Question about Electrolux Dishwashers
Electrolux EW30CC55GS3 is getting an error code 32. How can I reset ?
This is a drop in hybrid induction stove top. I have already turned off electric for 5 minutes, it did not reset.
localwonder
  • 6784 Answers
SOURCE: stove top elements f1 error code
Hi. you can try to reset the electronic oven control by unplugging the unit for 3 mins. if the problem still exist, you will have to replace the clock/control(electronic range control).
please rate and god bless:)
Posted on Apr 02, 2009
protek480
  • 1723 Answers
SOURCE: Electrolux dryer error code e61
There is a 'tech sheet' in the back pf the dryer. Unplug machine, Remove the access panel on the back to get to it. Reach in and it should be there. It will tell you how to do a button check. You have to enter a test mode through the buttons.
The E 61 is a stuck button.
Enter function test mode and perform key
stuck closed (active). (button) test to determine which button is at
fault. Carefully free the and perform the test
again. If button is free but the key struck code
still exists, replace electronic control.
Posted on Sep 25, 2009
  • 3 Answers
SOURCE: error code on new electrolux diswasher. How do I
unplug it
Posted on Jan 03, 2010
  • 679 Answers
SOURCE: My Kenmore Elite electric stove
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
An overheating magnetron can be :
  • operating oven without cover(s) in place
  • wrong magnetron installed in oven
  • an old or otherwise failing magnetron
  • cracked magnetron magnet
  • improper power line voltage (US homes should be 110-125VAC)
  • foods low in moisture (popcorn & bacon, e.g. - add 1/2 cup of water in rear oven)
  • failed or inoperable cooling fan or hood vent exhaust fan
  • deteriorating foam weatherstripping seals in air ducts or on outside cover
  • blocked air vents (dust, animal nest debris, insufficient free air space behind & around oven, etc.)
  • clogged or greasy charcoal filter or grease filter
  • blocked duct in hood vent exhaust
I suspect a failure or the fan, clogged filter or bad magnetron.
I appreciate your thoughtful rating of my answer.
Posted on Feb 07, 2011
reyjoshua07
  • 1157 Answers
SOURCE: GE Profile electric range: I'm getting an F0
Hi greengib,
The Failure code "F0" description is a stuck touchpad. Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.
Hope it helps.
Thank you for using FixYa.
Posted on Apr 20, 2011
Displays error 40. Why won't it turn on?
Hi Dolores, I understand that your cooktop will not turn on after receiving an error code "40". Usually this error code can indicate a communication error between the Induction Module, Relay Board, and Control Board. I would also recommend doing a hard reset by unplugging or turning the household power breaker off to the appliance for five to ten minutes. If the problem persists, please reach out to a professional technician. Hope this helps! -JK
Oct 01, 2015 | Electrolux 36" Electric Hybrid Induction...
Prestige induction cooktop showing error E4
Good Afternoon friend, I appreciate your inquiry!
Typically on an Electrolux induction cooktop the "E4" error code stands for key sensor for timer. Which means you could be experiencing an issue with the right board, center board, or left board. I would perform a reset on your cooktop and you can do that by flipping the household circuit breaker off for ten minutes.
If that does not assist with clearing any false error codes or the error "E4" continues to display I would suggest seeking assistance from a professional for proper diagnosis and repair. Hopefully this helps. -Matt
Oct 18, 2014 | Electrolux 36" Electric Hybrid Induction...
I was boiling water for potatoes on the Electrolux induction cooktop last night. Only using one of the five burners when I heard a "pop" sound and possibly a flash of light. Error code we have is EO
Hi Gail, I am happy to assist you!
It appears the main control has detected a faulty or error condition. "E0" should be followed by two more digits to indicate which error has occurred. Let's try turning electrical power supply off. It is necessary to wait roughly ten minutes to reset cook-top main controls. If resetting the power does not correct the issue or provides a new error code, at this point, I would recommend having a service technician to diagnose the problem before investing in unnecessary parts.
Dec 20, 2013 | Electrolux 36" Electric Hybrid Induction...
Induction error e6
Hello it07002 - You may try and reset the induction cook top by disconnecting the power to the unit for up to 30 seconds by flipping the circuit breaker off and back on. This often clears most false error codes. If the error code does not clear, then the unit more than likely may be experiencing an issue with the EOC (Electronic Oven Control) and/or user interface board. This is not a typical do it yourself job; please consult a professional or your manufacturer.
May 07, 2013 | Electrolux 36" Electric Hybrid Induction...
Electrolux E 95 code
Hello Robert - Typically, error code E95 indicates a power voltage miscommunication to the main components of the unit. You may try and reset the induction cook top by disconnecting the power to the unit for up to 30 seconds by flipping the circuit breaker off and back on. This often clears most false error codes. If the error code does not clear, then I would recommend contacting a professional to proceed further.
Apr 25, 2013 | Electrolux 36" Electric Hybrid Induction...
Error message on my electrolux INDUCTION STOVE TOP
Hello - Typically error code E on Electrolux induction cook top indicates an error with the user interface board/control board. Contact a professional to move forward accurately and properly diagnose/repair the unit.
Oct 30, 2012 | Electrolux ICON Designer Series E36IC80ISS...
My electrolux iduction cook top sends error across the whole bord when I put anythng on the inductoin burner
You may try and reset the induction cook top by disconnecting the power to the unit for up to 30 seconds. This will clear most false error codes. You can disconnect power by flipping the circuit breaker off and back on. If the error code does not clear, then the unit more than likely can be experiencing an issue with the EOC and user interface board. This is not a typical do it yourself job; please consult a professional or your manufacturer.
Sep 11, 2012 | Electrolux 36" Electric Hybrid Induction...
ELECTROLUX ERROR CODE E95
Verify AC input voltage at the cooktop input. Verify AC main input cables, screws and jumpers. Verify the fuse resistance to be approximately 0 ohms on the Induction Module. Replace the Filter Board on the Induction Module.
Aug 07, 2012 | Electrolux 30" Electric Hybrid...
Water boiled over on the Right rear induction side. Stove shut off. Now the Right rear burner doesn't work and flashes and "F" when I set any temperature. Stove thinks I have the wrong type of...
Generally there is a number after the F. It sounds like some liquid got into the electrical, sometimes if you wait about a week for it to dry it will work. If not, you would need to call a service tech
always unplug electricity before attempting to repair on any electrical appliance
Sep 14, 2017 | Electrolux 30" Built-In Electric Cooktop -...
Dishwashers Logo
50 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
