Question about Dryers
I have lights and power to my dryer but no front indicator lights and it wont do any drying functions
  • Dryers Master
  • 5,323 Answers
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
All else appears to be working except the dryness level selection button does not light up and will not allow selection
How do I read the digital display panel and controls on my ...
www.samsung.com/uk/support/skp/faq/1025253
Samsung ElectronicsAug 12, 2014 - The Drying light will illuminate and remain lit until the cycle is ... the indicators will light up until you press the Start/Pause button. ... When you turn on your dryer the Cotton Cupboard Dry cycle is selected by default. ... Drying Level button ... If you do not turn the Drum Light off within 5 minutes of turning it on it ...
Dryer Control Panel And Functions - Samsung
www.samsung.com/ca/support/skp/faq/230147
Samsung ElectronicsJan 7, 2015 - To set Dry Level in the Normal, Heavy Duty, or other Sensor Dry ... An indicator light illuminates next to the selection. ... Temp Selection Button ... When using Manual Dry, you can select the drying time by pressing the Time Selection Button. Important: Clothes may not dry completely if the drying time is not ...
MACHINE OPERATION
docs.whirlpool.eu/_doc/501930002795EN.pdf
Material thickness: whenever there is greater load than the dryer can handle, ... Do nottumble dry: nylon stockings, delicate embroidery, fabrics with metallic ... The indicator lamp above the relevant button lights up to confirm your selection. ... Wait at least 5 minutes, to allow the laundry to cool down, before you unload the ...
501930001546EN.pdfDOWNLOAD
Jan 01, 2016 | Dryers
Front panel wont light up, why?
I have the same issue. Dryer lights when door is opened, but no panel display, and no function.
Jul 26, 2014 | Kenmore Elite HE4 Electric Dryer
Got a software update and now dryer is flashing all indicators
try turn power off to dry,if still not working call the tech back that did the software update
Apr 24, 2010 | Miele T9820 Gas Dryer
Electric front load dryer flashes check filter.
what is the indicator lights in the board means. The green light is flashing one flash in then going into lock mode.
Model# RGPJ 05 EAUER
Jan 29, 2010 | LG Heating & Cooling
Whirlpool duet dryer wont start. Lights up
Symptom: Dryer turns on, drum spins, but you have no heat.
Any of the following components are more than likely suspect as being bad:
Heating Element
Thermal Cut-Out
Hi-Limit Thermostat
All these components COMBINED, should cost less than $100. If you fix it yourself, you will avoid the additional cost for labor.
If the dryer isn't blowing ANY air at all, but the drum still turns, you may have a bad blower fan assembly inside the dryer. Or, the blower fan assembly may be clogged.
If your dryer performance has been failing (i.e., clothes taking longer to dry), it may be for a reason. You need to ask yourself when the last time you cleaned the dryer ventilation. If you can't remember, or if it has never been done, this can contribute to the dryer failing. All dryers need proper air flow in order to dry properly. If the ducting becomes clogged, the heating circuits will actually overheat and eventually fail. This usually results in the Thermal Cut-Out (TCO) blowing or the Heating Element failing or BOTH. When these components fail, they must be replaced. Remove the dryer hose from the back of the dryer and inspect it thoroughly from where it leaves the dryer to where it exits your home. It should be clear with no kinks or clogs. If your vent line runs under a crawl space make sure it is suspended above the ground and has no sags where lint could collect. RULE OF THUMB: The SHORTER and STRAIGHTER the vent duct, the BETTER. After you inspect the vent ducting, turn the dryer on and make sure you have forceful air flow coming form the dryer. This will prove that your blower fan is working properly or not. Since you stated that your dryer is not currently heating, the air will be cold, but you should still have some force behind it. If the air flow is weak, you need to clean the duct work INSIDE the dryer. It is important to keep a dryer checked routinely. I recommend once per season (that's 4 times per year). Dryers are the cause of many house fires. These fires are due to lint accumulations inside the unit catching on fire. A little preventive maintenance can prevent significant problems in the future.
Getting to the heating circuit to determine if the components are good or bad is the next step. If your dryer has the lint screen on the top of the unit, you will need to remove the back panel of the dryer to expose the heating circuits. If the dryer has the lint screen in the door, you will need to remove the lower kick panel under the door by using a putty knife to release the retaining clips. They will be located along the seam in the front about 2 inches in from each side. If this is a Kenmore Elite or Whirlpool Duet, the lower lick panel comes off by removing the screws under the bottom edge of the panel. (HINT: placing a block of wood under the front feet of the dryer can make access much easier). If your dryer has no lower kick panel, you have to remove the entire front panel on these models. This is accomplished by lifting the dryer top and removing the screws that hold the front panel in place.
NOTE: The heating circuit should be troubleshot with the dryer UNPLUGGED. Dangerous voltages are still present with the dryer turned off. Resistance readings are as follows:
Heating Element (located inside heater box) - remove the two leads from the ceramic terminals on the heating element and take a reading across the terminal points. It should read 9 - 13 ohms.
Thermal Cut-Out (TCO) (mounted to the heater box.) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
Hi-Limit Thermostat (mounted to the heater box, closest to the heating element leads) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
If any of the above readings are abnormal, replace the component. NOTE: If the TCO or Hi-Limit Thermostat is defective it is highly recommended by most manufacturers to replace BOTH components at the same time. They are often sold as a set. Without doing so, these components can cause potentially fail again.
NOTE: One item I failed to mention - Double check the input power for your dryer FIRST. You should have 220VAC at the receptacle and terminal block. The dryer will STILL tumble and the timer will still function with a portion of the input power missing as these circuits only require 110VAC. The heating circuits, however, require 220VAC to function. If one leg of the receptacle voltage is missing the dryer may exhibit "No Heat" like symptoms. This could also be an indication of a burned or failed power cord. Continuity checks performed with the dryer UNPLUGGED should indicate a short between the prong end of the cord and the respective lugs at the terminal block.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$#@!
Jan 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite Electric Dryer, Model # 110.8586400, Control Panel Lights inoperative, But Drum Light works fine. I am going to try this procedure, Will let you know if it works. Jay/ Jacksonville Florida...
I followed that procedure, Taking the Electronic Control Unit out of the dryer, Blow Drying the printed circuit Board (PCB) Board out and reseating P3 and P4, Worked fine.. No moisture was found in the Drum area. I forgot to tag the TECH SHEET FOR this particular dryer . But punch in Tech sheet , Part # 8546206 into google, this gives Schematic and valuable Troubleshooting steps, The only thing i could not find was the pin to pin test on chekcing the individual switches on the main functions, Suppose to be 14 pins I only found 13. But in all drying the PCB board and reseating the plugs worked for me. Again the symptons were no Light indication on ANY button depressed but the drum light was on. Great Site, Not a first time user
Dec 04, 2009 | Kenmore Elite HE4 Electric Dryer
Whirpool GGw9250Pw3 no power on Control Panel Inside light works
In my case, the problem was a dead main board. The board cost $190 and the overall repair cost $335. I will never buy another Whirlpool due to this experience.
Dec 11, 2008 | Whirlpool GGW9250PL Gas Dryer
Kenmore elite he4 dryer wont run
Hi! crystal2hd
My he3 dryer does not have a door lock. The door switch turns off the light and allows the dryer to start. Make sure this switch is not damaged. Unplug the dryer before removing the front cover.
InMrFixIt
Aug 27, 2008 | Kenmore Elite HE4 Electric Dryer
"controls locked" red light indicator is lit up...
Hi! mingx2of06
So are any lights on, do you have power at the wall circuit.
InMrFixIt
Aug 08, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
26 people viewed this question
Top Dryers Experts
