Question about Cooktops
Should my Beto ceramic hob get hot around the touch controls
Hi my beloved QHC 64402t gets hot at the touch controls and is hot on the fingers when selecting the heat and it is already on
Master_Tech
  • 770 Answers
SOURCE: Miele Ceramic Hob Model KM 131
check your email
Posted on Feb 16, 2008
SOURCE: got a diplomat ceramic hob with no instructions
If the KEY lock is on (key botton flashes when switched on) ... touch AND HOLD the lock symbol for AT LEAST TWO seconds until it beeps, then hold the on/off button for AT LEAST 2 SECS.
If the CHILD lock is on ([L] on all displays when switched on), then:
1)Hold the on switch for TWO secs min (unit swtiches on) ...then
2) touch AND HOLD the + AND - for AT LEAST 2 secs
3) touch the - button once again.
Posted on Mar 05, 2009
SOURCE: Stoves 700CTH hob
I have a Stoves 900 CTH with the same problem. Its been like it for about 6 months and we're still able to get it going eventually.
If you turn the power on at the mains and leave it beeping for about 2 hrs then press the power on touch button. You should see all the "0."s flashing. When the flashing and beeping goes slow try pressing one of the hob buttons alot until the little dot illuminates next to the 0 then quickly lit the + button.
It sometimes works after 5 mins but other times it takes 20-30mins and is a real pain in the ****.
I did ring Stoves a while back and they quoted me £190 for the pcb but I hardly use it so just lived with it as it is but I finally had enough tonight and done a web search which turned up this thread.
I've just pulled it to bits to see if I could locate this "C17" but not 100% sure what I'm looking for.
29792d1.jpg Is it the big silver thing in the center with 5B RVJ on it?
Posted on Oct 13, 2009
  • 254 Answers
SOURCE: I can't unset the child safety lock on my diplomat ceramic hob
get the model number if a cooktop will be underneatth on sticker.... go to kitchaid.com and locate thier manuals and literature section where u can download a copy or print one out.... hope this helps
Posted on Feb 06, 2010
SOURCE: Safety lock on Neff hob
I have a Neff T4344N0/08. I cannot stop all four hobs flashing - ie: I press the 'on' button all four flash, I then choose which one I want to use plus the number but they all keep flashing instead of stopping after the usual three or four. Please help - have I pressed something I shouldn't, perhaps a child lock?
Posted on Apr 20, 2010
TOUCH CONTROL HOB (SCHOTT CERAM) GLASS CRACKED
Hi. Yes you can buy a new glass. Most of the come with frame top now. If you get me the model # I can look this up for you and get you an idea on cost.
Vic
May 18, 2009 | Cooktops
Fagor hob touch control
Our hob has the same problem. I would really like to know the reason for this! Try using a rubber eraser instead of your finger - this works every time with our hob. Covering Up and Down arrows with the rubber, zeros it instantly just like using both fingers. Hope this helps.
Jan 28, 2009 | Fagor 31 in. VFA-78S Electric Cooktop
Cant switch on hob
gud day,the ceramic hob is very sensitive to operate if u not read the manual.after u unlock the switch go to the control of the hob wat area u want to operate by touching the sensor then if u see the zero # touch again the area,positive side to increase the heat 1-9 the standard control heat.some model & brand have a different operational procedure,try to read the manual 1st or check the voltage of the unit coz the ceramic have a 4voltage standard for different country. tnx gerbee
Jan 26, 2009 | Neff 23 in. T1443 Electric Cooktop
Hob turns off
hi im gerbee my suggestion is replace the pcv control wat brand u have,always also in philipines the electric hob is so very sensitive,the pcv cotrol is not repairable.or next time u by a new one gas cooktop more ok compare to electric ceramic hob, or use electric ceramic hob w/knob control compare to sensor type,i think the part of the sensor or pcv control is so very expensive,that why i buy an another one.dont try to repair more difficult to com.tnx
Nov 24, 2008 | AEG 23 in. 6410KF-N Electric Cooktop
Cooktops Logo
111 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
