Question about Samsung Televison & Video
I have a Samsung plasma tv PN51D7000FFXZA that if you unplug and plug back in, the remote and the button controls on tv work for about 2 minutes. The remote still flashes ir but without any action.
SOURCE: Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Posted on Jul 19, 2007
ctf1800
  • 4402 Answers
SOURCE: Flashing Green Light on Front of 73" Projection TV
on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
Posted on Dec 15, 2007
  • 98 Answers
SOURCE: Samsung 50" Plasma TV no response to remote ctrl & buttons
No need to exchange the Logic Board.
Need to exchange the IR modue.
Posted on Feb 06, 2009
SOURCE: The standby/timer is flashing 6 times on my Sony KP-53HS30 TV
you must change ic reg.(ic mcz 3001db)
Posted on May 06, 2009
  • 32 Answers
SOURCE: I cannot adjust the volume on my Samsung 42" Plasma (PN42a400)
its called a sleep timer. when it does come back on you need to find the sleep timer program ans turn it off
Posted on Jul 12, 2009
I have a Samsung Plasma PN63A650 that has worked 4 8 years, until today. I turned it on, stays on for 14 seconds, then turns off for 8 seconds. Would not respond to remote commands either
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. ....Samsung E6030 led tv hv blinkin red light issue ... capacitors are looking good ...
Help PLEASE! Samsung Plasma Turning On/Off Repeatedly.
michiganstate.247sports.com > Topics
247Sports.comMy Samsung Plasma HDTV (approx 3.5years old) has some issues as of late. When Iturn the tv on, invariably, it starts to turn off and back on repeatedly.
Samsung Smart TV turning off - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have a Samsung plasma 60 inch model number PN60E6500EFXZA TV. It began to turn itself off every 5 minutes, for the past few days. I was able to factory ... Samsung TV Keeps turning off and on.
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
Samsung Plasma TV turns off by itself
Jun 22, 2011
My Samsung 50 in PN50B650 turns off by itself then on again ...
Apr 30, 2010
More results from www.cnet.com
Jan 13, 2016 | Samsung Televison & Video
Samsung DVD Player remote buttons activate Samsung TV settings
To do a reset of the remote control follow the instructions below.
1. Remove the batteries from the remote control.
2. Hold down the Power button for a full minute.
3. Once done, put the new batteries back in and test the remote control. Please power cycle the unit as well by unplugging it from the wall and leaving it of for a couple of minutes. Once done, test the remote control again. To delete the recorded programs, please follow the steps below
1. Press the BD button on the remote control then press Home. This should bring up the home screen.
2. On the Homescreen, choose AllShare Play and press the Enter Button.
3. On AllShare Play, scroll down to Recorded TV and choose ''HDD''.
4. Now the titles of the recorded programs will appear.
5. Press the Tools on the remote control and select ''Delete'' from the side menu.
6. Select the titles to be deleted by highlighting them, then press the Enter button on the remote control.
7. Select ''Delete'' from the side menu then confirm deletion.
To try and resolve this issue, please reset the remote control. To do so, please refer to the instructions below: 1. Remove the batteries from the remote control. 2. Hold down the Power button for a full minute. 3. Once done, put the new batteries back in and test the remote control. Please power cycle the unit as well by unplugging it from the wall and leaving it of for a couple of minutes. Once done, test the remote control again. To delete the recorded programs, please follow the steps below: 1. Press the BD button on the remote control then press Home. This should bring up the home screen. 2. On the Homescreen, choose AllShare Play and press the Enter Button. 3. On AllShare Play, scroll down to Recorded TV and choose ''HDD''. 4. Now the titles of the recorded programs will appear. 5. Press the Tools on the remote control and select ''Delete'' from the side menu. 6. Select the titles to be deleted by highlighting them, then press the Enter button on the remote control. 7. Select ''Delete'' from the side menu then confirm deletion.
Jun 27, 2017 | Samsung LA40A550 40 in. HD-Ready LCD TV
Need code for sky remote control for samsung model ps51d450 51inch plasma tv
Hello
Sky remote codes for Samsung TV are:
065 584 615 037 245 476 516 292 318 236 398 244 100 118 060 088
646
672
642
Follow the steps below
1. Select any channel on the TV.
2. Point your Sky+ remote control away from the TV and press the tv button.
3. Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5. Point the Sky+ remote control at the TV and try the volume button.
If this works try the other TV functions.
If these work then the correct code has been selected.
It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
OK.
Aug 30, 2011 | Samsung Televison & Video
Its a tiny 42'' plasma tv which was working perfectly until my grandaughter dropped the remote control and the tv went off and now wont switch on even though the stand by light is on.It wont even turn on...
Try removing the batteries from the remote control, as a button may be stuck and is causing a repeated signal to be sent to the TV, possibly overriding any manual button actions.
Also unplug the TV for a few minutes and then plug it back in. You said that it wouldn't turn on when pressing the channel buttons on the TV, try the power button instead.
Thanks,
Chris
Boise LCD
www.BoiseLCD.com
Oct 08, 2009 | Televison & Video
Every 10 minutes my Panasonic plasma 720p turns mute
the problem is it is locked in store mode. I had to call panasonic to fix it, this is what they had me do.
1 hold the volume down on the tv while holding the menu button on the controller.
2 after the screen changes to the check menu, hold the off switch on the tv untill it turns off.
3 unplug the tv for 30 sec.
4 plug it back in and turn on the set.
5 select home option
6 your done.
Jan 22, 2009 | Panasonic Viera TH-42PX80U Plasma TV
My remote is not responding to the tv even i have changed the new baterry
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 21, 2008 | Samsung BN59-00599A Remote Control
REMOTE CONTROL DOES NOT WORK
ad remote usally droped or conecter wonttouch will have to order u a new remote thx for using fix ya lg.com has them or remotecentral ok
Feb 03, 2008 | LG 42PC3D 42 in. Plasma Television
50 in plasma buttons not working
The micro may have become latched - - try unplugging the unit for about 15 minutes. Then plug it back in and see if the functions are restored..
Bill
Dec 15, 2007 | Samsung HP-R5072 50 in. Plasma HDTV
Vizio 50 inch plasma -- remote not working
You can also try to take out the batteries and push all of the buttons with the batteries out of the remote. Then put the batteries back in and push the power button on the remote. If this doesnt work press the two TV buttons at the same time and the remote should be fine.
Sep 14, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Open Questions:
Televison & Video Logo
Henry  Thomas
Henry Thomas
