Question about Epson Office Equipment & Supplies
My printer epson xp212,wifi light flashes green and orange,power buttun flashes green and the paper and ink flashes orange. what is wronge?
SOURCE: Epson stylus photo R1800 printer
http://www.fixyourownprinter.com/forums/printer/35608
this website will answer all your problems
Posted on May 27, 2008
SOURCE: Epson stylus 880 printer
"Turn the printer on while holding down both the ink and paper buttons. When the paper light flashes release both buttons", then hold down the ink button for approx. half a minute until the printer lights flash again then release it. That resets the printer.”
Posted on Jun 03, 2008
yooperbud
  • 8637 Answers
SOURCE: Ink cartridges wont accept in Epson D120 printer
Normal 0 Driver could be corrupt.
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 24, 2009
SOURCE: epson stylus photo 950 printer flashing lights
I had the same Problem and checked the solution:
This is a Printer Maintenance request.
Ink Overflow -
you sould change the waste ink pads under the printer mechanic.
Solution:
Posted on Feb 16, 2009
websnail
  • 419 Answers
SOURCE: MY EPSON D88 PRINTER HAS 2 FLASHING LIGHTS
This is usually caused by a problem with the chip(s) on the new cartridge.
Check that the chips are clean, and are correctly installed on the cartridge(s) (some can be knocked out of alignment and thus not connect properly).
Also check for any damage to the tiny wires in the printhead where the cartridge sits.. These can also become soiled with fluff, etc... Be VERY careful if you try to clean these as they are very delicate and if broken off you will have a broken printer.
Last thing is of course to check you have the correct cartridges... A common one with the D88 is to have C86 cartridges which are not compatible at all (different' chips!).
Hope that helps.
Posted on Feb 17, 2009
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
The screen on the printer is flashing e then 3 then 0. I have unplugged the printer, unconnected the cable then started it all back up but it keeps flashing that
If it is a Canon printer:
Clear the EEPROM
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD over current error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
Nov 16, 2010 | Office Equipment & Supplies
Power light (or Alarm and Power lights) alternate(s) between orange and green After long green flash, there are 2 or more alternating orange and green flashes. There may also be a Service Error message on...
Try resetting the printer by unplugging the printer from the power source for 5 mins. and they make sure ink is full and paper is loaded and not jammed. If not resolved carefully remove all ink cart from machine without touching and ink cart metal contacts, reseat the ink cart and reset and the printer.
Feb 21, 2010 | Canon i850 InkJet Photo Printer
The middle light keeps flashing 7 times then stops then repeats. the other button to change the paper type. i dont think its a ink issue possibly a paper one.
This mean multiple ink tanks of the same color installed or Ink tank in a wrong position.Check your ink tanks.This ink tanks has a memory chip.Sometimes this chip fails.
If the green light blinks with a orange 7 times this mean the waste ink tank is full.Follow this:
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Nov 04, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Problem on a canon 3100
The Power Light Flashes Orange - Error Codes When an error occurs, the power light flashes orange. The number of orange flashes followed by a long green flash indicates the cause of the problem.
Two orange flashes: Out of paper, paper jam, or paper feed error
If no paper is loaded in the auto sheet feeder, or if the paper is not loaded correctly, set the paper correctly and press the Resume button on the printer to continue printing.
Three orange flashes: Paper jam
If paper has jammed in the printer, carefully remove the jam and press the Resume button to continue printing.
Four orange flashes: A tank inside the BJ cartridge (print head) is out of ink
Replace the empty BJ tank and press the Resume button to continue printing.
Five orange flashes: BJ cartridge is not installed properly
Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely.
Six orange flashes: BJ cartridge (printhead) is not installed
Seven orange flashes: BJ cartridge (printhead) is defective
Remove the BJ cartridge and check that the contacts on the cartridge and cartridge holder are clean. Make sure the orange protective cap and tape have been removed and reinstall the cartridge. If the error occurs again after you resume operation, you may need to replace the BJ cartridge.
Eight orange flashes: Waste ink absorber almost full
The printer has a built-in waste ink absorber to hold the ink that is consumed during print head cleaning. This error indicates that the waste ink absorber is nearly full. Press the Resume button to skip the error so you can continue printing.
The POWER light flashes orange and green alternately: Service error
A service error means the printer requires the attention of a qualified technician. Count the number of flashes. (You may be asked this information.)
Feb 02, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Canon MP 160 flashing 2E
Found this on our site:
How to clear Error Code Canon printers MP150 MP160
CANNON Printers MP150/MP160 ERROR CODE
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
Direct Printing
E22 Carriage error
E29 EEPROM error
E35 15 USB Host VBUD overcurrent error - USB
try this method
service mode. (Waiting formenu selection)
button pressing
procedures below.
procedures below.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 22, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Oct 08, 2007 | Epson Stylus 880 InkJet Color Printer
41 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
