Question about Avia Audio Players & Recorders
A power cable volts and watts to power home theater
How much electricity to power avia home theater
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 28 Answers
Voltage X current = Power
Power / Current = voltage
power / voltage = current (amps)
Posted on Jan 01, 2017
How to change the indicated voltage which is indicated volt adjustment
Where the power cord plugs into the unit look for a red slide switch. One side will say 220 and the other will say 120. Use a finger nail to change the switch to match your local power voltage.
Sep 21, 2015 | Panasonic 330 Watts 5.1 Channel DVD Home...
User manual
You get surround sound only if you hook up your Optical out from your TV to the Optical IN on the HT-H4500 using an optical audio cable. You may have to buy such a cable if one was not included with the TV or the home theater.
Follow the link below and click on the Manual tab.
Samsung Home Theater System HT H4500 Home Audio
Oct 04, 2014 | Samsung HT-H4500ZA Home Theater System 5.1...
I have the phillips hts5580w. how much wattage output does it have? an does this system have a built in amplifier as well?
Anything that drives speakers must be or have amplifiers. They are rated in watts.
http://www.retrevo.com/support/Philips-HTS5580W-Home-Theater-Systems-manual/id/23889dj591/t/2/
It says the power output, presumably in the phoniest of terms - all channels summed together with THIRTY PRECENT DISTORTION which would seriously risk any speaker system and the health of tha amps themselves - is 1000 watts. This is a joke, a lie, marekting at its worst, especially when the totoal power consumption of the unit (that power whci it drwas from the wall outlet) is ONLY 135 watts.
Philips must be onto something no one else has ever seen - they get six times as much sound energy out of the unit as the amount of electricity that goes into it, plus all that heat. That, my friend, would be a miracle and would put all the reputable amp maufacturers, who rate their amps in honest watts per channel at certain (vanishingly low) distortion figures, to shame.
If you push this unit into sustained 30% distortion it will self destruct.
Aug 04, 2011 | Philips HTS5580W Theater System
I have a Samsung HT-C550, is there a separate power switch or something for the Sub-woofer? It seems to not have a lot of power.
If it is making any sound at all then it is "on".
Check your subwoofer function and level with Test Tones (page 29) and Auto Sound Calibration (page 30) and don't expect too much from an 8-lb 6.5" subwoofer and a multichannel amp that only draws 75 watts of electricity. Maybe place the sub nearer to a corner.
Register and download the manual for free audio.manualsonline.com
http://audio.manualsonline.com/search.html?q=Samsung+HT-C550
Mar 23, 2011 | Samsung Ht-c550 5.1 Dvd Home Theater...
Can i put an extra sub woofer on my lg da3525 via the woofer out socket and what plug do i require to do this
How to Connect 2 Subwoofers to One Receiver
Subwoofers produce the deep bass sounds that give home theater the realism of being at the movies. A good subwoofer can rattle the walls during action sequences, while adding depth to recorded music and a heightened sense of feeling in the midst of a televised sporting event. Because most home theater receivers are equipped with a single subwoofer jack, connecting a second subwoofer requires a simple audio adapter available at electronics stores. Self-powered subwoofers have their own built-in amplifiers to drive the bass speakers, so they cannot drain power on the main receiver in a system and thus pose no danger to the equipment, even when an extra subwoofer is connected.
Things You'll Need:
Home theater receiver
Y-adapter with RCA jacks on two ends and an RCA plug on the other, available at electronics stores.
2 RCA subwoofer cables
2 subwoofers
Instructions
Plug the Y-adapter into the home theater receiver's "Subwoofer OUT" jack.
Connect an RCA subwoofer cable to each jack on the Y adapter and route the cables to the subwoofers in the room. Because subwoofers deliver an omnidirectional sound, the boxes can be placed anywhere they won't get in the way, but within reach of an electrical outlet..
Plug an RCA cable into the "Sub IN" jack on the back of each subwoofer.
Connect the subwoofers to wall outlets and turn on each unit by pressing the power button, typically located on the back panel.
Adjust the volume and crossover settings on each subwoofer as desired. The crossover adjustment knob tells the subwppfer which low-end frequencies to reproduce from the audio signal, such as a movie on DVD. All frequencies higher than the crossover setting will be transferred to the other speakers connected to the receiver.
Tips & Warnings
Use subwoofers that are closely matched in power, as rated in watts, when using two subwoofers in a home theater setup.
Disconnect the subwoofers from the power supply while making the audio connections.
Have a nice day...
Feb 19, 2011 | LG DA-3525 Theater System
Sony Home Theater already connected to TV with HDMI cable, now I have blue ray player without any cables, what do I need to get best result?
for the past month i have been shopping for the perfect home theater system and have narrowed it down to a bose system,a sony system and a paramax p510...i have listened to all 3 systems and have found the paramax to be the better system not a cheaper system but seem more bang for my buck at 3200$,a very powerful tube amp and downfiring sub maxes out at 2000 watts...
Nov 14, 2009 | Bose 321GS Series II System
Power conversion
If you have 110 - 120 volts AC at 60Hz, then the mixer must be bad. Unless 50 Watts isn't enough. Does the voltage drop when you plug in the Mixer to the convertor?
Geno
Mar 05, 2008 | Denon Dn-X1500 Professional DJ Mixer...
Converter needed
If your unit is from the USA, 120 volt/ 300 watts.
EU is 220-240V / 300 Watts. Best choice is to go to Bose service center in EU and have your transformer inside your box replaced with 220-240V for EU operation. That way you don't have to worry about a converter. If not, 2nd choice is buy a step-down transformer 220-240V input and 120 Volt output that can handle 300Watts.
Good Luck.
Dec 22, 2007 | Bose 3 2 1 GSX System
42 people viewed this question
Top Avia Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Avia Audio Player and Recorder Expert? Answer questions, earn points and help others
