Question about Health & Beauty
The rollers in our u comfy foot massager are not working
Reclining is hard and the foot massager is not functioning, don't have the owners manual.
Sounds like the cable to foot massager is trapped in the levers. Turn it on its side and check. Unplug it first.
Sep 26, 2013 | Sunpentown Takasima A-619b 5-in-1 Air...
PANASONIC EP 1004 MASSAGE CHAIR : ROLLERS WORK BUT ARE STUCK AT THE TOP OF THE CHAIR. WHAT DO I DO?
I have one of these chairs, and it quit on me last week. The problem is that the up/down clutch is getting stuck. First, download the service manual here:
http://www.nodevice.com/manual/newmans/panasonic/EP1004NASIMPzip/get25127.html
After opening it up, locate the up/down clutch. It is on the bottom right of the control module. Use a 10mm socket to remove the bolt that holds the belt pulley on. Remove the belt pulley and under it is another big metal disc - the clutch. The problem is that there is a black rubber gasket under the clutch disc that decomposes and makes the clutch stick to it. I scraped the black rubber off and reassembled, and now, it works perfectly. In my case, the rollers didn't even work. This is because the massage clutch, which operates the rollers, also had the same problem.
Feb 23, 2012 | Health & Beauty
Where can I download a "user's manual" for
try typing what you want into your search engine ie, user's manual" for King king USA Big Foot Infrared Foot and calf massager. you might be pleasantly surprised
Oct 02, 2011 | Health & Beauty
I wan to use in office work
Place it in a bag. Take it to work. Plug it in. Enjoy.
Jun 30, 2010 | Homedics FOOT MASSAGER ULTRA DEEP KNEADING...
Remote doesnot work
If you have not already, register your product with the company. And contact them regarding the malfunction. they should replace the part or the product if you send it in.
Jun 09, 2009 | Homedics Qrm 400h Therapist Select Quad...
Holding question
First, select a wide massage area, and use the roller surface. Slowly movethe head of the massager over the massage area in big, wide circles. Then,for areas of soreness or stiffness, change the massager to the proper mode (Some massagers have two levels) . Push down on these massage areas for about 5 to 7 seconds for eachsore spot. Finish with the roller surface again, moving the head around theextended massage area in large, uniform circles.
Aug 27, 2008 | Jobri Dolphin Handheld Massager
Health & Beauty Logo
42 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
