Question about Garmin GPS
My garmin nuvi 660 stopped receiving satellite signal. Reset has no effect. Everything else seem to work.
    Scholar:
  • Garmin Expert
  • 186 Answers
Power your unit on outside, make sure you have a clear view of the sky. If your unit is working properly, then it should pick up the satellites. If so, then you can put the unit back in your vehicle and make sure it is positioned to maintain a satellite lock. If you cannot acquire satellites outside, then the unit is defective.
Posted on Apr 08, 2017
SOURCE: Dont Aquire Satellites
Ditto.. even after updating FW...
Posted on Sep 29, 2008
SOURCE: Garmin NUVI 660 - can not locate satellite
These are the instructions I got from Garmin as how to do the Master reset:
Here are the steps to backing up the favorites on your unit and then performing the master reset. First, you’ll want to plug your unit into your computer via USB cable. Once it’s plugged in, you’ll want to go to My Computer in your start menu or from your desktop and double-click on the Nuvi. At this point, you should see a few folders, but you’ll want to double-click on the Garmin folder. Here, you’ll want to look for the “GPX” folder and you’ll double-click on that. In this folder, you’ll want to drag and drop the file titled “Current.gpx” to your desktop to copy it. Now you are able to do the master reset.
To do that, you’ll want to start with the unit turned off and press and hold on the upper left hand corner of the touch screen. While holding the touch screen, power the unit on and continue to hold. You should get a message that asks if you really want to go into maintenance mode and you’ll want to select “Yes”. At this point, you’ll want to select “clear user data” and then select “Yes” when it asks you if you really want to clear user data. Now, the unit should restart and you’ll want to take it where it has a clear view of the sky and let it sit for up to 30 minutes to acquire satellites. If after 30 minutes it does not acquire satellites, you can go ahead and reply back to me.
Either way, once we have your unit back working again, you can follow the first set of steps again to get to the GPX folder and drag the “Current.gpx” folder from your desktop to that folder on your unit. This will replace your favorites.
Posted on Oct 07, 2008
Foxy_sister0
SOURCE: how do i unlock garmin nuvi 660 ? thanks
how do i unlock the gps
Posted on Aug 03, 2009
sharcnet
  • 2130 Answers
SOURCE: garmin nuvi can't get satellite signal
Please see this link:
http://www.sharc.net/gps_antenna_repair.htm
- Jim
Posted on Dec 23, 2009
odiebugs
  • 949 Answers
SOURCE: Garmin nuvi 1350 can't find signal
Fist you should travel around with it, and see if in a different area you get satellites.
It could be where you are at, so this does not mean that in another town or state it won't work.
If you try this and still have problems it could be the unit and you should contact the MFG and send it in for repair.
This is the contact support page I posted below if you need it, its a live link so if you click on it the page will open.
http://www.garmin.com/garmin/cms/cache/offonce/us/support/supportcontact;jsessionid=0D1782886E6A3CF9512F8AEE898B8248
Posted on Feb 12, 2010
Receiver Garmin nuvi not acquire satellites i lost satellites signal
Common problem. Please see this link:
- Jim
Aug 21, 2011 | Garmin Nuvi 660 GPS Receiver
My 660 is not receiving a satellite signal. Software has been updated and unit has been completely reset. Garmin has offered to replace with lower end unit. Any hope for the 660?
If you have preformed all the above then the GPS receiver in your unit is probably dead and you should take the replacement from garmin as the 660 is an older unit and probably out of warranty.
Feb 14, 2011 | Garmin Nuvi 660 GPS Receiver
Garmin 660 reads as acquiring satellite and stays stuck in this screen. Reset default settings, moved around outside to get the signal.
satellite receivers seem to be doing this on cloudy days also bad line of sight to the sky. say the unit is being blocked from seeing out the window properly or is in to far from the windshield it will not have a direct line of sight with the sky. thus no signal acquisition.
these units rely on signal triangulation to track your Xiamath location it takes 4 satellites to give your exact or near exact coordinates consider that your line of sight is not the problem then is say theirs a issue with eh unit and it may be defective. but try holding it outside the car a second like out the window and see if it picks Anny satellite up. if so then line of sight is probably the issue here. good luck and thanks for using fixya service.
Sep 20, 2009 | Garmin Nuvi 660 GPS Receiver
Poor satellite signal on my garmin 660?
you should update the unit software to the last ver
Jul 07, 2009 | Garmin Nuvi 660 GPS Receiver
660, hangs up totally after ca. 40mins use
Hi Martin,
It sounds like a corrupted firmware update. Please go to this site:
http://gpsinformation.org/perry/nuvi/
I believe the latest firmware version for a 660 is v4.7. You can try reflashing the firmware with v4.7 or trying an earlier version. Let me know if this resolves your issue.
Also, the Nuvi can lag if you have large picture files on an inserted SD card.
- Jim
SHARCNET-USA
Feb 13, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 205 Problems aquiring stellite
usually gps are automatically sensing the signal, with clear view without and sometime even with minimal obstruction like trees windows etc. there is no other way your gps could not acquire signal unles it is having a problem .
all gps thesedays have 10-20 meter accuracy, it is only a receiver, this model particularly have the highest signal.
in other words i suggest you reset your unit from the bottom and see if there is any improvement, replace the unit
cheers
Sep 04, 2008 | Garmin Nuvi 660 GPS Receiver
Jun 14, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi takes a long time to Acquire satellite
No. 98% of the time it took 45-56 seonds for your NUVI 660. Thats the compagny set up time acquisition and it did very well.
Be sur you had your flip antenna parallel to earth surface.
660 has THE BEST SIRF Chipset for acquiring satellite.
I had 2 NUVI 660 since 2 years. It work much better than those new 7xx series who it really took 2-3 minutes to acquire satellite.
Be sure you update your version to the last one.
----> https://buy.garmin.com/shop/store/downloadsUpdates.jsp?product=010-00540-00&cID=134&pID=400
Best regards
Jan 12, 2008 | Garmin Nuvi 660 GPS Receiver
GPS Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
