Question about Coffee Makers & Espresso Machines
I have the 12 cup PC connoisseur coffee maker and can't figure out how to set the time. I set the alarm fine but not the time. Any help would be appreciated. Thank you
  • 4 Answers
SOURCE: Cuisinart DCC-2000 12-Cup Coffee Maker shuts off after brewing
Turn the function knob to Auto Off
Hold down the hour button til you see the clock display blinking
you can then use the Hour and Minute buttons to program how long you want the coffee maker to stay on.
You can choose from 0 minutes (seems to be what you have it set on now) to 4 hours.
Posted on Nov 15, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: self cleaning coffee maker
Unplug the coffeemaker for one full hour, and the self-cleaning light will go off.
Posted on Mar 24, 2009
CHA55Y
  • 13 Answers
SOURCE: My Starbucks Grand Barrista 12 cup coffee maker stopped working.
from what i can see they have pumpo issues..... try your warranty although i guess that'd be long gone after your many "years" of ownership.... anyway, get an expresso machine, they produce much better coffee by far :) Goodluck, CHA55Y....
Posted on Jun 14, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: How do I set the time on cuisinart coffee maker
Set the function knob to CLOCK
Press and hold the HR button for a few seconds if the clock display time is not flashing
Once display time is flashing:
Press and release the HR button a few times for it to advance - it will say "PM" on the display if it is set for PM
Press and release the MIN button to set the mins
Posted on Sep 29, 2009
SOURCE: my 12 cup cuisinart coffee pot keeps shutting off
I tried a solution someone posted on this site back in Dec and it worked, give it a try: "I called the company about the "shutting off after a brewing cycle" problem and they had me turn the dial to "auto off" and set the time to two hours. You do this by holding down the "hour" button until it blinks, and then press it again until you get the desired hours that the warming plate will be on. Hope this helps."
Posted on Jun 07, 2010
Can't set clock. 12:00 keeps flashing
SETTING THE CLOCK AND DELAY BREW TIME
To Set the Clock:
1.
Plug the power cord into a standard electrical outlet. The clock
will flash on the control panel to indicate that the time has not
been set yet.
2.
Press and hold the HOUR and MINUTE buttons until you reach
the current time. The AM or PM indicator will light at the bottom
of the display (Figure 1).
The clock is now set!
NOTE:
Pressing any button before setting the clock will cause the
clock to start keeping time from 12:00 a.m. You must set the clock
if you want to use the Delay Brew feature.
Nov 01, 2014 | Mr. Coffee 10-Cup OptimalBrew Thermal...
My coffee makers digital screen is not seen. Cannot set time or turn on coffee maker. Checked outlets all fine. Just purchased. Only used a few times.
The coffee maker has clearly a manufacturing flaw, from your description the thermal fuse has opened and is welded to the heating element. The only option is return the unit to the place of purchase.
May 28, 2011 | Mr. Coffee JWX27 12-Cup Coffee Maker
Cleaned my mr coffee pstx properly and the light will not go off . Unplugged it and everything help !!!
!!!!FIXED!!!!
I know this an old question, but I finally fixed mine. Hopefully this will help someone. I have a PSTX Mr. Coffee (10 cup) maker.
Allow me to provide some background first ...
I started a clean cycle, following the instructions in the booklet exactly. I used 4 cups of white vinegar and pressed the clean button. Easy, right? The reservoir emptied about 2/3, the clean light began blinking and an audible (steady) alarm sounded. I waited for 2 hours for that audible alarm to stop, but it never did. Finally, I unplugged the coffee maker, plugged it back in and tried again. Same results. By this time, I figured I had run enough vinegar through it to properly de-calcify the unit, so I repeated the "clean" steps numerous times with just plain water. Same results. I realized that I could still brew coffee; only thing is, the darned clean light would keep coming on when I pressed brew. Surely, I did something wrong or there would be an answer on the web. I searched many answers, but none fixed my problem. So I decided to call Mr. Coffee (US: 800.672.6333 or Canada: 800.667.8623). I navigated through the menu and found the troubleshooting section for cleaning. The automated voice said, "Place 6 cups of cleaner solution or white vinegar in the reservoir...."
Stop the presses! Did she just say 6 cups? The manual clearly states 4 cups. Also, that's what everyone else on the web is reporting.
So I tried it, and I only used water (since the pot was still relatively clean) - 6 cups of water - pressed the clean button. This is what you SHOULD expect:
1. Place 6 cups of cleaner solution or white vinegar in the reservoir
2. Press the "clean" button.
3. When approximately 2/3 of the solution has brewed through, it will [apparently] stop brewing - the "clean" light will begin blinking (but there should NOT be any sort of audible alarm) - let the maker sit; it's still working on the clean cycle.
4. The final 1/3 of the solution will brew through and the cleaning light will shut off.
This CONCLUDES the cleaning cycle.
Of course, you should just perform a few "regular brew" cycles with just plain water to clear out the vinegar (or cleaner solution) odor.
Bottom line: The manual screwed all of us! 6 cups, not 4!
Try it - Hope it works for you as well as it did for me.
John
Nov 16, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
Set time to start brewing in the morning
The following instructions shuld have you in hot coffee in the am.
S E T T I N G T H E C L O C K A N D D E L A Y B R E W T I M E
On programmable models CGX20/CGX23 & CGTX84/CGTX85 only
To Set the Clock:
1. Plug the power cord into a standard electrical outlet. The clock will flash on the control panel to
indicate that the time has not been set yet.
2. Press and hold the HOUR and MINUTE buttons until you
reach the current time. The PM indicator will light on the left
of the display.
NOTE: Pressing any button before setting the clock will cause
the clock to start keeping time from 12:00 a.m. You must set
the clock if you want to use the Delay Brew feature.
To Set the Delay Brew Time:
After setting the clock, simply press and hold the SET DELAY
button (Figure 1), and set the brew time by pressing the HOUR
and MINUTE buttons. The PM indicator will light up on the
clock display.
The Delay Brew Time is now set!
NOTE: To activate the DELAY BREW cycle, see the “Brewing Coffee Later” section.
To check the programmed time, push the SET DELAY button. The display will show the time you have
programmed the coffee to brew.
http://www.mrcoffee.com/Manuals/MANUALS/CGX20_43_62164399.PDF
Dec 30, 2009 | Mr. Coffee CGX20 12-Cup Coffee Maker
I have a cuisinart coffee maker. I can set the
Unplug the coffeemaker for 20 minutes or longer - not a second less - in order to fully reset it. Then, when you plug it back in, turn the function dial to Clock again. Press and hold the HR button for a few seconds, and then set the hours. It should work now unless it got zapped, as you said.
-Tha Mp3 Doctor
Mar 21, 2009 | Cuisinart Brew Central DCC-1200W, 12-Cup...
Directions
Thanks for showing me similar problems posted in the past. I was able to figure out that 2 1/2 cups of coffee grounds per 30 cups water was perfect.
Aug 17, 2008 | Faberware 12-55 Cup Coffee Urn
Instruction manual
Go to http://sumanual.com maybe there you find the instructions.
Apr 22, 2008 | Mr. Coffee 072179228578 12 Cup Coffee...
Operating instructions
I have this manual (CM500) and can scan/email it to you if you send me your email address...also I am looking for a replacement lid for my carafe for this machine if anyone is looking to get rid of theirs!
Mar 29, 2008 | Gevalia CM-500 12 Cup Coffee Maker
Turn off beeping alarm when the coffee maker is done brewing
you can't ,its up in the top behind the controls.
you have to take the pot totally apart.
only a trained tech should attempt this.
Mar 23, 2008 | Mr. Coffee 072179228578 12 Cup Coffee...
Auto on
Just set the alarm time then click the auto button so the light shows green. Put in the water and coffee the night before and you are good to go.
Aug 27, 2007 | Gevalia CM-500 12 Cup Coffee Maker
Coffee Makers & Espresso Machines Logo
518 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
