Riding Mower
Garden Logo
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Paul Sikkema
Paul Sikkema
Are you an Ariens Garden Expert? Answer questions, earn points and help others
