Question about Whirlpool ED2GHEXN Side by Side Refrigerator
Water collects in bottom of freezer side - Whirlpool ED2GHEXN Side by Side Refrigerator
    President:
  • 744 Answers
Hello, this sounds like you have a blockage in the drain tube, remove panel back of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking down the vent instead of the drain hole...If you need any further assistance please feel free to comment again. good luck! P.s Please don't forget to rate my solution thanks! Mike
Posted on Jul 21, 2009
Water in the bottom freezer of a 2000 GE Profile refrigerator
look in bottom at back for drain hole, may be clogged, or even hole frozen over with collected water. Clear the drain hole.
Jul 30, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
Water collecting in bottom of freezer
Unblock the drain hose. You may have to access it from the back of the unit and it may be frozen up so you may have to fully defrost the freezer
Apr 30, 2012 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Your seal may be bad letting in moist air that provides a source of water to condense on parts of the freezer.
Jul 24, 2010 | Kenmore 53703 / 53706 Stainless Steel Side...
There is water collecting at the bottom of the Freezer. It is coming out of the vent area inside the Freezer near the bottom. Can you help identify?
Check the defrost drain at the bottom rear of the freezer. If the drain is clogged or frozen, the water has to go somewhere during defrost.
Nov 14, 2009 | Maytag MSD2756G Side by Side Refrigerator
Water at bottom of refrigirator
Find the drain line from the freezer to the evaporation pan near the motor. Often the line is visible on the back of the fridge. That line is plugged either with food residue or the collection point in the freezer is solid ice. The self defrost feature melts the frost and drains it to the evap pan. If you remove the floor from the freezer area, you will see the collection point. When the line gets plugged with food, no water drains and then freezes to block the line even worse. So, if there is ice at the collection point, remove it somehow, maybe a hair dryer, and then clear the line by blowing compressed air from the bottom of the drain hose through to the collection point.
Jun 19, 2009 | Maytag MSD2756G Side by Side Refrigerator
Amana bottom freezer: water leaking & ice build-up
There should be some kind of drain at bottom of freezer compartment to collect and run off any condensate that collects during defrost cycle.. Clean out the drain and snake out the line that leads from it. Right now the liquid is collecting where it should not and it will leak out the gasket when you have enough of it.
Sep 09, 2017 | Amana ABB1927DE Bottom Freezer...
GE TFX20JR side by side/water leaks out freezer during defrost
Yes, you are correct, that is a drain. Use a turkey baster with hot (not boiling) water to flush out the drain tube until water will flow out into the drain pan under the refrig. (where the air blown over it will cause it to evaporate)
Jan 06, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water in Freezer bottom
drain line is blocked check bottom tray if is collecting water if not drain line blocked
May 10, 2007 | Maytag MSD2754G Side by Side Refrigerator
Whirlpool ED2GHEXN Side by Side Refrigerator Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
