Question about Humidifiers
How do I stop my humidifier from making a vibrating noise
3 Suggested Answers
  • 118 Answers
SOURCE: Loud vibrating noise when the furnace blower starts up.
Try closing damper slightly between humidifier and furnace????
Posted on Feb 04, 2010
  • 16631 Answers
SOURCE: humidifier making noise.not steaming
This is an indication that the power supply has issues. You would have to take it apart to check and see what is wrong.
Posted on Mar 10, 2015
Humidifier making noise.not steaming
Mar 10, 2015 | Air Innovations Ultrasonic Digital...
I have a sunbeam sul2512um ultra sonic humidifier . I have had it for a less than a year . When I turn it on it makes a very loud noise where the mist comes at the base . Is there anything I can do to...
unfortunately thats the noiise a humidifier makes perhaps there are less noiser models on the market now you know as time goes by so technology becomes more amazing.
Nov 10, 2014 | Humidifiers
Noisy start-up
If it is a vibrating motor noise, then some oil may help but make sureit doesn't drop into the tank. The little Motors used in these things have a limited lifetime and bearings and corrosion a of insulated iron plates that the copper wire of the motor coils wrap around do tend to corrode and lose their efficiency.
Otherwise, try a bit of foam padding to isolate the tank from the motor assembly - there might be some slight vibration there.
Mar 13, 2014 | Crane Evaporative Cool Mist Drop Shape...
Humidifier makes noise
I reckon you should toss it out as you don't really need it as it makes the air damp and mold will start forming inside the walls and create a health hazard.
Jan 07, 2018 | Humidifiers
Vibration in water feed
I have a General Aire humidifier on my furnace. I was having the same issue with vibration noise. I took the solenoid off and took it apart. There is a part that had a screen and a very small hole. I cleaned all the parts in my ultrasonic cleaner. The I reassembled the solenoid. It had an electromagnet that was held on by one nut. I reinstalled the solenoid mechanism and started the system. I had way better water flow, but still some vibration. I tightened the nut holding the solenoid and electromagnet together and the vibration stopped.
Jan 22, 2013 | General Filters 1099-LH Humidifier
Have an HE225A, B By-pass Flow thru humidifier about 9 yrs old. Just change the antimicrobial pad with recommended Aprilair 110/220 and when the furnace comes on, there is a loud, hum-like, vibrating noise...
Make sure the new pad you installed is in the right position. The pad is marked with a black dot about the size of a quarter. This end should be up for proper water flow through the pad.I fwater flow is being restricted at the pad the vibrating nosie that you are hearing is the dry portion of the pad vibrating agaist the platic housing of the humidifier. This noise stops once the pad has absorb enough water in this area of the pad.
Jan 23, 2011 | Honeywell HE220A1019 Whole House...
Feb 03, 2010 | Aprilaire 550 Humidifier
Loud noise
Replace the water valve... It"s vibrating when closing. Do you have hot water feeding the unit?
Oct 22, 2008 | Aprilaire 550 Humidifier
Humidifier makes a huge noise and no mist
According to the Crane's Troubleshooting section:
The power light is green but there is no mist being emitted:
- Check that there is water in the tank.
- Check for possible lime deposits on the water level sensor or the nebulizer.
- Make sure that nothing blocks the vapor output slots.
- Check that the fan vent on bottom of humidifier is not blocked.
- Empty the humidifier and rinse the water basin with cool tap water and allow to dry for 15 to 30 min.
This next part may or may not be relevant.
Humidifier power light is staying red and not turning green. Or, Humidifier is working then stops:
- Ensure that water level sensor is assembled properly.
- Clean water float.
- Call service center and request replacement water float.
Barring that, here is the service center contact info:
Dart Warehouse Corporation
Tel: 1-888-599-0952 (Business hours Mon-Fri 9:00 am - 4:00 pm Ct)
Website: http://www.crane-usa.com
1835 Ferry Road
Naperville, Illinois 60563
Jan 28, 2008 | Crane Cow Humidifier
Noisy humidifier
A noisy humidifier may be the result of an unlubricated fan motor or a drive mechanism clogged by debris. Periodically clean the water reservoir, fan, and nozzle to ensure that they are clean and working properly. To keep your humidifier working smoothly and efficiently, lubricate the fan motor bearings with SAE #20 oil. Be sure to consult your owner?s manual for proper care and maintenance procedures. If it seems loose, vibrating parts are causing the noise: 1) Disconnect the power. 2) Remove the cover and look for any vibrating parts. Tighten screws, if necessary. 3) Wiggle the fan to see if it is loose on its shaft. If it is, tighten the mounting fasteners. Lubricate the motor's bearings if suggested in your owner's manual. 4) If it still makes noise, call an appliance repairperson or take the unit into an appliance repair shop.
Jan 18, 2006 | Honeywell HCM530 Humidifier
Humidifiers Logo
66 people viewed this question
Top Humidifiers Experts
Paul Carew
Dennis
Are you a Humidifier Expert? Answer questions, earn points and help others
