Question about Honeywell Humidifiers
Mymodel hmc-6009 honeywell humidifer the fan runs constantly
3 Suggested Answers
maklean
  • 1665 Answers
SOURCE: Honeywell HCM 560 Cool Mist Humidifer
Hi have a look at this:
http://www.appliancefactoryparts.com/content/pdfs/111854.pdf
Posted on Jan 20, 2008
SOURCE: Having trouble finding a replacement wick.
Try honeywell.com/support parts.
Posted on Mar 12, 2010
Service light on Honeywell humidifier
Sounds like a Water Level Sensor problem. Read the service manual, pages 51 and 53.
http://www.forwardthinking.honeywell.com/related_links/humidification/69_2285.pdf
Unplug the power cord. Turn OFF water. Remove the Water Level Sensor - One screw holds down the spring clip. Remove water scale in the compartment and on the Sensor. Test Sensor with an ohm meter. If OK, reassemble and try again. If bad, replace the sensor.
If you have heavy scale buildup in the sensor compartment, you need better water filtration. Your problems are just starting. This system can be very difficult to clean thoroughly.
Nov 15, 2012 | Honeywell Truesteam HM512W1005...
The Honeywell HCM-6009 humidifier unit no longer turns on. This was an abrupt change--not sure what happened. It was working fine one day, and the next day it was dead. Is there anything I can do to...
Save the time and frustration these units are hard to work on. Make sure there is power to the unit other than that throw it away and buy a new one for $100.
Aug 19, 2011 | Honeywell QuietCare HCM-6009 Humidifier
I have random pipe shocking heavyly.
It sounds like your solonoid valve on the humidifier was slamming shut cause the water hammer, no call for heat, no humidifer.
Apr 20, 2009 | Honeywell HE365 Humidifier
My HE260A is discharging too much water
these are flow thru models and a lot of water passes thru them. The instructions say to not limit the water by closing valve at all!
Feb 22, 2009 | Honeywell HE220A1019 Whole House...
Honeywell 6013i new machine will light up...
Unplug the machine and take both the water jugs off. Take the motor unit off and flip it over. Plug it into an outlet and press down the small silver contact at the bottom of the motor. When you press this down, a connection is made and the motor should turn on (Don't worry about being electrocuted, this is perfectly safe). If the motor turns on and runs at various fan speeds, you know it's not an issue with the main unit.
When looking at the base, on the left side you'll notice a plastic piece sticking up that's held down with a plastic shroud and 2 screws. This is you water level sensor. When the water level raises up, this also rises and hits the silver contact on the bottom of the motor. Make sure this isn't binding up(I suggest you clean it) I had the same issue with my HMC-6012i, lights were on at the indicated humidity level but the motor would never run. Take the unit apart, clean it out and follow my instructions. It should fire up (Mine is running right now :) )
Dec 22, 2008 | Honeywell QuietCare HCM-6013i Humidifier
Install HE220 HoneyWell , humidity not increasing in the house.
You can try installing the water line to your hot water if it is installed on cold line for more humidification. You should make sure your humidistat is up line 6" @least from humidifier for proper humidification measurement.
Feb 26, 2008 | Honeywell HE220A1019 Whole House...
HE120 By-pass humidifer - Sponge Drum not rotating!!
Model HE908A drum is turning but we get no condensation
Dec 25, 2007 | Honeywell HE120 Humidifier
Humidifiers Logo
Top Honeywell Humidifiers Experts
Dennis
Simon Benzekri
Level 1 Expert
Bill Long
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
