Question about Lexmark T642tn Printer
Lexmark t642 fuser part - Lexmark T642tn Printer
  • 15 Answers
The fuser part number is 40x2592
You can order new, refurb or exchange here
Posted on Jul 22, 2009
    President:
  • 2,306 Answers
I'm only seeing a fuser maint. kit which is
#40x0100 around $300.00
Posted on Jul 21, 2009
  • 3 Answers
SOURCE: Lexmark T642 Laser Printer error message922 02
Service fuser error requires a maintenance kit, this is approx $1000 + installed, if this is new, I would be taking it back because it shouldnt have this error. You possibly might be able tto fix it by replacing the fan in the back but thats only worked for me in approx 1 out of every 10 times.
Posted on Jan 30, 2009
Crankstart
  • 696 Answers
SOURCE: T642 Laser Pinter
This is a call for service message generally requiring professional repair.
There are generally only four reasons:
No power, Check fan power leads as one may have slipped off it's fitting
Jammed: Either too dirty or a shred of paper may be blocking the blades, pull free and clean off with compressed gas(no more than 25ft/lbs)
Dead fan: Call a repair man or call lexmark and give them the exact code,they will identify the fan and can sell you the part.
Dead controller board: as with above call a repair man or lexmark with code and order spare part.
The only bad news other than you may need a repairman, if you order the fan or controller board it may be the other and no way to know ahead in some cases.
The good news, if you're still under warranty, lexmark has good repairmen and fast response times in most areas.
Either way, Hope this helps FixYa,
Chris
Posted on May 10, 2009
  • 17 Answers
SOURCE: Im getting plain paper jam at the fuser...
You can replace those rollers. They wear smooth very quickly. In a pinch you can also peel them off the hub and put them on inside out. It will give it traction. It sounds like you already know about the little sensor in the trays themselves. I've seen them pop out of position and cause those probs. I don't think they could have made those sensors any cheaper if they had tried!
Posted on May 29, 2009
  • 320 Answers
SOURCE: Lexmark T642 When printing, LCD displays
this error is a scanner lost lock error and can be caused by the scanner or the logic board. if this error comes up immediately on power up the scanner motor is not initializing by percentages of failure the scanner is approximately 85% the logic board 15% i would change the scanner
Posted on Nov 28, 2009
SOURCE: power on reset T642
Failsafe way. . .pull the plug out, wait ten seconds, plug it back in :-)
Posted on Dec 10, 2009
What can i do when my lexmark T642 printer displays 922.02 service fuser error when the printer was never used?
It could be the connector to the fuser from the LVPS is not connected properly. It could also be the Thermistor on the fuser is bad.
Jan 31, 2017 | Lexmark T642 Laser Printer
How do I know when to use the fuser wiper cavity cover or the oil fuser wiper or the wax fuser wiper on my Lexmark T642?
The T642 is a monochrome printer and as such does not have an Oil wiper. The only wiper that should be needed with this printer is the hard plastic one that ships with the printer. These wipers are permanent and are only replaced when you install a new fuser. Oil wipers are usually only used with color laser printers.
Apr 01, 2011 | Office Equipment & Supplies
Message on screen reads: 920.26 Service Fuser Error. I've tried switching it on/off, still won't work and none of the buttons will cause the error message to dissapear.
Service Fuser Error appears when the fuser does not warm to the required temperature. For this error on this Lexmark model T642, the manual states you should power off the printer and power it back on, which you did, and if it is not plugged into a wall power point, change it to a power point mounted directly on the wall. Personally, I never got a Lexmark printer to work doing this, but this is in the manual. If this won't help, and the printer is under warranty, you should log it in with the servicing company.
If the printer is out of warranty, your next option is to change the fuser which costs around $350, so I think you would be better off getting a new printer unless you find a second hand one on Ebay.
Aug 22, 2010 | Lexmark T642 Laser Printer
I have a Lexmark T642. Where does the felt strip
The felt strips were not put in on the Newer T 630/T640 and up series as they were causing scoring on the fusers. They would act like sand paper and score it beyond use. There are no more which is a great thing.
Feb 26, 2010 | Lexmark T642 Laser Printer
920.07 code on a t642
a 920 error means your fuser is under temperature at standby. you should replace the thermistor it cycles the fuser on and off to maintain these temps
Nov 06, 2009 | Lexmark T642 Laser Printer
On a T642 prints out first three sheets just fine but on 4th it never makes it to the fuser. The paper curels inbetween the fusers and toner. 201.32 error
The error 201 means exactly what you are getting;
a paper jam between the printer input and exit sensors.
It is common on these printers for toner to build up on the fuser input guide and eventually gets so big as to catch on the leading edge of the paper,
you will need to scrape the encrusted toner off of the guide.
If the device has done a large volume of printing (say over 100k) it may be a faulty fuser assembly.
Oct 05, 2009 | Lexmark T642 Laser Printer
Lexmark T642 display says paper jam check rear door. There is nothing jammed! What can I do
The sensor in the fuser unit is jammed/broken. The fuser will need to be repaired or replaced.
Aug 13, 2009 | Lexmark T642 Laser Printer
Jan 13, 2009 | Lexmark T642 Laser Printer
Wiper blade
When you say wiper blade, do you mean the one in the cartridge? There's also a cleaning wand in the top of the fuser.
Dec 18, 2007 | Lexmark T642 Laser Printer
41 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
