Question about Miele Dishwashers
Need to buy a valve. Where can I get one? - Miele Dishwashers
1996 suzuki 750 katana can you buy just the carb bowl gasket and the gas needle valve
Yes you can buy a needle valve assembly which consists of a needle ,o ring,and needle seat.in the UK they are about £40 each !
Apr 12, 2015 | 1996 Suzuki GSX 750 F (Katana)
How much does it cost to replace the idle control valve on a 2004 f150
I just did one on a customer's truck. The IAC [idle air control valve] for this truck is about $160 for the part. Expect to pay $20 -$30 for labor. Prior to buying a new valve, I would try removing your existing valve and cleaning it with aerosol carburetor cleaner. Buy a new gasket [under $5] with the cleaner, as you will need to replace the gasket when you re-install the valve. If you have more than 150,000 miles on your truck, cleaning the valve will probably be a waste of time.
Jul 03, 2014 | 2004 Ford F150
Flush Valve leaking
replace the whole valve. It's cheap and easy to do. Probably you can install a universal valve. Look on e-bay or amozon
I’m happy to help further over the phone at https://www.6ya.com/expert/robert_24775b73ca70da93
Dec 05, 2012 | Toto Aquia II Dual Flush Toilet
Pressure relief valve on hot water heater
Yes, these p & t valves (pressure and temp) are available from heating supply houses as well as at most big box home improvement stores. You will need to shut the water off to the hot water tank, and drain it down below the level of the valve. There are two common sizes of these valves as far as insertion depth, so you will need to check this before buying the part, or buy both and return the unused one... Hope this helps.
Jan 31, 2012 | Water Heaters
I have the oppurtunity to buy a 97 audi a4 2.6L in great condition. Minus one thing; the transmission needs a part. So says the listing. After calling, the lady claims the car is at her mechanic's...
you can most likely buy the valve body but then it has to be fitted to the transmission, after that has been done you don't know if there are any other problems with the vehicle I would be a little wary to go down that path myself, after you have bought the vehicle it becomes your problem......hope this helps........cheers.
Sep 06, 2011 | 1997 Audi A4
My timing belt slipped off the pullies while I was driving. how much damage am I looking at. The car is a 1993 pontiac sunbird
you should be fine if you just buy a new one and install it and make sure everything is lined up and aligned correctly and your straight.
Oct 06, 2010 | 1993 Pontiac Sunbird
Need bicycle pump for Fuji M500 bike - which connection to valve do I buy?
Go to a bike shop and buy a decent pump, it will have the presta valve and shraeder valve connnections you need. Save yourself the aggravation and have the right one and it will do the job very efficiently.
Sep 19, 2010 | Cycling
Valves came out was told by hoover they didnot sell them had to buy whole tank
You don't need to buy a new tank you can replace the valve. You can find all the parts you need click the link below. Please give positive feedback.
F7431 Parts Link
http://www.usavacuum.com/Hoover-Steamvac-s/109.htm
Jan 29, 2010 | Hoover F7431-900 SteamVac Vacuum
Toto fill valve continual problem, new toilet
There are cheep fill valves and ther better built fill valves, so make sure you buy aa quality fill valve. Also buy a pressuer gauge at ahard ware store and check water pressure level at a faucet outlet. Screw gauge onto water fauct leave a little room for air to escape when water is drippng out tighten the hose bib on the gage turn on the faucet and read the pressure. If it's more than 50 PSI you need to lower the water pressuer. I need to know if your on a, on site underground well,or are on city water to tell you what you need to do to to fix this problem. If there is one. thanks for using Fix-ya if you want more info post here.
Avid101
Aug 19, 2009 | Home
Dishwashers Logo
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
