Question about Retail Supplies
How do I zero out the total on my GT balance in my z report on my used casio seG1
On my Casio tk-t200 when I take the Z reading at teh end of the shift the total is cumulative and not for teh shift
It sounds like someone has taken an X report instead of Z. X will read but not reset. It will normally be the report BEFORE the one you just did. Check the top of the reports and they should show a Z at the top. If one shows an X, the next one will be two shifts of data. Make sure the key is in Z mode for re-zeroing.
If anyone needs a Casio TK-T200 manual, one of the users has it here:
Casio TK T200 users and programming manual PDF
Mar 17, 2014 | Casio Parts Cash Register PC Desktop
How do I get my Sharp xe-a202 to not give all 99 dept. on the Z totals?
Look in the settings and find zero skip for department report. Turn it on
Mar 12, 2013 | Casio Parts Cash Register PC Desktop
HOW CAN I DO A Z READ AGAIN AS THE PAPER RUN OUT
On some models the Z report will not reset until the paper has been re-filled and the report is run a second time. If the next report comes out with a zero balance, then it has already reset and you have lost the report. If your machine has an electronic journal then you can recover it from the journal. It all depends upon your model of machine.
Jun 23, 2011 | Casio Parts Cash Register PC Desktop
I have acquired an old casio 240 cr and need to reset all the totals can you tell me how I do this please
Great old machines. The 240CR is only simple, so you just turn the key to Z mode and press CASH to re-set the report. The grand total (GT) may not reset because it is usually a security feature, but you don't need it. Just ignore any GT on the report. all other totals should be cleared and if you do it each day, you'll get the figures you need.
If anyone needs more information, the 240CR manuals are here:
Casio 240CR User manual: http://the-checkout-tech.com/manuals/cashregisters/Casio_240CR_operators_manual.html
Casio 240CR Service (repair) manual: http://the-checkout-tech.com/manuals/cashregisters/Casio_200CR_and_240CR_and_PCR-360_and_PCR-365_and_PCR-465_service_manual.html
Mar 21, 2011 | Casio Parts Cash Register PC Desktop
I just bought a Casio PCR T275 cash register and would like to zero out the "Z" report. Can you tell me how?
Try turning the key to Z mode and press CASH. That should clear the main report except for the grand totals which can't be reset. Just ignore them as they are not needed for daily reporting. If you want to remove the GT from the report, there is usually a setting. See how you get on. -----------------------------------------------------------------------------------------------------------------
If anyone needs more information, the Casio PCR-T275 manual is here: http://the-checkout-tech.com/manuals/cashregisters/Casio_PCR-T275_users_manual.html
Mar 14, 2011 | Casio Parts Cash Register PC Desktop
How do i reset my grand sales on a casio TE 2000
very simple solution with no reprogramming of the unit.
- in Z mode: make a report and read the grand total sales amount
- in RF mode make a refund of that amount
- in Z mode make a report again to check that the grand sales is zero.
Feb 24, 2011 | Casio Parts Cash Register PC Desktop
Reconciling
If you are trying to reconcile to your bank balance, you should not be reviewing the "deposit detail" report.
1) Go to "Banking" then "Reconcile"
2) If the "Opening Balance" is incorrect, then close the "reconcile" window and go to "Reports" then "Banking" then "Bank Reconciliation Discrepancy" report. (This report will reveal what changed after your last successful reconciliation).
3) If the "Opening Balance" is correct, then you want to press "continue" to focus on the bottom of the window, which reveals "total deposits marked as cleared". If you have duplicates, you will see them on the right side of the screen, but the ultimate goal is to have a "Deposits Total" (in QuickBooks) that agrees with the "Deposits Total" (per Bank Statement).
The "Deposit Detail" report is a "Journal Report" to show you details of historical deposit records, Has nothing to do with "reconciling" your current bank balance.
Feb 08, 2010 | Intuit QuickBooks: Pro 2005 for PC
Casio Exilim EX-S600D creates "white pictures"
Check the ISO setting...it may be too high. Also, check the white balance.
Sep 04, 2009 | Casio Exilim EX-S500 Digital Camera
Grand Total Clear z/1 z/2
Hi. On most machines, the Grand total is non resettable and is just ignored if you don't want to track the total sales of the machine long-term. It should not affect the daily totals. The rest of the report should reset at the end of the day. If you don't see CASH totals and departments etc returning to zero, then there is another problem. If you still want to try to stop the GT on the reports, tell me the brand and model number and I'll see if it can be forced from the report.
Mark
Nov 24, 2008 | Casio Parts Cash Register PC Desktop
Retail Supplies Logo
Top Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Retail Supply Expert? Answer questions, earn points and help others
