Question about Irons
HOW DO I PUT WATER IN MY PRESSA BELLA DRY STEAM IRON?? I DON'T HAVE A GRAY BUTTON I HAVE A YELLOW KNOB AND I CAN'T UNSCREW IT.
2 Suggested Answers
Terry Corrow
  • 10875 Answers
SOURCE: pressa Bella steam iron. How do I put water in?
unscrew the gray top
Posted on Jul 11, 2015
Rowenta Iron DG-980 problem
you should have a controll or button on the iron that tells it to release the steam. make sure that the button or controll is not stuck.
Aug 03, 2008 | Rowenta DG-980 Iron
Philips steam iron no steam and red tap light is flashing even when filled up with water it's still getting hot and water is boiling but steam fiction not working as red light will not go out
It sounds like the flow holes are CLOGGED with scale inside. To clean it out:
1. Drain the water/steam out the pour-in shoot at the top of the handle, over the sink. Is any crap coming out?
2. Take some VINEGAR and pour it straight into the fill pour-in shoot. Don\'t dilute it. Fill up the IRON to full line. Let the vinegar SOAK the inside of the COLD iron for 15-20 minutes, by placing it FACE DOWN on an old bath towel, on a heat-resistant surface, such as a granite counter top, or metal cookie sheet. Don\'t put the towel on the ironing board!!! It may get stained badly. Let it sit, COLD for 20 minutes. You can swirell the vinegar around by shaking the iron.
Stand it up on its flat end, with the vinegar inside, still. Take some fresh vinegar and dip Q-tips into the vinegar and clean the slots and holes on the bottom plate. Any burn streaks or soil can be removed with wiping the plate with vinegar. After you clean all the holes and slots with vinegar from the outside, TURN ON THE IRON with the vinegar inside. The vinegar will heat up and should come out the holes. If any holes are not blowing vinegar/steam, clean them with q-tips again. Don\'t let all of the vinegar inside steam out!! Just heat it enough to make sure all of the holes are clean. Some white film may come out of the holes on to the face plate--it is calcium build-up from using tap water in the iron.
Now DUMP out vinegar inside the iron and reservoir through the pour-shoot You may see crud and crap coming out. Repeat the process of filling it up, steaming through the holes etc. until the vinegar comes out clear!!!
DON\'T use tap water in any IRON. Use distilled water, or even bottled drinking water (without flavoring, additives, of course). This will prevent corrosion and calcium build up in the iron.
ALWAYS completely drain the iron from the pour-in spout each time you are finished using it!! After pouring out the tank\'s water, you can set the iron to STEAM HIGH, and force any water inside to boil off and out of iron.! Never keep water in the reservoir or iron.
I set my iron, when hot, and done using it, with the pointed side DOWN in the sink drain to make sure it is dry.
So clean it with vinegar often, use bottled drinking water or better, distilled water and it will prevent this.
Oct 24, 2013 | Irons
The steam button is stuck on (pushed in) but there's no steam.
follow this steps. God bless you
Clean an iron:
  1. Unplug the iron and make sure it is cool before cleaning.
  2. Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
  3. Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
  4. To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
Clean a metal soleplate:
  1. Unplug the iron.
  2. Use a sponge and commercial soleplate cleaner or baking soda and water to remove dirt buildup on the soleplate. Rinse well with water and dry. Don't use harsh abrasives or immerse an electric iron in water.
  3. Use very fine steel wool (0000) or an emery cloth to remove scratches and burns on the soleplate, then clean the soleplate.
Nov 15, 2012 | Black & Decker Irons
Water is leaking out of the bottom of my philli[s GC 9240
see the next steps and fix it. God bless you
Clean an iron:
  1. Unplug the iron.
  1. Unplug the iron.
Nov 14, 2012 | Irons
As the steam builds up it constantly comes out of the the blow off pressure valve under the iron. steam will come out of the sole plate when the button is pressed
see this causes and fix it. God bless you
Clean an iron:
  1. Unplug the iron.
  1. Unplug the iron.
Oct 02, 2012 | Irons
When I iron my white sheets dirty water comes out and my sheets are dirty
follow the steps and fix it. God bless you
Clean an iron:
  1. Unplug the iron.
  1. Unplug the iron.
Oct 01, 2012 | Tefal Pro Express GV 8120 Iron
I have an older model and it is not shooting steam like it did when it was new. I have tried to contact a Rowenta repair center without any luck. Is it ok to use a deposit remover in just the tank if I...
Frankly, I never use or "need" to use deposit removers (vinegar or CLR) just because I only use filtered water in the tank and use all the water until the unit is totally dry, using the blast of steam to clear out as much as possible. I remove the blue reservoir entirely, wait for the iron to be totally cool to the touch, open up the trim knob and sloted metal screw with a penny and shake out the rest of the water as much as possible. I leave the whole works to dry overnight or longer and only then do we pack it back up for storate. Just my way, don't like putting acids or salts into any metal tank for safety reason.
Sep 04, 2011 | Rowenta DG-980 Iron
Water leaking out of iron no steam I have a Hamilton Beach Steam Storm Model 14560 Lost manuel
The Use and Care Guide for the Hamilton Beach Iron can be downloaded here:
http://useandcares.hamiltonbeach.com/files/840091300.pdf
If water is leaking out of the iron:
• Do not overfill the water tank.
• If steam ironing, is Adjustable Steam Knob in a steam position that matches Temperature Control Dial steam range? Did the iron have enough time to preheat?
• If dry ironing, make sure the Adjustable Steam Knob is in the DRY IRON position.
Jun 20, 2011 | Hamilton Beach Steam Storm 14560 Iron
Won't steam
The steam irons I have see have a separate button to allow water from the reservoir to enter the steam chamber. This button latches down for steam and you unlatch it for dry. Also, there is a temperature range on the temp dial for steam.
The reservoir must have water in it for the iron to make steam. If calcium from the water has built up on the reservoir valve, it may prevent the water from entering the steam chamber. Straight white vinegar instead of water may help.
Nov 02, 2007 | Toastmaster 3302 Iron
Irons Logo
125 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
