Question about LG Dryers
Is there a reset switch on an LG dlex2501w dryer and where is it located?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 19 Answers
No reset switch but some have a resettable thermostat on the gas burner tube. you can get at by taking off the plastic side vent cover on the right side shine a flashlight in there and you can see a thermostat with a button on it . its tight but can be done also you may see it better from the left side vent cover
Posted on Jan 01, 2017
LG electric dryer is not working
Reset your electric breakers and make sure the door switch is working. If not sure on switch after resetting breaker turn dryer on and with open door press the door switch in .caution keeps hands from inside in case it starts to work It also could be a Senser inside of dryer that goes off if vent is plugged with debri
May 27, 2014 | LG DLE2512W Electric Dryer
LG DLG5988S will not light, Drum turns but no heat. I would believe it is the igniter. How do I get the igniter to replace it?
Check the high limit switch located on the side of the chamber tube. It will have a little reset button on it. If you push it and it clicks, replace the limit switch because it will trip again.
Jun 16, 2011 | LG DLG5988 Stainless Steel Gas Dryer
What would cause a brand new LG DLEX2501W to be extremely hot on the right bottom side if you are looking at it from the front?
The heating element is located there. Have you got a clear vent to outside? Using the rigid metal pipe?
May 21, 2011 | GE DSXH43EAWW Electric Dryer
I have a LG-DLG5932W dryer and can't find the reset switch. The sensor on the dry was triggered (no heat) due to air duct clogged. Had the air duct serviced and now to rest the switch. Please show me a...
Welcome to FixYa.
While I don't have a video or diagram I can tell you on the LG dryers there is indeed a "reset" for the heating/burner funnel (as you obviously know) on the right hand side of the funnel, however they also incorporate a no reset "hi-limit thermostat" on the left side of the funnel. Once it is tripped it must be replaced. This is only present on the gas dryers.
It is located on the left side as I mentioned, but the other is on the right side of the heater housing/burner funnel and will resemble the images shown below. It is part number 6931EL3004B ( the reset type is part # 6931EL3003C ) and available at "searspartsdirect" (which also has a illustration which may help you) or "repairclinic.com" to name a couple.
i.e. NON-RESET
i.e. RESETTABLE
With the aid of an ohm meter you can check the non-reset for continuity, the other you should be able to push the center reset button ( listen closely for a "click" ) but it too can be ohmed out for continuity to confirm or dismiss it's condition.
Hope that help`s move you forward. If so please take a second and rate the guidance and a testimony to the assistance you received here at FixYa, either or all is appreciated.
Let me know if you can provide any further info and I'll continue to help in any manner I can. Good luck
Regards,
Macmarkus :)
Apr 03, 2011 | LG DLG5932W Gas Dryer
I have an LG DLE2532W dryer. It suddenly stopped putting out heat. I've heard that there's a heat regulator switch that can trip if the unit overheats located underneath the barrel. What's the easiest...
You r correct. Take top off. Take control unit off. Take front off. Search how to videos online, YouTube, repairclinic.com, appliancepartspros.com
Jun 05, 2017 | LG DLE2532W Electric Dryer
LG TD C70045E dryer not heating up, this has happened before and the guy just pressed a switch but cant remember where it located, please help!
On the LG TD-C70045E the reset button for the heater is located inside the back air-way cover. This is easy enough to remove and the button is obvious once the cover is off. The button will 'click' satisfyingly if it has tripped. Don't forget to switch off and unlug first...
Aug 22, 2009 | Dryers
DLG2532W Loss of heat
I had same issue and cleaned out all lint from the entire cavity of the dryer. Fixed the problem.
Jul 08, 2009 | LG DLE0332 Gas Dryer
LG DLE2532W NO HEAT
Sounds like the heater element is bad that is the main cause for them not to heat up . Their should be a cover on the back that comes off and you can get to the heater element after removing it .
Feb 23, 2009 | LG DLE2532W Electric Dryer
Dryers Logo
149 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
