Question about Tablets & eReaders
Everytime i go and use my tablet,,this is what always pops up,,,"unforunately, the process android.process.acore has stopped" ok... how do i get this removed
  • 14 Answers
SOURCE: everytime i turn on my
"It came time to part with my review unit of the G1 (Thanks T-Mobile!) and send the phone back to its rightful owner. But what about all the personal info on the phone? The apps, texts, e-mails, AIMs and all that jazz? A quick search of turned up an easy way of restoring your G1 to factory settings:
if you power off your phone and hold the home (shaped like a house) and the end (red hangup button) for about 20 seconds you get a triangle with an exclamation point and a picture of the G1.
Now all you have to do is pop open that pretty QWERTY keyboard and there are several keyboard shortcuts you can use to accomplish what you want to do:
Home+Back reboot system now - (Soft Reboot)
Alt+L - Toggle log text display - (Toggles between the exclamation and menu options)
Alt+S - apply - (Not brave enough yet)
Alt+W - Wipe data/factory reset - (What I chose, had to re-register, out of the box settings)
thee last option (Alt + W) and restored my borrowed G1 to factory settings. I'm sure the soft reboot could be helpful too, should you run into problems a troubled application may have caused. We didn't try the other 2 options so use at your own risk.
By the way, I couldn't live without a G1 so I made the leap and purcahsed a G1 with a T-Mobile service plan. I'm still a loyal Verizon customer and will simply have to keep both plans... but I NEEDED the G1. So basically, you can expect the application reviews and insight you've gotten at to cotinue since we've got our very own device now!
[Via Android Forums]
Posted on Apr 08, 2011
SOURCE: buenas noches, tengo problema con
A mi tambien me salio, no me dejaba entrar a ninguna aplicacion, no lo podia quitar. Tuve que recuperar el sistema operativo para regresar al inicio de fabrica aqui te dice como hacerlo es muy sencillo
Te borra las aplicaciones que tengas instaladas pero lo que tienes guardado en tu memoria se mantiene.
No se como evitarlo para, si alguien puede decirme, tks.
Posted on Aug 04, 2011
  • 274 Answers
SOURCE: my pandigital keep makeing me forceclose evrythingand i cant do nothing
It may the processor problem. or reinstall it and see.
Another method is to contact the supplier for help if you could not fix it.
Android 4.0 Tablet PC
Posted on Feb 08, 2012
  • 323 Answers
SOURCE: have a 10 magni tablet model SYTAB10ST screen shows sorry! the process android.process.acore has stopped unexpectedly please try again . it has a force close tab on screen but the error still pop up t
this means that the program you were running has crashed. If it happens everytime you launch a particular application then I would advise removing the program from the tablet and then reloading it
Posted on Dec 20, 2012
  • 268 Answers
SOURCE: My pandigital has a box pop up that says "Sorry" The process android.process.acore has stopped unexpectedly. Please try again. Force close." It just keeps popping up and won't let me do anyt
Try holding down the power and volume up buttons down for several seconds to try and soft reset your device. Power down and restart it. You don't state your model of Pandigital-that makes it hard to determine exact reset procedure. Also look for a small hole on the back or sides of the device, into which you can push a toothpick or paper clip to push a reset button (check your manual for location and reset procedure for your device). You can also try powering down, then press the volume down button and while holding that down, press the power button to turn the device back on. The error indicates a major problem with the base android software - did you recently upgrade software or install some new app? If it was a new app, try uninstalling it and see if the problem goes away.
Posted on Jan 03, 2015
Testimonial: "I tried all you said expect the uninstalling part because I can't get into the apps. There is no little hole to reset. The problem has occurred before but usually went away. This time I was trying to install an updated catalog of Slide me Sam. I guess that is the problem. I will uninstall if I ever get into the apps."
Everytime I swipe my 9" Polaroid tablet It tells me "Unfortunately, c?mara has stopped working" How do I stop this and how do I get the c?mara to work on it?
Unfortunately, Launcher has stopped - Android Forums at ...
Jan 26, 2014 - 25 posts - ‎20 authors
Ilze C likes this. ... My husband has faster reflexes than me & managed to hit the app... This seems to happen to my HD7 every time I download an app but by .... open and a message pop up says unfortunately launcher3 has stop. i can't ... or Korean and then help me to solve the launcher stop working error ... How to Fix: Unfortunately, the process android.process ...
Jan 14, 2013
Unfortunately, the process has ...
Dec 26, 2012
More results from
Missing: polaroid ‎mara
Fix for "android.process.acore" error on my tablet - YouTube
Jan 01, 2016 | Polaroid Tablets & eReaders
How do i fixandroid.process.acore
Scroll to the bottom and try the solutions in the green box.
The solution on the top is drastic and I wouldn't advise it unless all else fails.
May 12, 2015 | Tablets & eReaders
I keep getting a report box android process acore has stopped
Look at the green box at the bottom first and try that.
The factory data wipe/reset on the top should only be tried of all else fails.
May 11, 2015 | Acer Iconia A1-810
Meep keeps popping up a message that says has stopped
In this case, you will need to perform a factory reset through your Settings menu.
Mar 16, 2014 | Oregon Scientific MEEP Android Kids Tablet
Go into Settings/Applications/All and find Google Services Framework and clear the cache (if any) and clear data.
Disable DRM Protected Content Storage and Media Storage in your Apps list.
Or if either of those fails, uninstall latest update [until you get to the latest properly working update] or factory reset
Jan 12, 2014 | Mach Speed Trio Stealth G2 9.7 inch Tablet...
I keep getting a pop up that says sorry the process android.process.acore has stopped unexpectedly.please try again
That only happen when android is rooted the way to fix that is to get gapp updates 11_23_2013_2_34_37_am.png
Jul 25, 2013 | Tablets & eReaders
Problem!!! I need help!!
That is the home screen. Have you installed a different launcher or home screen. If so remove that. If you havent do a factory reset. Unless your device is rooted, You wouldnt have access to fix that error
May 12, 2013 | Google Android Sowill oioi s7 7 inch...
Have a 10 magni tablet model SYTAB10ST screen shows sorry! the process android.process.acore has stopped unexpectedly please try again . it has a force close tab on screen but the error still pop up t
Dec 20, 2012 | Tablets & eReaders
Tablets & eReaders Logo
24 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
