Question about McCulloch Garden
EM 250 - 14" clutch drum sprocket number
McCulloch EM 250 electric chainsaw.
    Top Expert:
  • McCulloch Master
  • 2,372 Answers
I recommend contacting your local authorized service center directly.
You may contact the manufacturer, download manuals, check fuel/oil ratios, find your local service center, and view other resources using these links:
Contact us
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
User manuals McCulloch Service
I trust this information proves beneficial.
EM 250 - 14
Posted on Feb 19, 2018
dennisgladx
  • 52 Answers
SOURCE: Poulan Wildthing 18" chainsaw 2375 sprocket/drum replacement
mso 9]> Normal 0 false false false MicrosoftInternetExplorer4 mso 9]> mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> mso 10]> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi tchild,
my name is Dennis Gladx and I can assist you with the problem of getting the sprocket off of the crankshaft of your chainsaw.
To remove the centrifugal clutch and sprocket you unscrew it from the crankshaft and it has a left hand thread. Also a little trick to remove anything from a crankshaft that could turn while you want to unscrew the item, Remove the spark plug and insert some rope into the cylinder for the piston to squeeze against and you will jam the piston without damage.
Glad to be of assistance Please rate this solution because I can learn from your rating. Thank you
Posted on Nov 08, 2008
steve_lima
  • 181 Answers
SOURCE: Husqvarna 357xp rim sprocket problem
there is a special tool to remove the clutch properly with out damage to the clutch or springs.it is so much easier to take it in some where and have the proper tool used.the tool is $45.00 to $65.00 to buy one.most dealer will only charge you a couple of bucks to remove it and install one for you,it only take a second to do.I,myself have made a couple of differant ones because chainsaw differ so much.let me know and maybe i can get you a picture of the one you need
Posted on Feb 11, 2009
  • 5 Answers
SOURCE: Where can i purchase sprocket for mastercraft
the new company is Troy-bilt but i found the part in a Mcculloch dealer
part # MC-6228-120104P
Posted on Jun 29, 2009
dontbother10
  • 2220 Answers
SOURCE: how to remove clutch. McCulloch 438 chainsaw.
I think its an outboard clutch, use this as a guide. A YouTube video shows the procedure using a Husqvarna 350 here:
http://www.youtube.com/watch?v=cdqkIuVNUQc
1. I cannot find an IPL for your saw, it may require special tools.
2. A length of starter cord or nylon rope may be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and be cut when the piston rises.
3. It is probably a left handed thread (tighten it to loosen it).
Let us know how it worked for you. GL
Lou
Posted on Sep 10, 2009
SOURCE: NEED INSTRUCTION MANUAL FOR MCCULLOCH 838 AS CHAINSAW
Found it at
http://www.mcculloch.biz/int/support/owners-manuals/?query=MAC+838&types=O
Posted on Apr 16, 2010
Testimonial: "Thanks exactly what i was after,thanks again."
I need a drive sprocket inner gear for a 14-inch McCulloch Mini Mac electric chainsaw I called the number that was on the saw and they couldn't seem to help me where can I find one
You can usually get part numbers from this site the search online to buy part, only problem is depending on age it may no longer be available. Hope this helps, Good luck.
http://www.barrettsmallengine.com/mcculloch/chainsawpartslist.html
Nov 19, 2016 | McCulloch Garden
Can I buy a clutch for this chainsaw
McCulloch MCC1514 14Inch 15 HP Electric Chain Saw ...
www.fixya.com/search/...mcculloch_mcc1514...15...electric/clutch_nut
McCulloch MCC1514 14Inch 15 HP Electric Chain Saw, clutch nut related issues. Get free help, solutions & advice from top McCulloch experts.
Jul 28, 2015 | McCulloch 14" Electric Chain Saw Mcc1514
McCulloch Chainsaw Gear Drive Sprocket stripped
Ken's Repair Have 9 totes of parts for McCulloch saw Weed eater Modal # and Serial # Please
Feb 24, 2014 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Chain moves when trying to start
Either the sprocket bearing is dry or has broken up, or the clutch spring has broken, either way you need to remove the side cover, bar and chain, if the drum does not turn freely it is the bearing in the centre giving problems, you should also be able to see the clutch and springs from here, check there condition.
Aug 14, 2013 | McCulloch 14" Electric Chain Saw Mcc1514
Motor does not turn sprocket
I am assuming the kickback chain brake is not on. Push it forward to make sure. If the engine revs but the drive sprocket will not turn and the chain is adjusted correctly then the centrifugal clutch is bad or the spring is broken. You will have to take the clutch out to see exactly what has broken.
Apr 25, 2010 | McCulloch 16" Electric Chain Saw 35 HP
Need a brochure for mcculloch em 450s
http://www.poulanpro.com/node4043.aspx
Enter your model number and you can download a manual. It's not accepting the em 450. Check model no.
Dec 06, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Poulan Super25DA old chainsaw from the mid 70's.
Call your local Power Equipment Dealers and ask if any of them deal with OREGON replacement parts.
OREGON makes clutch drum, chain and bar combinations in the thousands!
NOTE: Along with clutch drum and chain replacement, your bar will need to be changed also, as the sprocket-tip in the nose of the bar will be a different pitch.
Oct 01, 2009 | Garden
Unit works but chain stops when pressure applyed, what oil goes resevior.
Does the motor continue to run when chain stops? Electric saws usually don't have a clutch, so I would look for badly-worn chain sprocket, or a possible sheared key in the sprocket hub, or a loose mounting nut. Remove the chain and bar, try to turn the sprocket by hand (wear good gloves). There may be some type of overload clutch built into the sprocket.
May 09, 2009 | McCulloch 10" Electric Pole / Chain Saw
Garden Logo
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
