Question about Kenmore Washing Machines
Reverse door kenmore washer model 417 - Kenmore Washing Machines
  • Brian Imperatore Jan 01, 2017
    Hi Scott Winick, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? 417 is not a model number that just tells me frigidaire made it the numbers after the 417 are needed
  • Scott Winick
    Scott Winick Jan 02, 2017
    417-40042990 is the full number.
4 Suggested Answers
  • 130 Answers
SOURCE: Door opens on the wrong side
Usually not. If you can you will need a door kit from sears. But in most cases the manufacture does not want to mess with the doors seal, so they dont offer a change.
Posted on Jan 24, 2009
  • 31 Answers
SOURCE: We have a Kenmore front loading washer, model 417.
This could be one of two things. The actual door lock assembly there is something malfunctioning with the part that the striker goes into or that the control pannel is not registering that the door lock is actually closed. One is a $60 fix (the door lock) and the other is approx ($250). Unfortunatly because they are both electronic parts you can't just buy the cheap one put it in and if it doesn't work return it. Most stores have a no return policy on electronics/electrical parts.
Posted on Oct 03, 2009
  • 15935 Answers
SOURCE: front door would'nt open on my kenmore tumble
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
How is the doors reversed on ffp187b
Reversing your washer door - YouTube
? 5:14
Feb 16, 2011 - Uploaded by Kenmore You can switch the side the door on our new dryers (model #s starting with 417) swings on. This video will tell ...
Jul 30, 2015 | Washing Machines
Kenmore Washer/Dryer Stack -- Need to replace Washer
first of all. comming from a Sears Technician.. (don't yell) -- the delivery drivers only know about delivering stuff. they dont know too much,
if the two are the same size they can be stacked.
sometimes have to rig something up
and yes, for that model the top is removed, clips go on the rear and screwed at the front.
in some areas it is sold seperatly as a stacking kit
May 28, 2009 | Kenmore 43042 Front Load Washer
Jan 24, 2009 | Kenmore 44072 Front Load Washer
My kenmore front loader model 417 will not start
You have to replace the door lock(switch its all one unit) This will fix it.
Nov 16, 2008 | Kenmore 44102 Front Load Washer
Won't spin or agitate - will pump water water out
This is caused by either a bad door switch or a speed control unit. There is no way to test the door switch but it is the cheapest to replace. Try that first then the speed control. The door lock switch hopefully does it. (even if it locks it can still be bad there is another switch inside.)
Sep 18, 2008 | Kenmore 44102 Front Load Washer
Kenmore Front load washer model 3 970-c29042-00 The washer is making a loud noise and shakes like something is loose when the drum is turning..
I have a kenmore front load washer, model: 417 42042100
It makes loud noise and becomes louder during the spin cycle.
The drum is loose when I inspected through the front door.
My problem is how to open the cabinet and replace any broken parts.
Aug 04, 2008 | Kenmore 46462 Front Load Washer
If it is stack from the factory (ie..came as one peice) you cant
Jul 24, 2008 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
37 people viewed this question
Sal De
 Brian Main
Brian Main
