Question about Samsung Microwave Ovens
Se error on a Samsung stove - Samsung Microwave Ovens
How to get -SE- off my Samsung stove
See this page for the official Samsung information on fixing this problem. You can do it yourself:
http://www.microwavecontrol.com/samsung_se_error.htm
If you need more help, you can e-mail me at pupista@gmail.com and include your full model number and FCC ID number from the tag in the cooking cavity.
I'll be happy to help you.
Dec 31, 2016 | Samsung Microwave Ovens
How to fix E5 code for Samsung Microwave
About 64,200 results (0.62 seconds) Search Results
    Fixing a broken Samsung Microwave - The dreaded 5E ...
    ? 4:30
    https://www.youtube.com/watch?v=_yWSU0kTkTg
    Mar 20, 2013 - Uploaded by Joe Devlin
    When my Samsung Microwave was just over a year old it failed giving me an "5E" or "SE" Error code which ...
    Samsung Microwave SE (5E) Error Fix - YouTube
    ? 9:23
    https://www.youtube.com/watch?v=YubSrHE7WFc
    Dec 7, 2012 - Uploaded by eric hatch
    I had pretty much decided to throw it away since the cost to fix it by a ... Fixing a broken Samsung Microwave ...
    Samsung Microwave SE Error FIX! - YouTube
    ? 1:33
    https://www.youtube.com/watch?v=oPQE2oLTR3o
    Jan 26, 2014 - Uploaded by jjthetechguy
    I am not responsible for any damage done to your microwave*** ***Do at ... Fixing a broken Samsung ...
Jan 27, 2016 | Samsung SMH8165B Microwave Oven
Says SE on the screen and will not work
HAVE THE SAME PROBLEM WITH MY OVER THE STOVE SAMSUNG MICROWAVE. LOOKED UP ALL THE ANSWER'S AND CHOOSE THE ONE I THOUGHT BEST AND EASIEST. ITS A MOISTURE (STEAM) PROBLEM FROM COOKING ON THE STOVE. TAKE THE TOUCH PAD APART (AFTER UNPLUGGING AND FINDING THE VIDEO ON U-TUBE THAT SHOWS YOU HOW TO DO IT) ITS EASY. I JUST TOOK THE RIBBON (MINE IS GREEN) SEPARATED IT FROM IT SELF AND PLACED A PIECE OF PAPER IN BETWEEN SO THEY DON'T TOUCH. HAD TO DO IT TWICE BECAUSE I DID NOT SEPARATE THEM DOWN FAR ENOUGH. I ALSO BUT A PIECE OF FOAM IN THE PANEL UNDERNEATH THE CIRCUIT BOARD BECAUSE OF THE HUGE GAP FOR STEAM TO GET IN. IT'S LASTED 4 MO, THAN STARTED FLASHING SE OCCASIONALLY BUT BY OPENING THE DOOR AND PUSHING STOP ITS FINE. THIS HAPPENS MAYBE ONCE A WEEK. I THINK IF I GO BACK IN AND RE-SEPARATE THE RIBBON IT WOULD STOP AGAIN BUT IT'S REALLY NOT ENOUGH TO BOTHER ME. GOOD LUCK
Oct 16, 2014 | Samsung 1.8 Cu. Ft. Over-the-Range...
Why does screen say SE
SE = Sensor Error, its reported that it could be components bent over, and touching each other on the PCB behind the keypad.
You need to be a fair bit mechanically savvy to attempt a repair, and remember to Unplug it before you do! :-)
Sep 04, 2014 | Samsung Microwave Ovens
SAMSUNG MICROWAVE SHOWS SE AND WILL NOT WORK.WHY?
SE is an error code for a shorted keypad, although the keypad might not really be shorted.
Unplug the oven for a few minutes to see if it clears the error code. If not, then leave it unplugged over night. If the problem persists, then you probably do have a shorted membrane switch on the keypad.
Aug 29, 2014 | Samsung SMH9187ST Microwave Oven
Oven shows -se- error,and now doesnt heat
Sorry but the -se- error code from the manual means:
An error of the oven may cause
low performance and problems
in safety. Stop using the oven
immediately.
Call local SAMSUNG service
centre.
Look for the 1-800 number on the back and give them a call.
Jun 10, 2014 | Samsung Microwave Ovens
Samsung microwave se error
see the video attached. God bless you
Dec 09, 2013 | Samsung MS1040BB Microwave Oven
My Samsung SMH7178STD gives me an error condition that flashes -SE- and beeps every so often but i can not get rid of the error condition. I have unplugged to perhaps reset it but it still flashes the same...
Hello :
SE error means you have a shorted keypad . If you couldn't find parts , then It will be cheaper to replace the unit or have new one .
good luck .
please rate !
Mar 30, 2010 | Samsung SMH7178STD Microwave Oven
Entire microwave is dead except LED screen which has a message -- E 5 -- Spoke to Samsung who told me to unplug it for 10 minutes - that dosn't do anything. This is a top of the line over the stove...
From the Samsung FAQ:
For all error indications, including the SE or 5E error, try unplugging the microwave from the outlet for at least ten minutes and then plug it back in. If the error persists, the microwave may require service. Please use our ASC Locater (sic) to find your nearest Authorzied Service Center.
It may be a failed sensor.
Sep 11, 2008 | Samsung Microwave Ovens
Microwave Ovens Logo
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
