Question about Water Water Heaters
2006 nuevo lancashire.truma gas-electric water heater.can see flames in exterior vent when running on gas.thank.Alan
  • 17 Answers
SOURCE: electric water heater will not stay on
sounds like the electrical thermostat is defective and is being over ridden by the overheat safety stat.
Posted on Nov 29, 2008
  • 2692 Answers
SOURCE: Eractic Power Vent Gas Water Heater
Th epproblem you are most likely have is from a safety called a flag switch usually located either in the blower or right past it. When you unplug and replug you reset the switch. Sequence of events.  1 fan comes on. 2 switch is made from the airflow of the fan.  3 ignitor come on 4. main gas valve opens and ignitor starts flame.
You are being stopped at step 2 when the fan does not move with the air. This shuts off and out the water heater from calling again.  Find the fan switch and make sure it moves easily. They get dirty and also dry from lack of lube. Good luck.
Posted on Mar 16, 2009
  • 14 Answers
SOURCE: Rheem water heater, will start but flame lasts 10 seconds
Is the vent fan working well and can you feel unobstructed air out the termination fitting outside?
Posted on Apr 05, 2009
  • 332 Answers
SOURCE: Rheem 40 gal power vent gas water heater shows code 42
you plugged it in and the fan started or you unplugged it and the fan started,,the fan will come on first before the unit will inginte to take out the excess gas, if it didn't lite then the ignitor might not be working there are 2 swithces on the unit one on the fan and one by the gas valve make sure they are both on and make sure the gas it also turned on.
Posted on May 30, 2009
  • 48 Answers
SOURCE: Loud blower on my new Rheem Power Vent 2 water heater
find out if it does the same noise with the venting disconnected
Posted on Jan 16, 2010
Can I use a Truma hot water heater on gas in my shed kitchen for washing up?
I just looked on the website which contains a remark there is only approval for installations for campervans and caravans.
Nowhere in the description or specifications does it mention a flue or ventilation requirement which is very surprising because burning gas needs a good supply of fresh air and produces poisonous gases that must be got rid of/vented to the exterior.
I guess you could use your heater as long as the requirements of an adequate fresh air supply and the venting of combustion gases is taken care of...
Sep 10, 2017 | Water Water Heaters
Truma Ultra store water heater. How ti hard wire from 230volts. Many Thanks awaiting reply ?
There may be a wiring diagram pasted somewhere on the heater. If not, request the diagram directly from Truma.
Aug 27, 2017 | Water Water Heaters
Digital signal
Bad gas control valve
air in gas line
clogged manifold tube
clogged burner ports
inadequate venting
screens prevent flammable vapor ignition.
Otherwise no danger.
Oct 06, 2013 | Reliance & LP Gas Water Heater Control
Rheem Power Vent 2 41vrp50n does not stay lit
Copy following link to troubleshoot by type of gas control valve:
Rheem does not post service manuals ... wonder if that's why huge majority of water heater problem on fixya are about Rheem/Richmond tank and tankless water heaters
Sep 26, 2013 | Water Heaters
Rheem 22V50F1 pilot won't stay lit. Changed thermo couple & it lit, ran then went out. Let it sit overnight & it lit, ran then went out. What next? p.s. The unit is 5 years old. Thanks
If pilot lights and flame is robust and clear blue, and pilot goes out later, then some suspects can be excluded: air in gas line, low gas pressure, thermocouple is overtightened (finger-tight + 1/4 turn), thermocouple not positioned correctly in the flame, dirty pilot tube.
If flame is yellowish and small: then clean pilot tube and combustion parts.
Remaining suspects can include: air in gas line, low gas pressure, bad gas control valve, tight house so household vent fans pull air down water heater vent that blows out pilot, hot attic with inadequate ventilation, water dripping down vent.
Open following links to read troubleshoot resources.
Aug 16, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Pilot light keeps going out I cleaned pilot loght has a good flame amd I replaced the thermocouple
Suspects include: bad gas control, air in gas line, water dripping down vent, poor air supply, dirty air intake, very hot attic, negative pressure caused by tight house and other venting appliances and vent fans that cause backdraft down vent. Or combination of these problems.
Open following links for resources:
Aug 15, 2011 | General Electric Water Heaters
I have a Bosch Aqua star 240 fx tank less water heater. The unit will ignite and run for 5 sec (Flame visible through window) the flame goes out and it reignites and runs for 5 more seconds and again goes...
It sounds to me like you tried about everything I would. So I think you're already thinking about what I would do next. Try the flame sensor,and as last resort check all connection . Remove wires one by one clean and reattach. If all else fails change cotrol board. It's very hard to fix when it's not consistent. Good luck. Thanks
Nov 15, 2010 | Bosch AquaStar Indoor Natural Gas Tankless...
Electric water heater will not stay on
Nov 17, 2008 | Water Heaters
Water Heaters Logo
42 people viewed this question
Top Water Heaters Experts
D. E. Hev
Are you a Water Heater Expert? Answer questions, earn points and help others
