Question about Video Game Consoles & Games
The game works fine, I just want to play with sound off--it's a Game and Watch Fire from 1981,widescreen edition.Know you have to push two buttons on the front of the game but can't remember which two
SOURCE: why doesn't my logitech work for f.p.s games
it doesnt work because your most likely programming it to the launcher, the box that pops up at the beggining when u first click ur shortcut there is no way to make it work for combat arms i've tried and have not succeded
Posted on Sep 28, 2008
  • 5 Answers
SOURCE: Madden 09 for PS3 -- Sound won't work
the only thing i cn think of is that the game hasnt been fully installed which could lead 2 the loss of sound!! take the game back and get a replacement this should solve the problem thanks ben !!
Posted on Oct 30, 2008
SOURCE: My TV has stopped responding to the remote control (and the universal remote) and the front panel buttons don't work
waynejman, I have the same exact problem, can you tell me what your outcome was?
Posted on Nov 16, 2008
  • 25 Answers
SOURCE: A gamecube game is stuck in wii... Please help...
You may check out Wii Fix Guideto fix the problem yourself. This DIY guide will show Step by Steppictures to fix the problems yourself without any technical knowledge.
Posted on Feb 20, 2009
pelicans405
  • 11 Answers
SOURCE: It works fine untail I want to play Asherons Call a MS game, firewall has locked me out, how do I shut off the firewall. tyvm Ken
What you want to do is "open ports" in your firewall. This is simple if you have admin access to your router. Find the section for "port forwarding" and add ports that your game require. Typically, there is a TCP port and a UDP port. The UDP is for broadcasting type messages to/from your fellow gamers. The TCP port is usually for the game server. Check with your game instructions -- or you can probably get the answer with a google search string of "game ports Asherons Call" and I would bet it will give you exactly the settings for your router.
Here ya go (I did the google search). It appears that it only requres the UDP port. I would open all of these unless you find out more detail that you can close some ports (never leave a port open that you don't know or don't need -- it is a hackers door to your computer).
9000 UDP Asheron's Call game
9010 UDP Asheron's Call game 9011 UDP Asheron's Call game 9012 UDP Asheron's Call game 9013 UDP Asheron's Call game
Good luck.
Posted on Apr 29, 2009
Graphics engine error
I don't know if you were receiving this error for the same reason I was. I had just purchased a new LCD Flat Panel display and the game absolutely hated the monitor. The resolution I had set for the previous monitor was apparently causing the error that prompted the "/safe" parameter message. Since support dragged their butts in offering a solution, I ended up seeking out help elsewhere online and found this website: http://www.widescreengamingforum.com/wiki/index.php/Main_Page
They deal in solutions for playing a wide variety of games that may not have any support for widescreen.
They offered a most simple solution. The safe meesage appears to come up because the game does not like starting in the resolution you have the game set at.
Their fix is simple. Scrap the "/safe" command that the game is asking you to use.
Go into the game data folder and find the file DATA/ufo-et.ini and then edit the height and width parameters to a lower resolution OR if you are in fact using a widescreen monitor edit the resolution to the default resolution the screen runs best at and then resave the file. Restart the game and the "/safe" message should go away. Worked like a charm for me.
Let me know if this helps
Cheers,
Robin
Apr 27, 2012 | Computers & Internet
Xbox makes noise playing discs
I know what you mean , some drives are LOUD .Try wraping it
with towels ,just kiding . I have recived alot of request to quite
these drives down , I am working on a sound insulator
that will wrap around the cd rom to knock 10-20db off
but i have to watch out for heat build up. Ill keep you posted.
Bobby.
I presume the unit works fine it's just loud, right?
Rob
Sep 16, 2009 | Microsoft Xbox 360 Console
Broken Banking Unit for Monopoly Electronic Banking Edition
me to but, I think you should return it and get monopoly millionaire's
Jun 04, 2009 | Hasbro Monopoly Here and Now Electronic...
Good luck.
Apr 27, 2009 | Computers & Internet
Oblivion elder scrolls xbox360 push buttons wont work
The game is very buggy, especially the 360 version. Unfortunately the Live updates for the game don't seem to do much either. Developers have started getting into the habbit of releasing buggy games just to save money. If you have Xbox live, you can download any game updates by connecting then playing the game and it will update automatically. If the problem persists then e-mail the developers and complain, stating the issues you have with the game.
There isn't much else i'm afraid...
Jan 20, 2009 | Take 2 Interactive Elder Scrolls IV:...
Some Virtual Console games don't work!
When using component video cables and a HDTV: Go into the Wii's system settings, under Screen, change TV Resolution to HDTV (480p) instead of Standard TV (480i) and change to Widescreen (16:9) under Widescreen Settings.
This worked for me, good luck!
Nov 18, 2008 | Nintendo Wii Console
Wii VC games won't play on hdtv
I had the same Black Screen problem and I finally have a fix for it!
Sep 28, 2008 | Nintendo Wii Console
Video issue
Everyone has this problem you cant really fix it,
Mar 06, 2008 | Microsoft Xbox 360 Console
No background music in games such is Battlefield 2
Suggest that some sound in the game set up is at low or on muit. the speakers ar dumb thay willonly play sounds from the pc the speakers do not decide not play some sounds and not others.
Jul 26, 2007 | Logitech X-530 Computer Speakers
Video Game Consoles & Games Logo
24 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
