Question about RCA Televison & Video
How to force 6ytold rca 2245LA to rescan antenna channels when relocated to new city
SOURCE: RCA HDTV, indoor antenna and Dish Receiver 311
I want to use two (2) 311 dish receivers with only 1 outside antenna.
Posted on Jan 24, 2009
  • 58 Answers
SOURCE: I have an rca flat antenna. June 12 I rescanned
you probably need a digital converter box
Posted on Jun 15, 2009
  • 105 Answers
SOURCE: Locked out of digital antenna in setup. I had it
1. ensure that you are on the TV tuner when you are trying to scan channels
2. if analog tuner works, but you cannot access digital tuner....the digital tuner is broken
When you turned channels before, did it switch between analog and digital channels seamlessly or did you need to press a button to acces digital channels seperately?
If you accesed digital channels seamlessly, #2 is not likely
If seperately, #2 is very likely.
Posted on Jul 10, 2009
  • 1779 Answers
SOURCE: Vizio VA26L - Tuner problem. After approx. 6
Take the set and reprogram it where one of the other sets are ok. Digital signal is not so forgiving as analog, also place one of the sets that is receiving that station in place of the not receiving one. It's possible that the signal level at the bad spot is on the border line and that model can't hold on to it. You may also check visio's web site for any software up grade to your model that you may have to down load.
Posted on Nov 27, 2009
  • 476 Answers
SOURCE: VHF channels come in however UHF channels are not
uhf and vhf tuning is performed in one board(tuner brd) there are some on line part stores that can help you with the number and price, you'll need to provide the model number. partstore.com is one of them, but there are more.good luck.
Posted on Jan 09, 2010
Did the channel scan for OTA stations, is there a way to hold these stations so I can turn antenna and rescan for more stations?
Guide to help get more channels on digital tv
spartacus-searching.com/dtv.html
Orginally there were many tv stations but the government decided to force ... Alsothese televison signals are more difficult to capture than before with analog signals. ...So that's not accurate when we are trying to find a TV transmitter. ... web page will tell you rescan for channels, thats great if you raise your antenna or have ...
How to sharpen digital TV reception via antenna
Jan 18, 2016 | Element Electronics Televison & Video
Set up indoor antenna
Plug antenna cable directly into antenna input on tv. Place antenna where you believe you will get a signal (don't know where you live but you can look up site map for optimum direction). Go into tv menu set tv to air and auto scan air channels. Your set will receive and memorize available channels. In your sets menu you should have a strength meter. You can use this to tune in the strongest possible signal. You may have to go back and rescan the channels because if you improve the antennas position you might pick up more channels and they won't just come in automatically. Once you've scanned and received maximum number of channels there will be no need to rescan again. If you do you run the risk of losing some channels and only a rescan under optimum conditions with regards to antenna position and environmental conditions will gain those back. Keep in mind some fringe channels may come and go. Hope this helps.
Feb 01, 2015 | Televison & Video
These answers do not fit my question. One day, on three different sets in my home, where I have received NBC for years just quit working. Did NBC quit broadcasting? It is not snowy, etc, it is just no
Ok This is what I found out and hopefully found your solution..
Have you heard of Double Rescan?
The Federal Communication Comission Designed a Process called double rescan.
Double Rescanning erases and thenreprograms the channels in the converter box an digital TVs memory.
To Double Rescan, you will first need to disconnect the antenna from the converter box or antenna.
Then disconnect the converter and or digital tv power supplies from the wall. Wait a minute before plugging them back in. The antenna should still be disconnected.
With the antenna disconnected run the channel scan function on the coverter box or digital tv. When the scan completes you will have completely removed any channel data the converter box or digital tv, had in its memory.
Now it's time to rescan for real.
Do this by reconnecting the antenna to the converter box or digital tv and running the channel scan function again.
Thus the double rescan is born.
If the double rescan doesn't work, then try some tips and tricks to get your converter box up and running..I will have to look up the url again that has the tips and tricks...
If the double rescan doesn't work let me know and I will look up more options..
I really hope this works..
Dec 18, 2014 | Samsung Televison & Video
RCA HD52W59 HDTV Plug in digital antenna into air antenna input then run channel scan =0 channels What should I do next??? Mike
Make sure you are connecting the digital antenna to the digital antenna input on the back of the set, then rescan. Most over the air Tv signals migrated to digital transmission and therefore the analog input is mostly for older analog devices. If you still do not get any channels, then you need to make sure the antenna you are using is rated for reception in your area. You can check for proper antenna size and channels available here,http://www.antennaweb.org/aw/welcome.aspx
Feb 08, 2011 | RCA HD52W59 HDTV Projection Television
Just got an antenna to pick up local HDTV channels. I scan the channels and none are found. does it matter if I connect to "Ant1" or "Ant2"? neither seem to work. Thanks.
According to the user's manual on page 16, press Menu and open the Setup menu. Highlight Installation and press Enter. Open the Terrestrial menu and highlight Input Configuration. Select the ANT1 or ANT2 (whichever the antenna is connected to) and select input source Antenna [not cable]. Highlight Done and press enter. Now rescan your channels. If you still get nothing, try relocating your antenna to a better place. Digital TV is highly dependent on line of site signals. So if you are in a mountainous region or surrounded by a lot of high rise buildings, you may not receive a good enough signal to register channels on your TV.
Feb 06, 2010 | Toshiba 56HM66 56" Projection HDTV
Jun 15, 2009 | Televison & Video
Lost several stations afyter conversion like al PBS stations. Is there something we can do?
Try rescanning for new channels. Some stations changed their Digital transmitter frequencies when they took their Analog transmitters off air. Rescanning will relocate those transmissions.
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
I have a rca digital ready tv,I scanned for the new channels and I received all of them except for 1 of our local channels.Why would I not receive this one?
Hi, There could be a couple of reasons, primary probably is signal strength. Depending on your antenna direction and the transmitter location it may be a dead spot which can be fixed by moving the antenna slightly and rescanning. If you need further help please get back to me. Good Luck! Hope this Fixsya!
Feb 26, 2009 | RCA TruFlat 27F520T 27" TV
Are there any boxes that don't require 'autoscan' for setup?
How to connect a motorola DCH3416 to a computer?
Feb 19, 2009 | Televison & Video
Televison & Video Logo
29 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
