Question about Brother Sewing Machines
How to open fuser cover on brother Mfp 8860 I have to do that to clear a paper jam.I have the back cover open but can't find the handles to take the next step which is to open the fuser cover.
It gets a little more complicated in my case because I'm disabled and can't get around to the back of the machine. Nor can I turn the machine around without risking dropping it on myself and sustaining a serious injury. What I can do is to stand in front of the machine and reach over the top to activate the levers which as I recall us some place on both sides of the fuser cover and need to be pushed toward each other. A picture of the few to cover latches might be all I need.
  • 4 Answers
SOURCE: buttonhole lever
If you remove the cover on the upper left portion of the machine, while looking from the left to the right.....Above the BH lever area, you will see a round cam with a post through the middle. Rotate the round can ( with fingers on it), and try again. This will change the angle position on the lever, and hopefully correct your problem. You may have to go a couple of clicks in either direction.
Posted on Nov 26, 2007
  • 202 Answers
SOURCE: Thread wound around disc of take-up lever on bernina 1008
Hi, there is no top cover on this machine. First the side cover has to come off then the back cover. Under the back cover there is a rigidity plate with many screws that has to come off and then you might be able to get at the take up lever mechanism. I'm not saying you can't do this but it might just be the time to have a tech go in and service this machine completely.
The thread must have slipped out of the end of the takeup lever and wound in the mechanism. It happens.
If you feel you want to do this yourself feel free to contact me and I can walk you through getting the covers off.
Possibly you can get a tweezers or needlenose pliers in through the front slot, grasp the thread and turn the handwheel bit by bit and see if it will unwind as you pull it out.
Posted on Feb 28, 2009
  • 74 Answers
SOURCE: Top thread gets stuck around bobbin case
you might have a bent needle
Posted on Oct 03, 2009
  • 96 Answers
SOURCE: Thread stuck in a Brother innovis 1200 sewing machine.
that is probably a glitch in the build, so a service repair would be necessary
Posted on Dec 13, 2009
  • 2382 Answers
SOURCE: When I insert the bobbin case, the arm will turn a
Hi, try to turn your handwheel using slight pressure. If it moves a tiny bit, you probably have thread between the bobbin wheel that holds your bobbin case. There is an outer ring and an inner shuttle. Place a drop of sewing machine oil in the inside of where these two are seated together. Now watch your shuttle as you turn the handwheel towards you. You may have to apply some force but you will not damage anything by using the force you can generate with your hand. You will see the thread move out. Pull it out with your fingers. If it breaks or doesn't get all of the thread, repeat the process. On most machines you never want to turn the handwheel away from you. This will cause damage to the motor over time. Make sure to stitch it out in straight stitch to check that it's sewing correctly. Thread jams happen when you get nesting (knots of thread) under the needle plate. This occurs usually when you are sewing light or tightly woven fabric with a heavy stitch, such as an appliique stitch. Try using a light wash-away stabilizer under the fabric or in the seam to prevent this. If it's an older machine or a newer Singer, hold the end of your top thread for the first couple of stitches, too.
Posted on Dec 12, 2010
I have a brother lx 2500 sewing machine and when it jamed i opened up the bobbin area and cleaned everything but now having problems getting the casing back in
Use a mirror and make sure that the area is perfectly clean and there are no obstructions. Then make sure that the needle is all the way up to the top of its cycle and then insert the bobbin.
Sep 20, 2015 | Brother Sewing Machines
I have an older Brothers Sewing machine, to thread the bobbin you need to turn the handle to open I up. After doing this you need to tighten it back up so you can sew again. This is where I am havin
It seems that your explanation has bee truncated.
Link below is to videos on youtube regarding winding bobbins on brother sewing machines. If you don't find an answer there please re submit your problem.
Brothers Sewing machine wind bobbin YouTube
Sep 15, 2014 | Brother Sewing Machines
Material will not feed after a jam while doing embroidery.
Make sure you CLEARED all the fabric and thread away from the inside of your machine. Disconnect it from the power. Then turn it back on.
Aug 10, 2014 | Brother NX-400
How do I remove the cover of the Brother PC-420 sewing machine?
This page should help explain that error message:
Aug 04, 2014 | Brother PC-420
1034D brother door broken
If you need a replacement front cover, you can order one here:
Front Cover Brother XB09797 001
You could also order one through most sewing machine repair shops and dealers.
Feb 09, 2014 | Brother 1034D Mechanical Sewing Machine
Problem with brother SE400
Looks like this girl does not have any issues with Brother se400 machine.
Mar 07, 2012 | Brother SE400 Computerized Sewing Machine
My brother machine keeps reading E6 and I clear the thread buildup and it keeps doing it over and over.
have you tried turning off the machine & unplugging & the turning it back on to see if that clears the computer part?
where was the thread build up it was indicating?
did the machine jam up in the bobbin area?
Aug 29, 2011 | Brother CS-6000
My sewing machine is like stuck or something the nob wont turn it wont sew it wont do any thing but make a noise
Is the thread jammed around the bobbin area? Open up the bobbin cover and check it all out, clean out any jammed or broken threads and rethread the machine.
The other thing to check is that the clucth in the side wheel is engaged. If you disengage the clutch to wind a bobbin, ensure that you engage it again to start sewing.
Hope this helps, otherwise it might be serviceman time.
Feb 27, 2011 | Brother XL-2600I
The bobbin case keeps rotating and jamming up. I have to open the cover and move it back into position
Are you using the right size bobbins? It requires a SA 156, I use the metal ones that I buy on ebay, 20 for $8.99 and free shipping. Less trouble.
Sep 18, 2010 | Brother EX660 Computerized Sewing Machine
Nov 29, 2009 | Brother Sewing Machines
Sewing Machines Logo
22 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
