Cartridge basket does not react? - Office Equipment & Supplies
Where is ink cartridge located?
This tis a Direct Line Thermal printer and does not use a cartridge. You use special paper that is chemically coated to react to print. http://www.newegg.com/Product/Product.aspx?Item=N82E16828154100
Apr 21, 2016 | Star Micronics TSP650 Series - TSP650...
I receive the code error 31.06 Defective Imaging Kit
Please try to do the following steps
1. Reseat all cartridges and Imaging Basket.
2. Remove Imaging Unit. To see the complete instructions on how to remove/replace the Imaging Unit, click the link http://bit.ly/jhK9fF
3. Clean the HVPS (high voltage power supply) and POGO pins and the corresponding electrical contact on the Imaging Unit with a clean, dry cloth. Click on the link http://bit.ly/jv58Nj to see the POGO pins location.
4. Replace all cartridges and Image Basket (you need to send bad cartridges back).
5. If supplies replacement doesn
Jun 30, 2011 | Lexmark X544dn All-In-One Laser Printer
We have a lexmark 544 and i have changed the imaging kit and it says we have a defective imaging kit
2. Remove Imaging Unit. To see the complete instructions on how to remove/replace the Imaging Unit, click this link http://bit.ly/jhK9fF
3. Clean the HVPS and POGO pins and the corresponding electrical contact on the Imaging Unit with a clean, dry cloth. Click link http://bit.ly/qxU9mD to see the POGO pins location.
If issue not resolve, contact Lexmark Technical Support
Feb 09, 2011 | Lexmark X544dn All-In-One Laser Printer
The screen says digital imaging kit is defective 31.06
Feb 03, 2011 | Lexmark X544dn All-In-One Laser Printer
I've changed the ink and still showing check ink tank
The "ink tank" can be compared to a garbage-basket -- excess ink from the ink-jets collects in that tank. When the garbage-basket, or the tank, is full, you must empty it. Changing the ink-cartridges (putting more food into the refrigerator) does not empty the ink-tank (garbage-basket).
Jan 21, 2011 | Canon PIXMA MP130 All-In-One InkJet...
How do I clean my pot ?
Rule#1: NEVER immerse the percolator in water--there are electrical components in the plastic base that will not react well to that kind of treatment.
The outside, cover, basket and stem can be cleaned with warm, soapy water. You can fill the pot with warm soapy water as well, although to remove mineral deposits and the like, it's recommended you periodically run a brew cycle (with stem and basket in place) using a solution of 50% vinegar and 50% water. To remove tougher stains, you might want to instead try dip-it coffeemaker cleaner.
Jan 11, 2011 | Faberware FCP280 Coffee Maker
How to remove drum and ink
Open the front door, latch is in the middle on top front, swing the door down.
The toner cartridge sits inside the drum unit, you must take the all drum unit out before taking the toner cartridge out.
You can see the toner cartridge sitting right inside the printer (after opening the door), lift up the "basket" that the toner cartridge is sitting in and after you lift pull it out, and lay it on a table, make sure not to expose it to the sun. Unlatch the toner cartridge by pushing on the tab on both side of the toner cartridge and lift the toner cartridge out of the drum unit ("basket").
Dec 14, 2010 | Brother HL 2140 Laser Printer
Mp780 wrong cartridge - all cartridges are canon
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can also be poor ink cartridge contacts
Sep 29, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
How do we empty the waste basket?
The "waste basket" is to indicate that the waste toner area in the drum cartridge is full. If the copy quality is still ok you may be able to empty the waste by removing the drum cartridge from the machine and removing the opaque piece from the left side and dumping it out. BE CAREFUL this can be very very messy. toner is a very fine powder and will get all over the place if caution is not used.
Jan 07, 2009 | Canon NP 7130 Black and White Copier
Knife Holder and tine adjuster fall off
This problem would be so easy for Kenmore to correct by simply redesigning and replacing these knife holders....but Until such time as Kenmore responsibly reacts, I recommend remounting the holder to the side of the basket at a better angle using your knife with the longest handle as a guide) usng plastic ties such as used as handcuffs and cable ties. (Not pretty, but effective).
Nov 01, 2008 | Kenmore 17382 / 17384 / 17389 Built-in...
23 people viewed this question
k24674
jasbo
jasbo
