Question about Sunbeam Coffee Makers & Espresso Machines
My sunbeam coffee master is stuck. I cannot get the top pot off.
sgregg
  • 133 Answers
SOURCE: coffee pot top
as far as i can tell you cant just buy a lid, mabe on ebay instead of buying a whole new pot or call customer care at 1-800-835-3278. Let them know you just need a replacement see what they say. Heres the item number for it on ebay, only one day left at $16.99 200133333009 , and heres the link http://cgi.ebay.com/New-Coleman-Stainless-Steel-12-Cup-Coffee-Pot-805D712T_W0QQitemZ200133333009QQihZ010QQcategoryZ87143QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Posted on Jul 30, 2007
harvestsun
SOURCE: broken coffee pot
Couldn't find any official Sunbeam site with replacement coffee pots. Here's the Sunbeam homepage. http://www.sunbeam.com/Category.aspx?section=kitchen&cid=243 Maybe you could use the contact us link at the bottom and ask them if they sell them separately. Otherwise, you might have to search on ebay or another site like that for a replacement pot.
Hope this helps you.
Posted on Jan 10, 2009
  • 300 Answers
SOURCE: coffee goes to counter instead of pot (occassionally)
How to Repair a Coffee Maker
http://home.howstuffworks.com/how-to-repair-small-appliances3.htm
Posted on Mar 06, 2009
NewsView
  • 40 Answers
SOURCE: Coffee grounds overflow out of basket into top of coffee pot.
Coffee overflowing onto the counter is a common complaint found in response to many automatic drip coffee makers. The following are potential solutions that can be used to rule out "operator error" vs. a defect or malfunction:
1. Do not "pack" or otherwise overfill the cone/basket with grinds.
2. Ensure you are using the correct grind for an automatic drip coffee maker, neither too fine nor too course. (See instruction manual.)
3. Do not overfill with water. Use the carafe to pour water into the reservoir. This is because a "cup" in coffee terms is defined as 6 oz, not 8 oz. Note: Some coffee makers define as little as 5 oz as a cup.
4. Make sure the filter cone/basket clicks into place and that the carafe is centered and pushed all the way in.
5. Try a permanent filter rather than a paper filter or vice versa.
6. Only use the correct permanent or paper filter (see manual).
7. Verify that the Pause 'n Serve button isn't sticking. If it is activated too long the brew will escape over the top of the cone/basket. This may be more apt to happen if the alignment of the carafe and the basket is incorrect.
8. Clean your machine with vinegar or as instructed by your user manual at least three times per year, more if your water supply is hard. A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew, to produce "off" tasting coffee, or to clog and overrun the filter basket as the water runs through the grinds.
9. Ensure that the coffee machine is sitting level on the counter.
Posted on Jan 04, 2010
SOURCE: Takes forever to grind coffee beans
sharpen it blade dull
Posted on May 10, 2010
Water gets stuck in the filter
Inspect the strainer basket's valve to make sure it is not blocked and working properly. You should be able to test it in the sink, fill with water and push the valve up from underneath. Tap the valve a few times to loosen any debris that might be blocking it.
Make sure the pot is fully in place on the warming plate. The lid must align properly with the strainer basket to open the valve adequately. If the pot lid is not touching the strainer basket valve, you may have the wrong pot or the strainer basket is not seated into the coffeemaker correctly. Check for obstructions underneath the strainer basket. Then, make sure the rounded projection aligns with the notch in the coffeemaker near the reservoir.
Jul 10, 2012 | Mr. Coffee JWX27 12-Cup Coffee Maker
How do I order a new pot for the tea drop
Check out Sunbeam's customer support HERE then you can find a local dealer who can order a replacement for you. Sears should be able to order as well.
May 28, 2011 | Sunbeam Tea Drop Tea Maker HTM5B
Vintage Sunbeam C50 doesn't heat enough to perk.
Hi. If you have a light on your coffee pot the model # should 122. A 12 cup older pot. I can fix it for you but you should consider the cost. I only charge for thr parts you need. Shipping both ways is about 10.00 , Max on the repair will be 15.00. My email is callahanronals@att.net Good luck. Ron
May 28, 2010 | Faberware FCP280 Coffee Maker
My cuisenart 12 cup thermal coffee maker makes bad coffee. I can't return it as it was a fathers day gift. coffee always tastes bitter and burnt. at work we use the same coffee in a 20 dollar sunbeam...
The quality of the water is responsible for the flavor of the coffee. If you have had this coffee maker for a while it is probably coated with lime. Run a couple of cups of vinegar through it followed by a couple of pots of clear water. That will clean up your machine.
Once it is clean, try making a pot with bottled water, or water that you run through a water filtering pitcher.
You will be amazed at the differenct.
Jun 11, 2009 | Wega Mininova EPU Espresso Machine
Broken coffee pot
Dec 04, 2008 | Sunbeam 6385 Coffee Maker
We have a Sunbeam coffee maker almost 3 months old and has been a problem after 1 month use. We bought a Mr. coffee and it,s around 6 weeks old and both are a big problem while trying to brew coffee,they...
my suggestion is spend some good money on a coffee pot or get a french press and a hot pot. those mr. coffee and sunbeams are nothing but trouble from my experience.
Sep 20, 2008 | Mr. Coffee 072179228578 12 Cup Coffee...
Coffee maker
get up at 659 am. seriously the pots have a 2 hour automatic turnoff feature for safety purposes-no fix.
May 05, 2008 | Coffee Makers & Espresso Machines
"Tea Drop" manual
It's December, so you may not still be looking, but you put in 1 tea bag in each side for 1/2 pot of tea, or 2 tea bags in each side for a full pot. If you are using loose tea (tastes better - I just buy Lipton), then you put in 1 Tablespoon in each side for a 1/2 pot and 2 Tablespoons in each side for a full pot. Hope this helps!
Jan 21, 2008 | Sunbeam Tea Drop Tea Maker HTM5B
Coffee Makers & Espresso Machines Logo
Top Sunbeam Coffee Makers & Espresso Machines Experts
ray gallant
Gil Shultz
Are you a Sunbeam Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
