Question about Health & Beauty
I bought a used jazzy power chair. When I push the power button the battery indicator lights keep going back and forth and a little wrench blinks, but it won't move
SOURCE: The charge lights blink and the chair won,t go.
Just had this problem with my Guardian Aspire. They had to replace the electronic box with the joy stick. BIG BUCKS!
Posted on Mar 13, 2009
dromtonpa
  • 40 Answers
SOURCE: My Jazzy won't move.
If your batteries are truly charge they should read around 24.5 VDC. And if the freewheel lever is engaged and you still have no movement your probably need to get into a service tech. Also check the circuit breaker on the chair.
Posted on Apr 03, 2009
  • 50 Answers
SOURCE: Our Jazzy Select G.T. power
Hi
delobner,
Sometime we lock our vsi joystick by mistake. Here are the instructions on how to lock and unlock your joystick.
If the problem is still there after write me back and I'll help you.
LOCKING/UNLOCKING THE VSI
The VSI has a feature that enables you to lock your power chair to prevent
unauthorized use.
To lock the VSI:
1. With the VSI powered on, press and hold the on/off key. After one (1)
second, the VSI should beep.
2. Release the on/off key.
3. Push the joystick to the full forward position until the VSI beeps.
4. Pull the joystick to the full rearward position until the VSI beeps.
5. Release the joystick. There should be a long beep.
6. The VSI is now locked.
To unlock the VSI:
1. Press the on/off key and power on the VSI. The maximum speed/profile
indicator should ripple side to side.
Good Luck
mi mobility
Posted on May 05, 2011
SOURCE: Jazzy Quantum 600 power wheelchair - On the
THE WHEELCHAIR WILL ONLY TILT IT WILL NOT GO FORWARD OR BACKWARD USING THE JOYSTICK
Posted on Jul 14, 2011
  • 5 Answers
SOURCE: Jazzy 1121 power chair won't go
I find a lot of the controller Problems are caused by the cable running from the joy stick down to the controller gets caught on something or rubbed against something and one or more tiny wires inside are broken ... If I find a spot on the cable that is worn through, that's where I start .. Open up the insulation and check the tiny wires .. fine the broken one and repair it .. usually that solves the problem and saves you a couple hundred for the cable
Posted on Oct 08, 2011
WHEN POWER ON CHAIR SPEED LIGHT BLINK .BOTH BATTERY WAS REPLACE AND JOYSTICK.SAME PROBLEM
The battery meter lights will flash a flash code when something is wrong. If the lights are flashing the same number of lights each time. get that number it is a flash code. if the lights are cascading up and down that indicates that the Joystick is locked. unlock by turning on the joystick and pushing the horn button twice within 10 sec. of turning on. Or push on button and hold the joystick gimbal forward until it beeps then back until it beeps. This should have it unlocked, if not Pride Jazzy Tech 800-800-8586
Mar 28, 2016 | Pride Mobility Used Power Chairs Jazzy...
Pride jazzy 1113, controller light scroll back and forth, wont move, i bought one new battery, it has full charge other battery is a little over 10 volts. is there way to test charger with volt meter?
The voltmeter should read 29 volts when on. You should never replace one battery and leave an old battery in the chair. Replace them both at the same time.
Oct 17, 2013 | Pride Jazzy 1113 Power Chair
Jazzy 1133 has new batteries. All lights are lit on the battery condition meter. Maximum speed/profile indicator constantly blinks no matter how many sements are lit. After I turn it off and waiting a...
If all lights are flashing excessive voltage has been applied to the controller system. 6 flashing lights on the 1133 indicates that the chair is being inhibited by the battery charger. Try unplugging the battery charger. Check you battery connections.
Mar 30, 2013 | Pride Jazzy 1113 Power Chair
Blinking yellow wrench light on pride jazzy 614 HD
Your version has a Dynamic Controls model controller and joystick.
Unplug the charger and engage the motor/brake lever so the chair is no longer in free-wheel mode (con't push by hand)
Turn the chair off, wait 5 seconds, turn the chair back.
If chair still does not run and your wrench is flashing you have a problem. Count the wrench flashes - the flash count indicates the error detected. 3, 4, 5, and 6 flashes indicate and error with the motors.
3=Left motor fault
4=Right motor fault
5=Left brake fault (may not be engaged)
6=Right brake fault (may not be engaged)
Any other fault code usually means the electronics or wiring is bad and not worth fixing.
Jan 06, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
Replaced batterys in jazzy chair speed indicator keeps blinking - no code for it - plug in charger works for a minute after unplugged but then goes back to blinking?
Jazzy is in lock mode try the following to unlock:
Lock Mode
To unlock the VSI:
1. Press the on/off key and power on the VSI. The maximum speed/profile indicator should ripple side to side.
2. Push the joystick to the full forward position until the VSI beeps.
3. Pull the joystick to the full rearward position until the VSI beeps.
4. Release the joystick. There should be a long beep.
5. The VSI is now unlocked
Hope this helps
Mar 29, 2011 | Pride Jazzy 1113 ATS Indoor Power...
Not sure witch jazzy chair i got but the joy stick blink and keeps blinking i have tried pushing horn button twice and also turning it on and pushing joy stick forward waiting for it to beep but no beep....
The jazzy probably has a VSI controller and if it is sleep mode then the lights will scroll rather than blink. Now turn on the chair and see if the blinks have a pause between them, ie 4 blinks pause 4 blinks pause etc If they do count the number of blinks and this will give you the error code ie 4 blinks right motor 3 blinks left motor your owners manual should have a chart listing the error codes If not you can contact Pride tech support @ 1-800-800-8586 ask for jazzy tech support
Hope this helps
Feb 17, 2011 | Pride Jazzy 1103 Ultra Standard Power...
I have an 11 month old jazzy 1170xl. part of the time when you push the power button you get 2 flashing red lights. if you keep resetting it with the reset button, it will eventually power up and work fine...
You can visit this website to find answers on what the flashing trouble indicator lights mean: http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Locate the page that has the controller used on your power chair/scooter and count how many lights are flashing to diagnose the trouble.
If the Jazzy is pulling to one side, it may indicate that there is a bad fuse or motor and the blinking lights are trying to alert you to this.
If your insurance purchased the power chair for you, they may also cover the repairs and have a DME (Durable Medical Equpment) company to refer you to for service if the Scooter Store is not helpful; contact them for information.
Dec 11, 2010 | Health & Beauty
I have a jazzy and the power meter keeps blinking a steady red light.... And now the chair is moving really slow....
Low batteries Outlaw. If you have charged the batteries and after only a little while you get the blinking red light -----Time for New batteries. Hope this helps you
Nov 10, 2010 | Pride Mobility Products Jazzy Select 14
Lights go back and forth 2 or 3 times and then flach
The number of lights that are blinking indicate what the problem is. Visit this site to locate the type on controller on your power chair and you will be able to see that the blinking lights mean:
Try to reset your manual brake release as this is a common problem.
If you continue to have a problem, contact your manufacturer or dealer for service. If your insurance purchased they power chair for you, they may also cover the cost of repairs.
Jul 10, 2010 | Pride Jazzy 1113 ATS Indoor Power...
Health & Beauty Logo
51 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
